Skid Plate
Kyle94
Every WD21 I have seen has the same skid plate so I assumed it is for all of them.
Kyle, I have 2. One with the rubber side wings, one without. Buy one along with my tires... ;)
I have one (with the rubber wings) laying in my garage. Don't need it since I put on my black panther skids. Shame it won't fit in a flat-rate box or I'd send it to ya.
btw... the stock ones are really only good as a water deflector or a home for rodents. It's pretty thin and I beat the hell out of mine.
Same, I ripped mine off! Now I have a custom 5mm steel one fabed, won't bend that bugger.
Yeah, calling the stock unit a "skid plate" is really stretching it, over built splash guard is more like it wink.gif
5523pathfinder has an AC skid plate and I have never heard him complain about it... Not sure who else has one.
I took 2 of the stock skid plates and welded them together. I drilled holes every 4 inches and plug welded them and ground them flat. I had to get longer bolts. So far it has held up. I Put a huge dent in it slamming it into some rocks last year. I will post of couple of pics of how well it took it. I powder coated the inside silver so I can see better in the engine compartment and used roll on bed liner for the bottom.
Here some pics of the build
Edited by msavides
How much to buy the tires and skid plate and send em to me?
Hey, good idea!! Do they nest that well??
Did you not say earlier you hav e2 of them? Find out for yourself dork!
seriously I do like the double-up idea
hmmm... what would it fit in? how much would it cost? hah... :)
They go together perfectly. Just have to run a drill through the holes to straighten them out and get longer bolts. I welded up that useless radiator drain plug hole as well.
I still have not got under the truck to take a photo of the carnage.
Mark
If you are ever in the Yakima Area, let me know. I have 3 of them laying on the floor in the garage. You can have one if you take some other crap with you :)
how far away from kelso is yakima? oh i think... is that up by mossyrock? my cousins live there, hmm ill have to get ur adress and come by there sometime... what kind of crap would i be takin with me? hah..
