statikuz
About statikuz
  • Birthday 10/21/1986
    1993 Nissan Pathfinder SE-V6: 31x10.5 BFGoodrich AT-KOs on 15" rockcrawler rims Custom K&N intake PIAA headlights and foglights PIAA 520 SMR driving lights Garvin Wildnerness Accessories roof rack Rancho RS5000 shocks and steering stabilizer MSD 8mm Heli-Core plug wires Warn Premium manual hubs Alpine HU, Infinity 5x7s Idler arm brace
Contact Methods
  • AIM
    statikuz
    Nevada
statikuz's Achievements
NPORA Old-Timer (5/5)
  1. Ended up doing what should have been done in the first place - pull fuses to try and isolate the problem. Ended up being the rear cargo lamp switch that had gone bad. Unwrapped a lot of wires to figure that one out.
  2. Alrighty so a few weeks ago my alternator went kaput - replaced with Maxima alternator - went fine. Ran fine for a few days, then the truck just shut off when driving. Busted out the DMM and found that the positive terminal on the alternator was grounded somewhere. After much ado ended up tearing out the white wires that run to the alternator from the battery. The big white wire that runs from one of the connectors on the battery is still grounded somewhere! I've torn it out of the wiring harness all the way back to the firewall, where it goes in and comes back out, then runs to this connector: ... that connects to the mess of stuff attached to the positive battery terminal. In this photo you can see the two white wires in question, the upper one runs to the alternator, and the lower one goes to the battery terminal connector as above. One of my questions is, what is the thick black insulated section of the upper white wire? Also - what is the orange loop connector on the right side of the photo? The Chilton book mentions this as a fusible link? The white wire, which is shown in wiring diagrams as going directly from the alternator to the battery, goes through the firewall? Anyone know why? Main question being - any insight on what could be wrong here? Probably not including all the pertinent information in the first post so ask questions if need be. Thanks for your help and happy new year!
  3. I did actually today sell my Pathy to a friend of mine. I had just kinda disappeared for awhile. I think the window lock switch locks everything but the driver windows - I played with it and it didn't make a difference. I will probably scrounge a master window switch this week and see if that fixes it. Has to be something simple if its affecting both windows I thought (i.e. not a bad drive mechanism or something)
  4. "so I checked that first." Yep, those don't work either.
  5. So I searched around and read what I could find on power window issues but it didn't seem to help. My front power windows work fine, but the rear ones = nada. I have had issues with the front ones before, which always ended up being the driver's window switch being loose or whatever, so I checked that first. Can just the rear window part of the switch bite the dust? Anyone else had this problem? I considered replacing the driver's switch but figured I would check and see first.
  6. Its kind of a bummer but from the ones I've seen that's the story with any grille guard. Here's some pictures of the WAAG one... you can see the problem. The WAAG guards run about $600 too. If you're just looking for a little looks, you could scope out a prerunner bar that bolts to the stock bumper (like in my avatar), but if you want any sort of protection you should probably invest in a full ARB-style bar, which would run you somewhere like $850 depending where you get it (even though I know you said you weren't looking for one like that.)
  7. It's all the same body style - "Nissan Pathfinder 1986-1995 2WD,4WD" is on that list.
  8. Manik makes one - I didn't look for an online retailer but I imagine it would run you about $350-400. http://www.manik.com/products/?id=3355&rsku=7857
  9. PIAA 520s on the roof and cheapo Pro Comps on the bumper: http://www.citlink.net/~dboge/IMG_8038.jpg
  10. i wired up all my lights so i CAN turn them on if i don't have the engine running, that way if I just need a bit of light real quick I don't have to start up the truck. considering the headlights are wired up so you can leave THEM on, i imagine you would either be trained to turn your lights off when you get out, or you would probably notice that you left on some big bright lights when you turn your truck off =) my piaas were wired up in the beginning so that you could only turn them on if you had your brights on (as per the piaa instructions) but i got kinda sick of that so i fixed them =)
  11. then you should be fine i imagine, there's no problems with fitting 31s" under a stock pathy, and since you have that lift, there really shouldn't be any fitment issues.
  12. yeah, i'm with 88, i would put them up front so that way you really get some use out of them... if you just want some reverse lights you can get some real el cheapo ones and use those. you'll appreciate your nice lights if you can actually see them too
  13. pro comps are super cheap and work well, hellas are pretty good, piaas are really nice and expensive, and lightforce is the most expensive but also the slickest. =) http://www.4wheelparts.com/4wp/products/index.asp?cat=LIG you mount them with a bolt =) onto whatever sort of rack or bar you might have up top, and you wire them up with a switch and a relay http://www.4x4wire.com/tech/electrical/zj_lighting/
  14. actually, a 265/70 is 30.7" in diameter, the same as a 31x10.50. so you're getting the tires and rims together?
  15. statikuz
    Vibration Damper
    i guess they might be able to order more stuff for you, but their site doesn't have much, only for 1999+ nissans =( oh yeah, i guess they do call them "vibration dampeners". it's part of the crankshaft pulley that... well... dampens its vibrations =) according to 88's part sheet, the dealership will charge you $144 for the entire new pulley. http://store.yahoo.com/dpstore/309a901.html ???
