GrimGreg
Everything posted by GrimGreg
  1. Might check your ECU for codes and your vacuum lines for leaks.
  2. My mother-in-law had a 94LE. It had chrome(bumpers/mirrors), and interior tire carrier. It also had just about every option otherwise besides LSD and rear disc.
  3. Yeah, to do a ring job, might as well do a complete rebuild, or complete motor swap.
  4. 4lo is basically a crawler gear, if you need wheel speed, don't use it, use 4hi.
  5. That isn't an R50. (My 88 might look like that soon.)
  6. I hate manuals in 4x4s, way to much clutch riding/burning. Not like I'm changing gears on an obsticle, and rarely even leave second on flats in the trail.
  7. You know someone probably thought it might be a good idea....
  8. I think for what you want to tow, just get a dolly and you should be OK with the Pathy.
  9. Don't forget the ricer dude, Vengeful. He was a man at one time and wheeled the piss out of his R50.
  10. They're great, the box where all the wiring goes is about 3"x1"x1", can hide it almost anywhere. I have the same CB in my 88.
  11. You would have to add more weight in structural bracing than you remove in making it a convertible, just to keep it from folding in on its self.
  12. Me too, the big piece of spinning metal on the back of the crank is a flywheel no matter what tranny you use behind it.
  13. Well, skipped teeth + low compression test probably means you bent a valve or 2. If I were you I would pull the heads and check the valves since you have the front tore down anyway.
  14. No thanks,, nothing but NGKs in my Nissans.
  15. Less to clean up after a water or mud crossing I say they are inconvenient to have them.
  16. This is the 90-95 room, go one door down and post this
  17. Mine has been on for 3 years. I bashed the sensor (it is on the bottom of the pinion on the rear diff) on a rock and haven't fixed it. I don't like ABS anyway.
  18. DO NOT POUR BRAKE FLUID ON YOUR ENGINE!
  19. If you just can't get the screw driver into the head of the screw, use a rubber mallot to "tap" the driver into the head.
  20. Ebay http://cgi.ebay.com/ebaymotors/87-95-NISSA...sQ5fAccessories
  21. Not carb unless it was custom converted, should be TBI (BTW if it is the V6 everything else is pretty much the same beyond the intake manifold on 87-95s). And no, ECU is not the same.
  22. NO ONE MAKES A CHIP YOU CAN JUST PLUG IN!
