DavefromOZ
Everything posted by DavefromOZ
  1. Do you mean the clear corner lights? If so they are a JDM part, available here in Oz & NZ.
  2. I wouldn't trust J-B or any other epoxy in a water jacket. If you know a skilled welder with TIG gear they may be able to fix it.
  3. Coming from the pinkman, it must be pretty gay then
  4. I pray that thing started life as a 2wd, otherwise, what a waste of a Pathy. If you want a useless POS 4wd that you cant use, you should buy a hummer.
  5. G'day Darren, another option is the roof console, check out JADM4x4's members ride, http://www.nissanpathfinders.net/forum/index.php?showtopic=22413.
  6. This is what I have come up with, still to finish it off.
  7. The headlight washer bottle on your 93 is in a different location to my 93, mine is in the front of the engine bay on passenger side. yours is a +10/93, with the round dash I see, they may have relocated it.
  8. If its the factory rocker switch that activates it, it may pay to check it with a multi-meter. I had to pull mine apart the other day as the contact inside the switch must have been arcing which resulted in a poor connection and eventually the switch simply wouldn't work. After pulling it down I simply gave it a light rub with some fine sandpaper and re-assembled. Works a treat again.
  9. Although, I cant take credit, is all available here http://www.cvwine.com/bacon/funstuff.html
  10. Anyone want a new wallet? Or a new lunch box for work For when you cut yourself in the kitchen
  11. Perth 4wd Centre specialise in imports, I will drop them an email to see if they can help.
  12. I know its not Nissan powered, but check out Cyrils conversion (Holden 3.8l), he's located in Newcastle. http://www.nissanpathfinders.net/forum/index.php?showtopic=21068
  13. If you really don't want to use the poly blocks, another option would be aluminium. I would definitely stay away from steel, most pathys are already underpowered enough, without adding any extra weight. Snake Racing here in Oz do Aluminium blocks, not sure on price. Cyril has them on his truck.
  14. First time I have seen this one, I'll be pulling mine down on the weekend.
  15. Google can be your friend here Ty, this might be of assistance http://www.modelsbuzz.com/chrome-removal-226385.html
  16. If its the light on the dash, you will find it will be a loose connection at the switch itself which is located on the handbrake lever under the centre console, mine every now and then will play up (light doesnt come on at all), I can reach down the gap in the centre console and fiddle with the wire and it comes good.
  17. Here in Oz you will pay around $550 for a Terrano Alty, even a JY job you will pay $330 (I have a buddy who just had to replace his)
  18. I don't have a centre retracting seatbelt.
  19. What is make & model of the car?
  20. I'd go with stuck/dislodged tumblers, the lock to keep the key in should hold it all the way in, not allow you to pull the key 1/2 way out. The deadbolt on my front door at home did the same thing, ended up having to pull the thing apart just to get the key out. I have a buddy who is a locksmith, I have sms'd him, if I hear back I will let you know what he suggests.
  21. Nah mate, its all good. I will add that to the collection of electrical problems I have to sort. Starting with lighting, have to hook up relays to hi & lo beam, then spotlights.
  22. Where is the 4wd light? I have never seen mine on, so either its broken or the 93 Terrano didnt come with one.
  23. Bah, I've already found you 2 sets mate, they arent that impossible. Just with shipping costs it would be a bit expensive.
