sw
Everything posted by sw
  1. when you say 'falls off' how badly is it doing it pathfinders only have small engines and i know my path hates hills in any way shape of form
  2. usually hiatchi alternators have the reg inside bosch alternators have em outside my path has a hiatchi
  3. sw
    Sway Bar?
    yes you can tighn them, just be careful of the little rubber boot or even better take them off and go flex some where sly
  4. sw
    Noise
    if its only happening under load i would say detonation check ignition timing, knock it back 5 degrees = no problems
  5. sw
    4WD
    from your description sounds like the front diff is stuffed pull the inspection plug and see if the fluid is clean or bad, a broken seal will let contamients in if the shaft is loose maybe some internal bearings in the diff have broken down disconect the drive shaft from the diff, raise the front wheels and turn the shaft, that sticks out the end of the diff, over go from there
  6. remove the switch, get 2 small slot screw drivers and very gentely pri it apart
  7. hi & welcome not sure exactly but i have heard of them being between the dash and the firewall btw if the local Nissan shop doesnt know where it is i would be going to another shop
  8. safari snorkels look at my rig
  9. sw
    Green Liquid?
    three words again after market manual btw the only way you will have leaky seals is if they are damaged or decayed from age
  10. three words..... AFTER MARKET MANUAL
  11. simple just run a new plug, cable & switch
  12. calmini steering solution yum yum
  13. your pathy HAD electronically adjustable shocks - ride stiffness bit of a gimic though, i dont think they do anything really
  14. i always thought the 96+ came with a socket extension for removing that plug from Nissan maybe mikey or blizz can confirm
  15. you have got lots of time on your hands, havent you great mod though, if you can get all the piping to fit what brand and what size??? :cool2:
  16. what ta....... an sr20 form with the heading 'ba16 tunners - stomping on Nissan since 1988' am i missing something here???? my understanding is quite clearly an sr20 is a nissy motor please explain, or am i completely missing the point btw Pete where are you????
  17. third is of the idler arm - not sure how to check this one, but use your imagination or ask 88 - he seems to know everything else
  18. second is of the centre link, check for slop in the same way
  19. first picture is of a 'ball joint' basically to see if there is any slop grab the two bits of metal that the ball joint joins and try to move them apart. they shouldnt move apart any if theres no slop.
  20. sw
    Wheel stud
    oh i see i agree BOYCOTT les schwab
  21. sw
    Wheel stud
    if they buggered it up take it back and kick up a fuss with the manager this happened to me when i first got my muds - they stripped a stud, tried to hide it, i saw it on a visuall inspection before i left the the shop, made then fix it free of charge btw mine was a stud on the rear axle
  22. i would leave taking it to a shop as the last resort, the moneys better in your pocket than theirs...... if you can wait till tomorrow i will take some pictures tonite from my path pics will help explain
  23. firstly i dont suspect bushings - worn bushings usually give a 'shake' however do a visual on them to eliminate them check your ball joints, there are three or four each side - they do simply wear out. also check your centre link, they wear out also. also check your wheel bearings, it might be time for renewal.
  24. should be bolt out bolt in btw i have an 88 2 dr path but i also have the back door with an opening window
