pathblazin420 Posted August 10, 2010 Share Posted August 10, 2010 still got lots of stuff to do but thank you very much Link to comment Share on other sites More sharing options...
Northernpathy Posted August 10, 2010 Share Posted August 10, 2010 Picked up this beauty a few weeks ago. Still haven't had a chance to do anything to it yet, but she will clean up good. Is fully loaded with the 3.0L engine, 4x4 (naturally), electric windows and doors, sunroof, etc Going to fix the body and repaint it the original color. Then do some upgrades to make it more trail ready. Came with some nice extra tires. Even came with the original manual and warranty book with the name/address of the original owner back in 88 Link to comment Share on other sites More sharing options...
Adam Posted August 10, 2010 Share Posted August 10, 2010 (edited) I've got an 86 BMW 325e that I've been working on. Found it out in a field, body is pretty straight besides one fender. Picked it up for $500, non-running, though it could technically run. I wasn't interested in it for its engine though. I had a 2001 BMW 330ci for a few years, and because BMW designed the rear subframe mounts poorly(class action settlement is supposed to cover them), mine ripped out, BMW said no-go, I got tired of fighting with them, ripped out the motor and trans, and started gutting the 325e. The 330's engine is a 225hp 3.0l in it's current form, 10.2:1 compression I believe. I'm going to be rebuilding the 3.0, either using lower compression pistons or a thicker head gasket, and I'm going to be turboing it. The engine is currently at my mechanic's, had to use an oil pan from a early 90s 525i because of the location of the front subframe on the 86, so my mechanic is making a custom oil pickup tube to work with the new oil pan. I'll be running a modified Garret GT30R turbo(seen here, goal will be 400rwhp out of the old 86. I'll be running the engine on an OBD1 ECU, and having it tuned locally for the turbo. The 86 turned out to be more of a deal than I expected as well, because it has the Getrag 260 transmission that makes for the best swap transmission(and the trans was behind a motor that couldn't go over 5000rpm, so it's got 143k on it, but with only 120hp and low torque it should have minimal wear) so I don't have to use the high mileage ZF transmission from my 330. The car also came with a limited slip rear diff, instead of open diff, meaning I saved some 300-400 depending on gearing. I'll be rebuilding the diff with a different gearset, as it's only 2.93:1, I'll probably be going 3.25 or 3.46. Some pics of the carnage: The 86 in the field I found it in Under hood, don't need that paperweight! This is the hole where the rear subframe mount on my 330 used to be... That hole is 8" wide, and about 5-6k to repair the damage properly, which is almost the value of the car. Engine out of the 86 Engine out of the 01 86 in its new home in the garage, which is also the home of my wood shop, I build guitars on the side. Under the valvecover on the 01's engine: Looks brand new, hard to believe there's 150k on that engine, compared to the Pathfinder's 200k engine that's completely covered in brown oily residue. Edited August 10, 2010 by Adam Link to comment Share on other sites More sharing options...
MAXEDpath Posted August 11, 2010 Share Posted August 11, 2010 Northernpathy you could turn that hardbody in to a PreRunner style truck with the long travel kind fiberglass fenders and stuff Link to comment Share on other sites More sharing options...
Northernpathy Posted August 11, 2010 Share Posted August 11, 2010 (edited) Northernpathy you could turn that hardbody in to a PreRunner style truck with the long travel kind fiberglass fenders and stuff Yup that is a good idea that I am looking at. They do still look good with a king-cab. I am also looking at doing something similar to this: Many things I could do with it. The truck is in great shape as it came from the west coast, so no frame rust. Last hardbody I picked up looked decent till I took the box off and found the back half of the frame completely rotten as well as both rear cab mounts rusted off. Edited August 11, 2010 by Northernpathy Link to comment Share on other sites More sharing options...
Kingman Posted August 11, 2010 Share Posted August 11, 2010 (edited) I've got an 86 BMW 325e that I've been working on. Found it out in a field, body is pretty straight besides one fender. Picked it up for $500, non-running, though it could technically run. I wasn't interested in it for its engine though. I had a 2001 BMW 330ci for a few years, and because BMW designed the rear subframe mounts poorly(class action settlement is supposed to cover them), mine ripped out, BMW said no-go, I got tired of fighting with them, ripped out the motor and trans, and started gutting the 325e. The 330's engine is a 225hp 3.0l in it's current form, 10.2:1 compression I believe. I'm going to be rebuilding the 3.0, either using lower compression pistons or a thicker head gasket, and I'm going to be turboing it. The engine is currently at my mechanic's, had to use an oil pan from a early 90s 525i because of the location of the front subframe on the 86, so my mechanic is making a custom oil pickup tube to work with the new oil pan. I'll be running a modified Garret GT30R turbo(seen here, goal will be 400rwhp out of the old 86. I'll be running the engine on an OBD1 ECU, and having it tuned locally for the turbo. The 86 turned out to be more of a deal than I expected as well, because it has the Getrag 260 transmission that makes for the best swap transmission(and the trans was behind a motor that couldn't go over 5000rpm, so it's got 143k on it, but with only 120hp and low torque it should have minimal wear) so I don't have to use the high mileage ZF transmission from my 330. The car also came with a limited slip rear diff, instead of open diff, meaning I saved some 300-400 depending on gearing. I'll be rebuilding the diff with a different gearset, as it's only 2.93:1, I'll probably be going 3.25 or 3.46. Some pics of the carnage: The 86 in the field I found it in Under hood, don't need that paperweight! This is the hole where the rear subframe mount on my 330 used to be... That hole is 8" wide, and about 5-6k to repair the damage properly, which is almost the value of the car. Engine out of the 86 Engine out of the 01 86 in its new home in the garage, which is also the home of my wood shop, I build guitars on the side. Under the valvecover on the 01's engine: Looks brand new, hard to believe there's 150k on that engine, compared to the Pathfinder's 200k engine that's completely covered in brown oily residue. BMW designs their engines pretty well.... Looks like a fun project! Is that your Suburban in the background? Looks really nice. Lol sorry, I have a thing for older Suburbans since I grew up with one and learned how to drive in it. Still miss that old boat. Edited August 11, 2010 by Kingman Link to comment Share on other sites More sharing options...
Adam Posted August 11, 2010 Share Posted August 11, 2010 Nope, no clue whose that is, didn't even meet the person who owns that lot, the guy I bought the car from was friends with the guy, and kept it on his lot. Link to comment Share on other sites More sharing options...
MAXEDpath Posted August 11, 2010 Share Posted August 11, 2010 the hard body could be turned into so many different things but it all depends on what you want to do with it Link to comment Share on other sites More sharing options...
Northernpathy Posted August 12, 2010 Share Posted August 12, 2010 the hard body could be turned into so many different things but it all depends on what you want to do with it Well when the apocyplse comes, I need a good vehicle when I become my own Lord Humongous Link to comment Share on other sites More sharing options...
MAXEDpath Posted August 12, 2010 Share Posted August 12, 2010 This is true so I'm guessing its going to become the full time off-roader/tank right???????? Link to comment Share on other sites More sharing options...
Extreme90path Posted August 20, 2010 Author Share Posted August 20, 2010 Welp, just picked this up for 400 bucks ... as if I needed another project aside from the Audi and the Pathfinder The Jetta now be doing DD duties instead of the Pathfinder for a long time! Didn't run when I picked it up. Got that all sorted out and now I am sporting 35mpgs of 8v goodness! Link to comment Share on other sites More sharing options...
GLSHLE Posted August 22, 2010 Share Posted August 22, 2010 I just started to rebuild my HybridZ,74 260Z, 383 sbc. Putting a R200 with a OBX in, all new bushings thru out. Next it's thru the motor and a 700R4. It's endless, but damn it's fun. Link to comment Share on other sites More sharing options...
adamzan Posted August 22, 2010 Share Posted August 22, 2010 Welp, just picked this up for 400 bucks ... as if I needed another project aside from the Audi and the Pathfinder The Jetta now be doing DD duties instead of the Pathfinder for a long time! Didn't run when I picked it up. Got that all sorted out and now I am sporting 35mpgs of 8v goodness! My friend has one of those it looks nice but man its more gutless than the pathfinder is. Link to comment Share on other sites More sharing options...
180sx Posted August 23, 2010 Share Posted August 23, 2010 He did say 35MPG DD didn't he? Link to comment Share on other sites More sharing options...
1987Bama Posted August 23, 2010 Share Posted August 23, 2010 Just picked it up and drove it home saturday 125 miles.I have $650 in it. 1985 BMW 635 CSi "the shark" car actually was owned or 24 years to MAJ in USMC that lived 12 miles from me.Now it is back home Link to comment Share on other sites More sharing options...
GrimGreg Posted August 24, 2010 Share Posted August 24, 2010 Just picked it up and drove it home saturday 125 miles.I have $650 in it. 1985 BMW 635 CSi "the shark" car actually was owned or 24 years to MAJ in USMC that lived 12 miles from me.Now it is back home Those 6s were the best cars ever made by BMW in my opinion. 1 Link to comment Share on other sites More sharing options...
Kingman Posted August 24, 2010 Share Posted August 24, 2010 That car is gorgeous. I love the 6-series. I will own one of those and one of these someday. Jaguar XJS HE V12 hardtop. Link to comment Share on other sites More sharing options...
1987Bama Posted August 25, 2010 Share Posted August 25, 2010 Those 6s were the best cars ever made by BMW in my opinion. I think so also,one of the best body lined car ever made. Came with full power Recaro memory seats and among other things. Owner even left his am/fm/cd player with Infinity amp in trunk.lol now to get her running correctly again Link to comment Share on other sites More sharing options...
SilverPath Posted August 27, 2010 Share Posted August 27, 2010 (edited) Lately Ive been working on my Spyder Originally it came with a 4.3 merc but when I received it, it was empty so I decided to get a 260 Mercruiser(350) with an alpha 1 unit, since in USCG rules I/O boats don't have power restrictions. Anyway been tearing the 350 down and I found 7 gallons of Dijon mustard Which unfortunatly made me start looking for a crack and I found it.... The gray line near the top is the crack, there is also a large bulge to the right of the numbers Thankfully chevy 350 blocks are dime a dozen. Edited August 27, 2010 by SilverPath Link to comment Share on other sites More sharing options...
nismothunder Posted May 25, 2011 Share Posted May 25, 2011 Damn sexy spider Silverpath. Any up dates? Link to comment Share on other sites More sharing options...
edicer2 Posted May 26, 2011 Share Posted May 26, 2011 (edited) Well heres my new project! I now have 2 zs! you can see the old z in the back How shortly after i bought it Now Replaced all the suspension with poly and solid mounts where I could, new tires, new tie rod, new ball joints, new wheel bearings, body kit(not pictured), hids, fixed all the lights, 3 gauge pod, aem wide band, e85, Garrett gt35r turbo, installed interior, nistune, short shifter, strut bars f+r, turbo blanket, ss headers, vg33e, 3" ss exhaust, z32 calipers, ss brake and clutch lines, eliminated all emissions ac and ps, 680cc injectors,maxima intake, zr3 lowering springs coming, manualzed steering rack, lsd diff,bosch 044 pump, in bay fuel gauge, efan, intercooler, 15-20psi boost, underdive pulley, maxima alternator, custom alt pulley. Edited May 26, 2011 by edicer2 Link to comment Share on other sites More sharing options...
SilverPath Posted May 27, 2011 Share Posted May 27, 2011 Damn sexy spider Silverpath. Any up dates? Sadly no, Finances tanked not long after I took possession. Its been under a tarp for awhile. Thankfully if I need to sell it off I don't have much in it. Link to comment Share on other sites More sharing options...
teixeira Posted May 30, 2011 Share Posted May 30, 2011 This is mine: 1959 Simca Aronde P60 Elysée Had all body done, rust free and new paint. Still missing the side trims, the blings. Now for a fews mechanical things... everything in a very slow motion. Link to comment Share on other sites More sharing options...
devonianwalk Posted May 30, 2011 Share Posted May 30, 2011 This is mine: 1959 Simca Aronde P60 Elysée Had all body done, rust free and new paint. Still missing the side trims, the blings. Now for a fews mechanical things... everything in a very slow motion. Awwww damn ... I love the old rides. That. Is. Nice. Link to comment Share on other sites More sharing options...
teixeira Posted May 30, 2011 Share Posted May 30, 2011 Thanks. Link to comment Share on other sites More sharing options...
