hawairish
  1. Lol. Cojones mas grandes. I really wish we had a video or better pics of the final obstacle. That was something awesome. Basically about 150' of 1.5'-2' boulder steps. I ended up getting hung up a couple times when the slick rock shifted the truck, but eventually wormed up it. It did a number on my front skid plate... Already got plans for a new one. Here's the video of the obstacle just ahead of where the Xterra and I are waiting in that first pic: I was with 2nd Gen Frontier CC and Xterra Pro-4X trucks, so they only had rear lockers. They struggled a bit over the 2nd boulder...what you can't see was a deep sandy spot that was just robbing traction for both front and rear tires. What I lacked in ground clearance, I made up on traction, but it's time for more lift.
  2. Went on a kick-off run for two local Nissan groups to a trail called Hackberry Creek. Three of us opted for a more-difficult trail, and it was great. Skids, sliders, and lockers were a must. Heavy overnight rains turned much of the trail into waterways, and near-freezing temps and wind kept things interesting. Definitely bent at least one trailing arm, the front skid is a little more bowl-like, and the rear bumper is probably beyond repair. All the reason for a proper bumper, right??
  3. Yep, it was a big issue, just for a different engine. @thorpe991: That seems like a pretty solid price, and those problems listed seem pretty trivial. There are definitely some upgrades available for it. Any issues with the title? Has the timing belt been serviced? Do you have an OBD scanner that you can use to check for any stored codes, or to confirm that it has passed its Readiness Tests (assuming that a clever seller hasn't recently reset them, or pulled the SES bulb)?
  4. Not a problem on this truck. That started with MY05 trucks.
  5. I have the R200A ARB locker that used to be on that truck. Amazing the transformation it's gone through. He's got a few other good posts on Nissan4Wheelers.com.
  6. Man, that looks like a fun day! So, about the SAS...I think this is one scenario where IFS is actually better, mainly because the axle and diff can be well above the centerline of the tires (with the right amount of lift). Maybe what you really need is a miniature plow on your skid that pushes snow into your tracks for better flotation. I also couldn't help but notice how flat your LCAs are, though...almost even looks like your crossmember is lower than the LCAs in some pics. I thought you had a little more lift than SFD height? @Snowboarder12345: interesting thought about the WD21 grafting since there are SAS kits now. But surely too much work when you think about what's required just to get a donor frame, and then still have to SAS that. In my opinion, I think the R50 chassis is already prime for 4- or 5-link SAS. Remove a few bolts and disconnect some hoses, and it's like a clean slate. Then, a custom subframe to add motor mount perches, steering box mount, panhard drop, etc. That's how I'd approach it, anyway.
  7. Picked off 3 buckets-worth of dried mud from the underbody and wheelwells from last weekend's excursion. That's what was left after power washing some of it the other day. Still need to power wash it again.
  8. So another 1.5" of front lift? It's say just put the lift springs and strut spacer on and that's it. You'd drop another few hundred just to negate the lift via SFD...probably not worth it. Should be alignable with 1, possibly 2, sets of camber bolts. Some bump steer, but probably manageable.
  9. Wow! Now that's an impressive set of pics on their latest feeds. Hard to believe there's a line-up of R50s with 33+ MTs in one pic! Doubt that's ever happened here. But yeah, great call on reaching out to those guys.
  10. CV binding isn't the only reason for an SFD. It's meant to correct all the effects of lifting, 2wd or 4wd: Driveline (4wd): restored CV angles, reduced binding, more efficiency Alignment: it moves the LCA mounts downward, effectively restoring kingpin inclination Steering: tie-rods are strongest, and work best, when level Suspension: restores travel and corrects ball joint angles Stability: sway bar links should be perpendicular to the sway bar mount to be the most effective When it boils down to things, though, these benefit 4WDers who find themselves in situations where obstacles can put significantly higher stresses on the components that street driving doesn't. SFD doesn't make any component stronger, but helps them work more efficiently. Obviously, there are less effects at 2" than there are at 4". Again, OP, what's the goal here?
  11. No. A new or modified steering link is required for any SFD amount.
  12. Have you tried contacting Woodward's European counterpart? http://www.woodwardsteering.com/Contact-EUROPE.html Of course, now you understand why I asked if you had looked into this previously, noting it's perhaps most critical part of the SFD for a several reasons, including costs. I've seen other solutions, but the Woodward approach is the cleanest. In essence, you need to add a 2nd u-joint to the upper part of the existing steering link, and also extended it a little. You'll need to do some homework and find a suitable joint from another vehicle. I'm aware that some guys in the past used some Honda u-joint, but I could never find any model or year information. I did an extensive amount of research on other vehicle options and came up empty. You obviously have access to other vehicles than we do here. If you can't find a joint that slips onto the upper gear/pivot box splined end, then you'll need to consider welding a splined end to it to adapt it to some other spline size.
  13. Steering link details: http://www.nissanpathfinders.net/forum/topic/41442-sfd-steering-link-details
  14. Adding a note from Snowboarder12345 that he used a shaft length of 5.75" for a 4" SFD. Not sure what happened to my image link, but here it is again:
  15. @haydenmidd12: That's cool. Not too relevant, though, since the process and parts are 100% identical if you want to do it to a 2wd. Keep in mind, though, with the setup you just mentioned (4" SFD + 2" rear AC springs), you'll be sitting lower in the rear than the front. You'd probably need to consider adding rear spring spacers, or going with a modified WJ rear spring. So is the goal 33" tires?
  16. 2" is about the minimum you can go, otherwise you run into hardware clearance issues inside the spacers. But as Snowboarder12345 mentioned, there's not much benefit to it. You don't necessarily need the strut spacers height to match the subframe spacer height, but you do need the subframe spacer height to match the motor mount spacer height. The goal of the SFD is to offset some amount of lift so that the CVs won't bind. For the 2" SFD, for example, you could use AC's 2" lift springs, no strut spacers, and 2" SFD blocks if you wanted...and your CVs would be at stock angles. It's also okay for the amount of lift (by strut spacers and/or spring lift) to exceed the height of the subframe spacers, like in the case of a 6" SFD (which is essentially a 4" SFD with an additional 2" lift). You do need a new steering shaft for any amount of SFD drop. The increase in length is not consistent with the amount of drop (i.e., a 4" SFD does not warrant a 4" longer shaft). Woodward probably won't be able to tell you what you need, except perhaps for the 4" kit since they've sold a few. I think someone has posted the length of the shaft for the 4" kit; I can tell you what's necessary for a 2.5" and 3" SFD because I've done both.
  17. hawairish
    WD22
    Good question, Citron. Honestly, I'd love to see more Nissan truck/SUV chatter since there are actually a lot of similarities between all models (well, models before 2005 anyway), and because a decent amount of active members (self included) are familiar with other Nissan platforms. But as mentioned, this is of course for "Pathfinders"...and more specifically, for those intending to use them for off-road purpose. Not to say that we don't welcome everybody. And yes, the Xterra probably should've been the rightful successor to the WD21. If considering an Xterra, I wouldn't hesitate to ask those questions here. Many of the guys here are already familiar with the engines, transmissions (some guys actually upgrade to X transmissions), and suspension.
  18. All is not lost. But, I must stress that there is probably more research required on your part if you're still needing to ask some of these questions. (And by no means do I say this negatively; I don't mind explaining things, though I hope they're not lost in translation, of course.) Let's take a step backwards, though... The "standard" 4" SFD was intended to use all stock front suspension parts...it is essentially a spacer kit. It included 4" strut spacers, 4" subframe spacers, and 4" motor mount spacers. Since there is no off-the-shelf 4" rear lift solution, the proposed method was to use a rear WJ lift spring, which would require cutting one end of the spring so that it could fit the upper spring perch on the chassis. An adapter is required to mount the uncut end of the WJ spring to the lower spring perch on the axle. It's important to note that a 6" WJ lift spring does not mean you get 6" of lift on the R50. You will cut—and possibly re-cut—the 6" WJ springs to get 4" of lift on the R50. it is not as simple as cutting 2" off the spring. You will have to determine the amount of rear lift and rake through trial and error, which is why you'd initially want to cut off the least amount of spring as possible. Now...to get 5"-6" of lift, you do everything for the 4" SFD, and then must use front R50 lift springs (OME, AC, Snake, IronMan, Pedders...whatever is available in your region). They must be for an R50 because they have to fit the R50 strut, without being heavily customized. The front WJ spring doesn't fit the stock R50 strut. You can use stock struts (there are no "lift" struts for an R50). For the rear, the 6" WJ may or may not work (I don't know the specs of the springs), but I suspect they will. In both scenarios, the SFD spacers are all 4". Your Air Lift bags may also not work in the WJ springs. They are meant for the shape R50 springs, not WJ springs. But, it may be possible to make them fit, you'll just need to modify their installation a little, since the WJ spring adapter may interfere with the air line. If you can get around that, you can make them work. You've also not mentioned anything about the steering link, which is one of the more critical parts. Have you gotten this link, or do you intend to make a custom one? The same length is use for the 4" and 6" options above. My recommendation at this point is to just run a 4" SFD, stock front suspension, and rear WJ springs. But if you want 5"-6", all you should need is front R50 lift springs.
  19. Thanks! Funny, I'm curious to see how yours turns out! That's why I usually let the mud sit a few days to dry out, knock all the stuff off, take it to the powerwash, then just shovel the dirt off the driveway. But...I got restless and took it to the powerwash tonight...bad idea. The sprayer wasn't powerful enough to knock all the chunks off, so now I gotta take it back later. I always feel like a jerk leaving all that mud there, though. I'm hoping to get into welding this year, too. I bought a cheapo HF flux core welder last year...still in the box, though, until I can dedicate space for it. The 4Runner bumper in mind is actually a DIY (er, WIY...weld it yourself) kit, so that would/should just need slight modification of the mounting brackets. I have a few other projects lined up, that I'd at least like to tack up and get a pro to finish. But, the year is young...
  20. My kids love it, even had my 3-yo with me on the little adventure (was better than going to Costco). Got it muddy the other week, too, and left it in the driveway for a few days, then went around with a mallet to knock all the big chunks off (enough to fill a bucket). Not a mud fan, but fun to see all the crap falling off it. I've been thinking about bumpers a lot lately, actually. My last trip the other week punctured and dented the rear bumper on the passenger side...trivial metal damage underneath the quarter panel, and the plastic can probably be knocked out with a mallet and some heat. But fact is that it just hangs too low, as does my hitch. I've got something simple in mind, but not the know-how to DIY. There are a couple fabrication connections with my FB group, though. For the front, though, I've been eyeballing a 4Runner winch bumper that ought to be a better solution than the Cherokee bumper. 2016 was definitely a driveline year; 2017 will hopefully mean more lift and armor.
  21. A guy in one of the FB Nissan groups I follow got stuck in some mud yesterday, not too far from my house and put out a call for some help...and apparently some half dozen other people also got stuck all around the area (lol, idiots). I pulled out one guy in a Toyota pickup, and that was fun. After I yanked him out, I then had to drag him crooked about 300 more feet so that we were both on firm ground. It kinda looked like how a boat would pull a skier, where the skier was to the side, not directly behind...except I also had to drive sideways a bit to keep momentum. Wish I had some pics or a video. Not too shabby for ATs, but the lockers did wonders. Not sure how some guys got as stuck as they did...the guy I was actually responding was out there with a D40 2wd Frontier. Not sure what he was thinking. I suppose I should go wash it off today.
  22. In re-reading the posts, I can see where the confusion was...we were talking in the context of WJ rear springs, but "rear" got dropped from discussion and was then misinterpreted as being "all" springs. I see it wasn't caught on your confirmation post a while ago, either. Unfortunately, the front WJ springs can't easily be used. You'll need OME lift springs (the medium or heavy duty, the latter giving slightly more lift), or 2" lift springs from Automotive Customizers (4x4parts.com). (This assumes you're going for a 6" lift, or 4" SFD + 2" lift.) As for how much to cut the rears, start by cutting only one side at the spring at the point where the inner diameter is the max...that is, cut off the least amount of the pigtail so that it'll fit the upper perch. Then you'll need some adapter to sit atop the lower spring perch on the axle that will allow you to use the pigtail that's still on the opposite side of the spring. If it's been a while, I'd highly recommend searching for more SFD discussions on the forum...but the search function of the forum ignores 3-letter words, so use Google to search "NPORA SFD WJ springs" or similar to find better results. There are several of them. I can't really give any more specific details about the WJ springs because that's not the approach I took, but the concept is pretty simple.
  23. If you're still doing the SFD, you just need stock R50 front springs (or OME, etc.) for the front and the WJ rear springs for the rear. The WJ rear springs also get cut and require some sort of adapter...people have bought them because the inner diameter is close to the R50 rear springs (except at the tail end, which is why it gets cut off).
  24. Cool! But what's with the front WJ springs? I don't think you'll be able to use those anywhere.
