johann_peralta
Everything posted by johann_peralta
  1. To be honest, I don't know much about the topic. I did use a link arm length calculator for the front (I have to admit I had no idea how the algorithm works, but I just did as was directed by the website). For the rear, I'm not worried about the links hitting the body. The links are essentially in the same location as originally, the rear end won't have crazy flex or anything so it should be fine (I hope lol). But, thanks for the suggestion, and I will keep an eye out for any hitting on the first tests.
  2. Yes of course! That is what I spent this afternoon doing. You beat me to it. This afternoon I mocked up the lower trailing arm drop brackets! I'll post pictures in a sec.
  3. Thank you! maybe something like this but with the actual perch lower down.. https://www.artecindustries.com/TJ_rear_coil Instead of bringing the upper trailing arm mount down, I'm bringing the mount on the axle up. The gas tank is seriously in the way for doing any sort of work up there and I do not want to lower the tank. The plan is to fill the front and back with another piece of 3/16 and burn them in to strengthen the bracket. Not my brightest idea, but it beats dropping the tank IMO.
  4. Thank you! maybe something like this but with the actual perch lower down.. https://www.artecindustries.com/TJ_rear_coil
  5. Finished my thesis and graduated, so decided to buy myself a plasma cutter as a graduation gift to myself. Ended up cutting out the 4 link brackets yesterday for the rear end. Hopefully tomorrow I'll start getting them mocked up, maybe even tacked in. Stripping the Nissan underlining in tight areas, especially on the stock brackets where the ends are bend outwards is a pain in the rear. I still haven't decided on what to do for the springs... Need springs that are at least 10" longer, or need to incorporate spacers and longer springs. Ideas? what needs to be done still: 4 link brackets, panhard relocation bracket, longer brake line & breather, figure out what to do to lengthen driveshaft..
  6. Are you are talking about adding a stabilizer like the straight axle cars use?
  7. got the 40s mounted. Sorry in advance if the picture is rotated. I have no idea how to upload pictures here. I have to use other websites to upload bc this site has a tiny size limit when directly adding pictures. I use a third party that makes the picture into a link, and the link shows up as a picture.
  8. I knotched my corssmember a little bit to clear the DS, but then again i have a different setup than just a 6" sfd. As far as building them goes, unless you have a superior design to the one that's coming out soon, id recommend straying from the market. In my experience, 1 out of the 50 people that messages you and says they are definitely interested in buying and will do so soon, will actually buy. Be weary when taking a poll, because you'll get lots of interest, but hardly anyone follows through. I believe this is because these kits run a good amount of money (a full sfd is going to run around 1000$+) and generally people who drive pathfinders do so for a reason (because they are probably on a budget and the car fit the budget).
  9. yeah I can imagine it is not going to want to roll around easily. The end goal is to locate some 4.9 gears from a frontier/xterra and match the front with 4.88. Yes! This is my senior year and I'm in the thick of it. Taking biochem, bio, physics 2, and writing a thesis. I'm also studying for my graduate exams at the same time. Its a handful for sure. I'm taking microbio, cell bio, and med chem over the summer so we'll see how much more free time I get over the summer. Hoping to knock it out as soon as possible though. The hard part is already done lol
  10. I found some used tires that were so cheap I couldn't say no, even though they weren't the size I was looking for. 40x15.5x20 Nitto trail grabbers. Something is probably going to break, but that's ok. Gives me a reason to fix it and make it better the next time around. Now I'm on the lookout for some rims.
  11. I have this sitting in my garage if you're interested in it. It's the subframe blocks of a 2" sfd.
  12. Hasn't been touched since unfortunately. Between doing my thesis, BioChemistry, Physics and my Biology classes, I have no time to spare. Hopefully after graduation this May i'll have a decent break to finish the rear. On the bright side, I just bought a new welder to help with this project, so that ought to make it go by a little faster than the front end.
  13. Installing the same exact one on mine^^ brother ordered it for his tacoma, but there was an error in the production so they are sending him another for free
  14. Yesterday I stripped down the rear end completely, and you are absolutely right. Im gonna need to lower the brackets. Maybeeeee not the lowers but the uppers are most definitely going to need to be moved down. I didn't realize how far back the brackets were. In my head i saw them as about 2 feet further forward, but in reality the uppers are like a foot away from the axle and the lowers maybe 30"+-. the links in the front are probably 45" so this is a huge difference. Time to change my approach to the rear end.
  15. Your points are very good. Im going to have to lay down under it it for a while taking measurements and seeing whats the best course of action.
  16. I really would like to use the stock brackets in the rear. A lot less work involved for me.
  17. They are originals form certain countries only. Many have imported them to the US.
  18. I put the jack stands under the car (right on the rail, in front of the lower trailing arm bracket). the back wheels are barely off the ground... So i'm either gonna have to put a foot of wood under the jack stands, or get ones that are a foot taller. Either way, its pretty annoying. Rear currently has 2" lift coils. The goal is to see if I cant get ahold of longer springs that fit this. That or longer springs and weld on a spacer.
  19. I saw some numbers/letters on the inside of the corner extension piece the other day. Ill try to get a picture of them as they might help find out what this bumper came off of originally.
  20. Got the car out and back into the shed so I can get working on the rear end. Really would like to extend the current 4 link with sleeves, but another part of me says heim joints all the way around... IDK yet! Here are a few pics I took while moving it around. Also, if you have any ideas/suggestions for the front or rear end, id love to hear them. Constructive criticism is great. I want to do a pinion brake setup.. but we'll see
  21. no because the rear axle was and is still the lowest part.
  22. The brackets themselves only took maybe an hour to make and 30 minutes to install. Yes. in order for mine to work, i relocated the control arms down 3-4". So when i dropped the diff down another 3-4" they stayed at the same angle.
