Pulling heads/HEAD GASKET
Slick
i took pics of everything... according to me and the manual.. my timing pulley is at ZERO degrees, and my rotor is dead on its mark, and the RH cam sprocket is also dead on.. and the center white line in the t-belt is dead above the timing pulley dead on mark.. so the only thing that is out is the 1 cam sprocket by a tooth... :blink: here are a couple pics
  • Replies 201
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
OKAY!!! NOW it makes sense!!! I thought you had the harmonic balancer, and lower timing cover off as well........Thought you were looking at the crankshaft sprocket!!!
Sorry.....I'll stop being dumb now!!! P...P...
Alright....there's 3 sprockets. 2 camshaft, one crankshaft........I assume by your first post that 1 of the camshaft sprockets, and the crankshaft sprocket are correctly lined up.
1 camshaft sprocket is off. Is that correct?
yes. the LH cam sprocket is off by one tooth from its mark.. everything else lines up PERFECTLY
hehehe.. no.. haven't got that far as i am concerned about fixing this issue b 4 going any further... i have no housing mark to line up the lower end.. as i guess is most everyones case.... i noticed when we did the t-belt b 4 that one cam sprocket was 1 tooth out.. but this time i want to get everything 100% dead on... i do NOT want to be back in there again anytime soon.. nor do i need anything breaking.l and when i smogged her he said my timing was 1 degree out at 14 degrees...... :blink: i think they are supposed to be at 13 degrees?
15 degrees BTDC.......if I remember correctly.
so.. how do i get my timing right if the manual says to have the timimg pulley at 0 degrees? this is what i didn't understand... does it automatically set itself upon start up or something? as the motor turns it changes.. cuz i know it owuldn't start at 0 degrees.... :blink:
I know when I did my 93 they didn't line up perfect either. My Step-Dad (ASE Master Mechanic) set both cams just slightly off the marks (split the differance). It actually ran better after than it had before the T-belt change :shrug: . When I did my 88s with him, it lined up dead on, so they might have gotten the marks off on later models or something.
yeah.. the belt i just took off has all the bells n whistles too.. so it won't be an issue putting it back on. I am not gunna mess with anything.. just put it back together the way it came off....
the deeper i get into there.... the uglier it gets.... i am feeling some rings shot between psiton 5 & 6...
here's a few shots from today.. tomorrow the cam sprockets come off and the heads... :blink:
:mellow:
from all the damn bars leak there was a lot of sludge in my LH valve body.... i really think that crap did more harm than good and will be looking to find some sort of engine flush once she's back together
doesnt look too bad...the heads have certain spots in the 3 or 4 diff 1's i've seen get buildup in the same places i guess the oil gets trapped and doesnt drain out and sludges up
now from ure pix i saw something very interesting...does any1 know if the 86 maxima lower intake is the same as whats on slicks truck? it looks exactly the same b/c it was fuel injected...if it is this would broaden up my spectrum for possible buyers when i go to sell all the intake parts off of the maxima motor i have
and ure replacing the timing belt and water pump while ure in there correct? i would try to do both b/c u dont wanna break a belt it makes for a very bad day and murphey's law says if u dont change the waterpump in a month or so it'll start going out on u
i did a waterpump and didnt know any better about changing the timing belt and it looked good to me but i didnt know antifreeze broke down belts and here was the result
belt
valves (the 2nd from the right is strait the other 3 are bent
Edited by unccpathfinder
belt
the t-belt has 3,000 miles on it and the h2o pump has about 2,000 miles on it.. so neither will be replaced. The t-belt has not got anything on it, i was very sure about that.. so it will be fine to reuse on there, along with the h2o pump. i will be replacing the t'stat, cap & rotor though ;):aok:
So are you saying one of the cams was off by one tooth before you started?
That would affect emission levels! And power...
Good thing you're doing all this! And thanks for sharing your adventure. I'm thinking about pulling my heads this summer to drill out all the broken studs and do some very mild porting (basic bowl shaping and clean up) before I do the headers.
And after you're done, don't worry too much about using any special "engine flush". Just run top of the line oils and change after a few hundred miles the first couple times.
Top line oils contain verrry impressive detergent packages that will clean out that stuff very quickly. My personal favorite is Valvoline, but most other name brands are probably just as good.
And of course, Mobil 1 is probably the best available for under $5/qt.
yesh. since i've had the truck it's been like that. when i changed the t-belt and even when i pulled the motor out it was like that.. it has always been 1 tooth off.... :huh:
It is common for these engines to jump by a tooth. I think it has something to do with the belt design. There are two different designs. One with round shoulders and one with very square shoulders.
Just reset it back the way it is suppose to be when you put it back together. Did n't you recently have a problem with emissons?
Sort of on topic question, sort of on....
I want to check the spark timing on my 95......I know "how" to do it...but.....I don't know what marks on the harmonic balancer represent what number....IE... TDC, 5 degrees BTDC etc.....If anyone actually knows this, since I've checked my chiltons, and the FSM, and couldn't find the info, it'd be greatly appreciated.
Edited by Simon
