01silvapathy
14
Everything posted by 01silvapathy
Dude thats awesome! My pathy wishes she was there to join in the sfd goodness
I have had nothing but great experience with my vq, love it to death. Take good care of it with regular maintenance and it pays you back.
Whenever the topic of the R50 vs other model pathfinders comes up the first thing out of anyones mouth is always...Well the r50 does not have a frame!! You say it with some spunk as if it has some kinda valid point behind it, when really what is that point? What are the advantages to having a frame besides the whole oh real trucks have frames and its easier to lift them and so on. Sure my pathy is a unibody but never once have I EVER found myself in a situation where I was saying to myself "damn I wish I had a frame" I wheel my pathy and put it in some pretty good situations...the doors always open and never bind, the body does not torque like in some other vehicles. The towing capacity is pretty much identical to that of the wd, if anything id imagine towing with a r50 would be easier due to having more power at your disposal. The running gear on the r50 in terms of trans and xcase and axles is pretty much all the same. If anything the fact that the r50 has a unibody can be used as an arguement against a frame. The truck rides awesome, alot better than any jeep or lifted truck I have been in and our unibodies are not as notorious for becoming swiss cheese after a period of time.
Will a Xterra transfer case work on a pathfinder?
01silvapathy replied to muddfildvaynes's topic in 96-2004 R50 Pathfinders
Yes you have a tx10 transfer case in your pathy. IMO just try and stick to whats stock dont try and put parts from a different vehicle into something it was not made for. There are tons of junkyards in the houston area that have plenty of pathys to pick from. Atleast there were when I was last there lol -
Un-answered lifting question
01silvapathy replied to GApathfinder's topic in 96-2004 R50 Pathfinders
Sure you can throw on lift springs with stock hardware (shocks and struts) Most just change it out when they get the chance to do it cause it makes things easier. I know when I did my lift all the stock suspension was still in place and needing repair/replacement so I just did a lift at the same time for a little more money. The front struts are no different from any other strut you can buy since they are all the same dimensions, just KYB is the best buy and performing. The rear shocks will work but will limit travel of the rear suspension until you can buy longer shocks. Im pretty sure they will work, if not just get some cheapo autozone ones or something thats long enough. I have procomp rear shocks on mine that have lasted 3 years and still work great....paid 75 bucks for both of them out the door and I have TONS of flex with them. -
If only you were not so far away lol. Driving to El Paso is like driving to a different state basically lol.
Did anyone custom order their Pathfinder from the factory?
01silvapathy replied to jwblue's topic in 96-2004 R50 Pathfinders
Parents ordered ours. Its a 2001 LE 3.5 every option but the navi and rear cd/dvd wanna say it was 38? -
Electric Cooling Fan Conversion
01silvapathy replied to laxman0324's topic in 96-2004 R50 Pathfinders
I went wheeling this weekend in the middle of a texas summer and a massive drought. The thermometer reading in the pathy got up to 115 degrees for awhile. I was wheeling with the windows up from 9 til 7 with the ac on and the temp never got above half way. If thats not a testament to how well the stock cooling system is then I dont know what is. Its the same with stop and go traffic, never have any issues -
Yeah I had to swerve around a semi that rear ended another truck on the side of the road and then wound up flipping in a ditch at around 70mph with 33's and the 6in lift. That was REALLY sketchy with a front sway bar...I have a really strong feeling it would have turned out much much worse if I had the front sway off.
Check out this link, basically when you turn left without a sway bar your body of the pathy will want to keep going straight and creat a roll feeling. The body rolls more as the suspension does more work. http://www.speeddirect.com/index.aspx?nodeID=158
Without sway bars the front end is floaty to say the least! It does not ride like trash, it actually rides better and makes the suspension softer in my opinion. But you have to be very careful with it. Body roll will be very obvious, so take it easy if you take it off. I take mine off from time to time just cause I like to feel the suspension work if you can get that? But 90 percent of the time my sway bars are on up front, even when I wheel.
My Subframe Drop Install Thread
01silvapathy replied to 01silvapathy's topic in 96-2004 R50 Pathfinders
I dont really remember to be honest, its been quite a bit since the life was installed -
IAT Relocated, P0505 and P0325 codes
01silvapathy replied to moto-m's topic in 96-2004 R50 Pathfinders
Leave the battery negative cable undone for 12 hours. That will clear out the codes, my iat sensor is just zip tied in my engine compartment lol. Gave me an issue for a bit til I cleared the code and it never came back. -
Rear Lift Install (to compliment SFD)
01silvapathy replied to Rick13's topic in 96-2004 R50 Pathfinders
Yeah im surprised the driveshaft could take that much lift. Also since you dont have a panhard drop you may want to keep an eye on your tires, when I ran around without one for awhile since the axle was pulled towards the side it started to chew up the inside of my rear tires. Also caused bad tire scrub on my shocks....enough to bring me to a hault at slower speeds. Just some things to watch out for! -
Man I really wanna make a trip out there soon.
Looks factory, good job.
For the AC 2in lift with new shocks and struts its going to run you about 800. The SFD is about the same price once you buy the coils for it and brake lines ect.
My youtube is xmoddriver16, plenty of stuff from jeeps to my pathy to drag racing and little projects. Link- http://www.youtube.com/user/xmoddriver16
Wheel hop often has some play with bending tre's. You could try taking off the ends and sleeving them with some tubing. That may help some but im not sure its a guarentee
So jealous, really hope that they go and put a kit into production!
sas kit anyone seen this?
01silvapathy replied to ahardb0dy's topic in Solid Axle Swaps, Hardcore Custom Fab
Was it a yellow frontier? -
VH45 Swap & SAS Update (Merged Threads)
01silvapathy replied to tmorgan4's topic in Solid Axle Swaps, Hardcore Custom Fab
Looks to me like its pretty damn near finished! So whats the story, what needs to be done in order for this thing to be trail worthy? -
Found it http://www.nissanpathfinders.net/forum/index.php?showtopic=26677&st=0&p=492986&hl=+thermoplastic%20+boots&fromsearch=1entry492986
Weather wear and tear are all factors of torn boots. Both my stock cv's got torn boots a few months after the lift was put on. Simple solution for me was to get a remanufactured cv from orilleys. They come with a lifetime warranty on them so if they break or tear a boot in the future its a free replacement. Another big thing that helps is to spray down both boots with a silocone spray to help keep the boot rubber lubricated. Fleurys also did a write up on here about thermoplastic boots if you are willing to take the cv apart and replace the boots on both sides. Those boots are REALLY durable from what I have heard. He has a write up on npora somewhere of the job with pictures.
Thats very strange, hope its an easy fix for ya
