johann_peralta
Everything posted by johann_peralta
  1. Finished the steering up. can turn the wheel with a pinky
  2. front one is a combination of a wj front shaft, 4x4 r50 rear shaft, rear f350 shaft
  3. Rear one is a combination of a 2wd preface lift R50 DC that i took apart and clearanced, the front driveshaft of a 4x4 r50, and the slip yoke of the f350
  4. Got driveshafts made for the car
  5. here is the case mounted up with 2 mounts. would like to get 2 more in also. I put 3/8" rubber bushings between the mounts and the cradle walls (after pic).
  6. heres the beginning of the passenger side mount. 3 1/2" bolts on the cradle side. Im planning on welding 2 tabs to the case and then use a pin/bolt through the tabs and the tube to make it like a "quick disconnect". Hopefully will get the other mounts knocked out soon.
  7. had to drop the case to get the shaft in.. what a hassle
  8. made the mid shaft to connect the stock t-case to the np201.
  9. np201. I believe it came in 57-68 dodge w100/w200/w300.
  10. needs to go up about 3" but thats the idea
  11. got it up there only to have near 200lbs of metal fall back down on my leg... that was fun.
  12. Gonna try to use this like a drop case to help my drive line angles
  13. Did my research and found a bigger master that I'm going to swap in. Stock uses a 1" bore with M10x1.00 front and rear. Bigger one is a 1.25 bore with M10x1.00 rear and M12x1.00 front. the M12X1.00 to M10x1.00 adapter ran like $2.80.
  14. got some new badges for the pathy
