SE or XE?
TeenZombie
1995 Nissan Pathfinder XE or SE, which do you like better?
371 members have voted
  1. 1. 1995 Nissan Pathfinder XE or SE, which do you like better?
    • XE
      132
    • SE
      235
Sweet mine is an offroad package :) I wasn't sure..I've also got the map lamps too...
Wow, the XE came really well appointed...these things must have started around the mid $20 thousands...
  • 1 month later...
  • 2 months later...
Well I have an XE with most of the extras I wanted so SE wouldn't make much of a difference.
XE w/ LSD, Power locks, mirrors, windows, spare tire rack, roof rack, disc brakes in front, drum in rear
Although a sun roof would be great! :)
Edited by deadline
  • 1 month later...
Power this and power that. I could care less. I like basic vehicles, less to go wrong. But SE got my vote because it comes with 31's. dont need to worry about speedo fluctuation with bigger tires, and the 8 speaker audio. Sounds great for 95, just added a sub, and swapped out the fronts for some jbls, other than that the stock speakers hold up. Im also a big fan of having a way to see the sky. +1 for sun roof.
  • 2 months later...
  • 1 year later...
The info I am putting below might have been discussed in this thread but at least I could not find it; so please excuse a newbie while I put in the following that I dug up.
When you open the hood, near the passenger side hood hinge there is a vehicle identification plate. Right below the VIN is the 14 character model identifier.
The 9th character tells whether it is xe or se. It is J for XE and P for SE.
For example mine is WHLYD21DJFBU87 - 9th character is J meaning XE.
Hope this helps someone new like me in quickly identifying XE/SE.
What years does this cover? I have a '96, '98 and a '03 and they are no. 4(X2) or 8 for the 9th character?
The one I posted earlier works for 1994, 1995. For 1996, the model identification number under the VIN/vehicle identification number on the identification plate uses the 6th character. The 6th character can be R, T or V. R is XE, T is SE and V is LE.
Here is an example from 1996:
TLPULRFR50EUA
T-> Wagon (Manufacturer's descripton not mine :-) )
LP -> VG33E engine
U -> U = 2 wheel drive, Z = 4 wheel drive
L -> LH drive
R -> R=XE, T=SE and V=LE
F -> F=Manual transmission, A=Automatic transmission
R50 -> Model
E -> Multiport fuel injection system
U -> U=Non California USA, V=California USA, N=Canada
A -> Standard (no idea what the manufacturer means by standard)
Edited by wd21fan
  • 1 month later...
TLPULRFR50EUA
LP -> VG33E engine
L -> LH drive
R50 -> Model
Nice[emoji16]
Sent from my SM-N910T using Tapatalk
  • 1 month later...
  • 7 months later...
