5523Pathfinder
Everything posted by 5523Pathfinder
  1. You gotta be talking about the Centerlink(looks like a dog bone). Nope, none of the joints are replaceable. There are a few aftermarket options out there including a Grassroots Centerlink(I have this, its awesome), Calmini makes a new steering system( go to calminis website for details, but warning, some have had long wait times to get this), a 2wd steering swap(you gotta use the search function for that one) or replace it with another factory unit. If you offroad at all, I highly recommend one of the first two options.
  2. Actually, I don't think that's abnormal. The VDC system applies the rear brakes a bit more to aid in traction as well as reducing front end dip when braking. The Infiniti FX was very well know for this. If you do some complaining to nissan(corporate, not the dealer)they might cover them for you
  3. Uh, wasn't the first pathinder the Bushmaster.... "A covered utility body style like that of the early Toyota 4Runner was also available as an aftermarket conversion by a company called Matrix3. This was available as a "dealer option" in the United States from 19841986 and was called the Bushmaster. In mid-1986 a factory-built version was introduced and was named Pathfinder. "
  4. Page EF & EC-135.... http://www.nicoclub.com/FSM/Pathfinder/1995_Pathfinder/ec.pdf#page21
  5. Time to go wheeling! Next time you home for a bit, gotta take a trip to Tahuya!
  6. Drips Oil Drops Grease Everywhere Another Crappy Useless Rotten Automobile Needs Instant Service Stop At Napa Had One Never Did Again
  7. Just cleaning the Air flow meter may not cure the problem, as when i have seen it, its not a dirty situation. Usually what i do is look at the MAF sensor output with the enigne off, at idle, and at 2000 rpm. Usually the dead giveaway is it will read near or over a volt with no air moving(spec is .5v or less). I also looked at the load precentage under heavy accleration and would see the numbers skyrocket. This is why i asked earlier about what information they gave you on how they came to the conclusion that both your cats were bad. They should be able to explain how they came to their diagnosis, thats what I do. This would be a perfect example of the failure not being the actual code. They need to properly diagnose it and no just break out the parts shotgun!
  8. If you have both of those codes at the same time, there has to be a common failure. Its very rare to have two cats on different banks go at the same time. I have reparied many of these and I will tell you what i would do. I would inspect the air flow meter. I have seen where it reads too high in its signal range without setting a check engine light. Basically, its telling the computer it has a lot more air coming in than what actually is. This in turn is making the o2 sensors read that there is either too much or too little oxygen left over after the combustion burn. The p0420/p0430 are catalytic efficiency codes, not failure codes. My money is your cats are not bad, but your air flow meter is(or you have a vacuum/air leak).
  9. It should. Did the dealer not give you a printout of the codes or write them down for you?
  10. So your truck has 4 catalytic converters. You need to get the codes it set for it to be properly diagnosed. Here are a couple of pictures to show them.. #3 on both sides #2 on both sides Now, depending on the codes, it may or may not be a Cat issue. Did they tell you how the Cats failed? Are they broken? Are they just guessing? Yes, they can fail. But they can also be easily misdiagnosed. Ive seen Mass Air Flow meters cause issues, as well as just bad sensors. I dont think there is a ECM reprogramming for the 04's, but its been a while. I would get more info from them before you pull the trigger. Oh, the codes you get will let you know what side is the issue. The code will be follow by a B1S1(bank 1 sensor 1) identification code(there are several, thats just a example). Bank 1 on the V6 is always right bank.
  11. Ok, well that apparently took me too long to edit that post. Here is what it should be... I assume your Pathfinder is a 4.0l, with hill decent control(or what we americans call the Off Road Package). Here is a pic of the wiring diagram for the ABS system. The shop should check it for codes and see whats going on. I wonder if somehow they messed up something and the Steering angle sensor needs to be reset. That can be done with some nicer aftermarket scan tools or at a Nissan dealer. The system should not just keep the system locked up. If it fails, it should go into failsafe mode, and basically you have a vehicle with no ABS until its fixed. The other possibility is that there is a brake caliper locked up.
  12. I assume your Pathfinder is a 4.0l, with hill decent control(or what we americans call the Off Road Package). Here is a pic of the wiring diagram for the ABS system. I would suggest pulling the ABS fuses and see if you can drive it.
  13. You should also replace the pilot bushing. You need to inspect the flywheel for cracks. Any over a inch, the flywheel should be replaced, not just resurfaced. Usually what I do when im in there, is a new clutch disc, pressure plate, throwout bearing, pilot bushing and a rear main seal. Your going to want to clean the bellhousing of all the clutch dust and debris. Pop off the shift fork, clean and lube the pivot stud. Luckily on the R50, there are no torsion bars to drop, but yes, as B said, it is very heavy. So be careful!
  14. Did my best Nunya inpersonation with Big Homie. Dragged a 72 ford pickup around my yard so I can rip the carb off and install a points conversion kit.
  15. Here is from the 95 manual... http://www.nicoclub.com/FSM/Pathfinder/1995_Pathfinder/tf.pdf#page8
  16. Looks like the wire for the oil pressure switch, just above the starter.
  17. or this... http://parts.nissanusa.com/nissanparts/index.cfm?action=replacement&siteid=14&selYear=1998&selOEmodel=R50&groupid=&sectionid=431&partcode=55130
  18. Some body cut the rear panhard bar? That couldnt of been easy! Or quiet! Anyway, the rear panhard bar centers the rear axle and keeps it from walking side to side. It would be very unwise to drive without one. I would love to see a pic of how it was cut.
  19. http://www.nissanpathfinders.net/forum/topic/37521-cb-radio-install-location/?hl=radio There are several threads on CB mounting, thats just one. Go to the search, advanced search, type in CB mount and select titles only. You will get a lot more than what people may post in this thread.
  20. Here is a good thread for a newbie... http://www.nissanpathfinders.net/forum/topic/9577-acronyms/
  21. Removed the parts of a tree root that got stuck in my left rear wheel/tire when wheeling over Labor Day weekend. Admired the beautiful brown mud undercoating while I was under there.
  22. http://www.nissanpathfinders.net/forum/topic/13814-aftermarket-part-list/
  23. Z car guys use them when building big power. That upgrade has been around for quiet some time. IIRC, the factory AFM tops out when building much over 400hp. The ford AFM changes those parameters
  24. Im going to throw out there any car that is currently in the "tuner" crowd. No hear me out, not the vehicles that have been "modified"(ebay or otherwise), but the cars that are left untouched. A lot of people have destroyed 240sx's and its getting harder and harder to find them in decent condition. Same goes for the AE86, Civic Si, 300zx, Supra, Miata.... See where Im going with this?
