adamzan
Moderator
Everything posted by adamzan
  1. I am not a fan of wix filters, even though I know they have a great reputation. I used one (napa gold) on my wd21, and for that entire oil change interval the oil pressure took noticably longer to come up and the lifters ticked on nearly every startup. Changed it with another filter (don't remember the brand) and it was fine again. Same oil used both times.
  2. Those look great, B. I have the same volt meter to install. Would you mind sharing the model of the oil pressure gauge you have? I really didn't want to drill holes in my truck but I guess it wouldn't impede putting the stock trim back on if I decided to sell the vehicle.
  3. Maybe you should research here from people who've actually installed them on these vehicles...
  4. Recieved mine too. Looks good to me.
  5. You "might" be able to pass without an egr. I passed with a non functioning one here in ontario. Barely, but it passed!
  6. If you have an LSD rear diff, you do need the special fluid. Or there is an additive in a small bottle that you can add to regular gear oil. It isn't overly expensive either.
  7. I already have the gauges, just waiting on this!
  8. It sucks if you drive an auto though. Over drive will kick out on the highway a lot.
  9. The hub on the other side is sticking. Check it out
  10. I had a leak there too. Luckily for me tightening the clamps fixed it. What a bitch to reach
  11. Avoid Garys automotive, active green and ross. Frisby tire is pretty good, I've had my pathfinder in there for an alignment, and they did a good job. I was kinda annoyed that I had an appointment for 9am and the truck sat in the parking lot till after noon though. The Canadian tire on Carling ave is somehow connected with the motorsport club of Ottawa, and I have taken my vehicles there several times. Surprising for a Canadian tire they were prompt, friendly, and did the job right.
  12. Sounds like you have an issue with the alternator or the charging wires
  13. ^^ Absolutely true. Happened to me and it was a pita to diagnose.
  14. I'd say its normal for the cold weather. When mine is cold there is a crap load of white coming from the tailpipe. Once it gets warmed up there is still some but not as much. All 3 of my pathfinders have done this.
  15. I would suspect something is up with the sensor for the 4x4 light. You said the transmission was rebuilt? So they probably had all that out, I would check that switch. It is on the side of the tcase somewhere. I'm not sure where though.
  16. According to page 46 of the em part of the fsm the standard compression is 173, the minimum is 128, and the limit for difference between cylinders is 14.
  17. NGK plugs are the best for these rigs. Use whatever the manual says. For wires any decent brand will work (NGK, Bosch), or OEM.
  18. For the mis fire try unplugging the o2 sensor and see if it runs better. They don't always throw a code and it made mine miss and hesitate when it was bad.
  19. You're lucky! I believe you can go up to 2 teeth off without hitting anything. Any more than that and I don't want to know what happens.
  20. Where are you getting your belts? The gates belt I got from carquest had the marks on it.
  21. I'm not sure. The most I've seen fail in person were ones with no reverse, or reverse that slipped so bad you had it at 4k rpm and it crawled along. I also saw one once that had 1st and 3rd but no 2nd or overdrive LOL. The guy was 2 quarts low on ATF but unfortunately topping it up did not fix it. My old pathy that I had for almost 6 years had an intermittent no reverse problem that turned out to be a clogged valve body. My new one, the previous owner replaced the transmission with a "low mileage" one from a used auto parts place. It shifts ok but I find the shifts kind of sloppy. If I have to I will get it rebuilt or find an xterra HD tranny to rebuild and throw in.
  22. You said you counted 40 valleys. It's supposed to be 40 teeth. Unless you just said it wrong that mould be your issue right there.
  23. I'm curious as to how it shifts. The stock shifts are normally hard 1-2, long soft 2-3, and a "normal" 3-4.
  24. fskc you're a dumbass to the OP I would keep at it, it will eventually break loose. Try heating it and then throwing cold water on it. I've had success with that in the past.
