Everything posted by sw
your mate ran from a cop? how stupid
first of all before you do it yourself or not ring a Nissan dealer and ask to speak to someone in the service depo. tell tell them you have a p1444 error code & find out what that actually is. more offten than not its something simple which even the novice spanner turner can do when you find out what it is let us know, we might be able to help some more
the o2 sensor tells the computer whats happening with air fuel mixture by the time the stuff gets to the zaust they do go bad but shouldnt of only after 38000kms
PCoA has a tread about htis at the moment the link is in my sig
when you topped up the fluid was there much metallicy crap on the plug?
those fluid leaks shouldnt be the problem check the timing and retard it some - works a treat
lockers romp on lsd's get a air locker and you have no bad side effects highly recomend them to anyone lockrites/detroits are ok aswell but they rachet round corners & slight jump in wear on tyres which ever option you go the wallet is gonna take a beating, just to what extent
thats a very good lookn job youve done there. that fuse box looks cool - stud for suppy cable then blade terminals for sub cables.
have you looked at your cat converter? when was the o2 sensor last renewed? also check your carbon canister is also in working order (probably not a cause for emissions tho)
torsion bars: i find with the weight off the bar sliding the anchor arm towards the rear of the vehicle, inside the cross member, then once free simply pulling the bar out of the holder on the lower a arm up front easier
theres no way REAL bead locks are that cheap..... down my way, $2k will get you a good set of bead lock rims... :o
thats alright, live & learn but jump back on ebay and leave some bad reports on the seller..... if your gonna sell junk like this you should have a bad reputation
i had a similar problem when rebooting my cv's i had to get my brother (a fairly beefy guy) to pull on the shaft with all his weight, to give me enough slack to get that snap ring on maybe try abit more weight to get enough slack for the snap ring
those things are bad news stay right away from them dont install them on your pathy they just trick your computer to use more fuel heres some interesting reading & this also the quote in Big Johnsons second post pretty much sums it up!
sounds like either your phone is drawing too much current (doubtful) or your charger is shorting is there something else you can try in your outlets? i tend to think if its a wiring short with the car, the fuse would blow as soon as you put it in - no applicance needed on the end of your outlet to make it short
i want one like mookies but the whole daily driver thing - cops would be all over it next would be arb steel winch bar then a custon tube bar like the second photo, without the poxy lookn skid plate
the only way to be sure with water in the engine is to take ALL spark plugs out then crank the engine over, the water gets pushed out throught the openings be a good idea to check all your oils now..... a hint: if you cant walk the water crossing then taking your vehicle through is not a good idea
15x8 is good for 31.5x10.5 up to 33x12.5 15x7 is a bit skinny fot those tyres 15x7 can run a 31.5x10.5 (I THINK!!!!) go the 15x8 wheels & 31 or 32x10.5 tyres
took me, by myself, one weekend to do it it was easy! if you were prepared and had help of a mate, you could do it in a day
just in case anyone cares...... you dont want your exhaust running cooler if the gases cool in your exhaust they will flow SLOWER = restricted flow
if someone knows better feel free to correct me to the best of my knowledge vss's dont need to be calibrated, you buy it for your model vehicle and your set to go you dont have to chage your vss for bigger tyres, you can if you want.... (not sure how you would go about it) your speedo will be out with bigger tyres but its only slightly, 2 or 3 km/hr unless your puttn like 35's upwards on a daily driver its not worth it just my $0.02
thanks for the idea Aaron
have you taken the cap off to see its not damp in there? rule out the simple things first
the search button is your best friend
what would you like to know? just use fuel hose and put it where you want it i ran my lines up in side the cab up behind the back passenger side window (of the 2 doors) i fitted my snorkel myself my lines dont go to my snorkel but some people do it i hadnt thought of a filter, sounds like a good idea, i might do that
