Everything posted by sw
you dont need to replace the whole arm you can get the old bushings pressed out and new one pressed in
poly urathane (spelling) Pete if you need help sorcing stuff i can help
Pete its a piece of cake
Does anyone out there have a 4 cyl.?
sw replied to 87pathfinder4banger's topic in Z24 Engine Discussion
interesting.... just about everyone else on Nissan bb's has said hg48 = 4.8 gears, which is what i thought now why cant the s t u p i d Nissan dealer have record of my path having hg48??? anyways guess theres only one way to REALLY find out........ keep ya posted if i bother getting round to it -
Pete no fun at all - i use to be a big fan, even went a saw them play when they came out to oz last
NO the inner cv 'cup' is recessed at the end you have to tap the end seal off, thats why i mentioned it
well the info on the link tells me nothing new however i did ring a Nissan dealer and tried to find out whats going. gave him my transaxle number and vin number, here searched for ten minutes, found my vehicles vin number, told me i had the lsd axle (emphasis being on HAD..... hehehehe) not that thats news to me. but for the life of him he couldnt find the transaxle number, kept telling me i had 4.3 or 4.6 - no new news there either my transaxle number is: FS5W71C HG48 - taken straight of the vehicle id plate the fs bit is the transmission and t case combo and the next bit is supposed to be the the diffs. but no one knows about the HG48 now a while ago while over on AC some said that the HG48 means 4.8 gears, thats why i thought what i thought, all this discussion has made me want to find out whats going on anyways the fact that the dealer couldnt find HG48 leads me to think i still have 4.8's just that no one can find it on paper anyone shed any light??? steve -
[rant] no matter where you have a jerry can in an accident its going to be dangerous. no ifs, buts or maybes i must admit for some one to hit my jerry can it would have to be another 4wd due to the height offthe ground all i know is i didnt want it iside the cab if someone finds a 'safe' place to mount a jerry can on a vehicle let me know cause i will be the first to move mine. [/rant]
well technically your right, but when theres no need you should unlock em if you leave em lock the diff will be turning over = more wear and tear on your vehicle and also slightly less mpg
good mod there engaged at a flick of the dial, not like the autos thake take a bit to engage. as well as not having a mind of their own however you do have to get out the vehicle and engage them by hand would highly recomend em
jack & support car, remove front wheel 1.loosen torsion bar completely 2.disconnect & remove locking hub 3.disconect steering arm 4.remove brake caliper 5.disconnect & remove wheel hub 6.disconnect & remove axle note: you may have to unbolt the bottom of the shock to get the axle out working on axles: 1.put the axel in a vice, working on inner joint 2.tap the joint toward the outer joint. the end seal will pop off (dont go too hard you dont want to damage the seal) 3.remove clip on tripod joint 4.remove tripod 5.disasemble shalf and clean well (the outer joint does tap off (but this step can be very hard to do and also not necasery)) 6.regrease well and fit new boots 7. reasemble (reverse of process) hint: buy a cv boot banding tool (cheap ($40) and worth its weight in gold) - style that winds in with a rachet motion just be careful and mark where the boots lie on the axle and how long the axle is. (the inner joint has 'floating' length). if you get it wrong you WILL be doing it again
YOU SHOULD KNOW THE RULES BY NOW
hi guys i have a z24 5 speed twin sparky, carby do you guys have fuel injection or carby which drive train do you have? hg48 or 46 (not sure on the hg bit but you get the picture) i got the 48.... mmmmmm 4.8 gears -
** PUTS ON FLAME SUIT ** in all truthfullness i would reckon you would get away with that kit you might have to make the steering work yourself but other than that its so simple a noob could do it with a bit of effort
i heard something about rocky mountain suspension its not hard to put a kit together your self yoou know
body lift took me a weekend & that was doing it myself, no mates to help ** faint mumor in back ground, getting ouder & louder ** go on body lift, body lift, body lift
body lifts are cheap & it wasnt that bigger job go on, you know you want to sorry Stat, i know you said no lifts etc
email Jeff Schieck (one of our members) jschieck@arbusa.com he will point you in the right derection
my understanding is they are cable operated, so you wont have a problem someone correct me if im wrong
pilot to gunner (american) at the drive in (american) edison (oz) thinktank (oz)
lets see some proof dude new d21's - $7000 i agee with Aaron what ta
yesum Mike, what did you end up doing in the end???
at what speed is this happening at sounds like rear control arm bushings
