19
Everything posted by johann_peralta
stoves products are pretty crappy imo. mine broke and was only offered 30% off on a new set. but i didn't order new ones bc of the fear of them breaking. try 4x4parts.com they offer metal ones that are beefier
New coils
Does anyone know the dimentions of the tie rods thread? Also what about the tie rod ends thread?
Took the boat out to the bay. 35s
On my 97 there were 4 bolts holding the whole thing into place, had to swap mine out bc rust broke one of the links
went out in the yard and gave it a good testing for a few hours. everything held fine.
- 1 reply
- 1
1 ...my front drive shaft does spin regardless of it being in 2x4 or 4x4... 2, my driveshaft would block the rear a-arm bar because i did a diff drop... so i had to go above it... ive taken it out on the road multiple times now and bump steering is yet to become a real thing. just saying. i dont mind if you or anyone trusts it... to each his or her own opinion. i wont judge. correct me if im wrong but i dont think any vehicles are designed to be lifted. or am i wrong? if i am doing harm here just let me know ill just stop posting stuff.
the rear a-arm bar is one bar that goes from one a arm to the other. it has a big curve in it to go over the front driveshaft. i know a little bit of bump steer will ocure but not too much hopefully. fot the rear i plan to put a little spacer in the driveshaft and extend the links out a little less than an inch. also get new longer coils. i will need a longer diff breathing hose and also a longer drop panhard drop bracket.
i totally understand your concerns. i fixed the bolt/washer issues and took it for a test drive in the yard. it held up fine and nothing got bent or thrown out of shape. every new idea has to start somewhere and then improve along the way right i know there are lots of different ways to improve it in a more strurdy way. im completely open to suggestions and helping tips to improve it. im no pro lol
none of those silver bolts are the final bolts... they are only there to hold the place of the gold grade 8 bolts that i will be buying soon. hopefully that clears thing up a little. the bolts will be 9/16" and will be big enough to hold the load. also no the holes arent overcleared... as of this moment the bolts are just the first i could find to maintain the structure together, that being said they arent 9/16" so they do not fill the entire hole up. i can assure you there will be proper bolts with washers in before this car ever moves an inch from the driveway. the last thing i want is to endanger anyones life because of my choises. yes there are cross bracing on the rear portion of the a arm/ control arm. and also in the strut tower... the first testing of this lift will be in my own fenced in backyard. if it isnt safe, it wont be leaving the yard. i hope this cleared thing up, the pictures posted werent that specific so they were slightly misleading...
its being sold with the 12" lift and it also comes with a running and driving spare 97 pathfinder. Original http://i58.tinypic.com/bhx0zt.jpg Original http://i59.tinypic.com/317bkba.jpg
12" lift all finished up! i just finished tonight so the pics arent so greatt... i will post more tomorrow! cv angles are perfectly flat, needs a alignment, vlears the 35s easy and will clear the 37s also! no trimming required.
right, its 3 pieces of steel, im currently looking into just making it one thicker piece. the lower u-joint used to rub the slightest bit, i got a file and filed off just a hair. now it spins freely. good eye man!
left is the top side
i used grade 8 bolts for everything... the 12 subframe bolts i used, the 6 strut bolts, i bought 10" bolts and the extra length sticks up into the hood area. the rear was just 3" lift coils and a 4" spacer, over all it gave a little more than 9" of lift. but then i added about 350lbs of sound equipment in the trunk so it droops ALOT more now... to date now i have lift coils and 8.5" of spacers. i made strut tower braces on the top and on the bottom to hold things together better. it sounds unstable but i feel just as safe, and it corners well, handles well, and works just as it should.
i do appologize for the late response, been busy at work lately and haven't had much time. this was a pretty hard thing to get my path up to 9". i began off with a 1.5" spacer in the front. i soon wanter bigger bc we all know bigger is better! jk so then i went to 3" of spacers. kept on wanting bigger but my support rusty car wasn't holding up at all so i bought another identical pathfinder that was rust free. only problem was the motor had too many miles, clutch was slipping and it was 2x4... so i swapped the motor,tranny,clutch,4x4 transfer case, the front end,suspension and pretty much did a 4x4 swap. so then i was left with an ideal pathfinder with no problems. i then wanted bigger so i bought krfabs kit and realized that i needed longer brakelies, diff breather hose, abs brake sensor line. so i was able to get them all at advanced auto parts for pretty cheap. next i lifted the rear with 4x4parts lift coils. so after this i still wanted bigger. i installed rear spacers and then realized i needed a longer break line, longer diff breather hose and longer shocks. i got the break line extension at advanced auto parts for about 17$ and used old brake hoses i had for the diff breather hose. i went to a junkyard i bought two fox shocks that are about 3' at full extension so those did the job and a little extra. so the rear was at 6" now. then i wanted the front higher.so i got ac coils. then i put extra spacers in also. after doing so the angles of my cv axles were so ridiculous that as soon as they got engaged in 4x4 they binded. the only way to solve was either to have less lift or to drop the subframe down more, so out of steel blocks i hand cut out 2 pieces that were 2x2x3, and 4 that were 2x2x6 i slid those above the krfabs kit to drop the subframe. only to realize that now the steering link was 2" short... so for all you guys that have the krfabs kit, on the steering link you can read that it says "woodwardusa" on it... so they sell the steering link (the on needed for a 6" subframe drop is the 201 spline pattern and has to be 7.75") they're link cast about 16$... so i bought the link and it fit perfectly into place and that was all. it might not all be in order and im sure i forgot something along the way^ but if you guys have any questions ill try my best to answer em.
its a home made sfd along with ac coils and spacers
it donst have have enough power to make a burnout, but it can spin them in the dirt. top speed is right around 75+-
i made a sfd at home, along with front and rear ac coils, also front and rear spacers.
sorry man computer reposted it
