hawairish
  1. I believe the harness is already there. That's how it is on my 2004 SE that didn't come with heated seats, anyway. There are two harnesses (one blue, one black, I believe) under the radio, both are live when ignition switch is on, and they fit the OE seat heater switches (which I pulled from a QX4, same colors as the harness). I'd have to check under the seat, but I'm pretty sure I'd find another harness. Eventually I will add aftermarket heater elements to the seats and tap into those harnesses (if they exist). But again, if the switch harnesses exist, I'd presume the rest is there.
  2. I'll also add that with a little luck, you can also just loosen the tie rod or ball joint nuts, whack the knuckle a little, then whack the nut upward a few times and it might pop out. Don't plan on re-using the nut or joint.
  3. I see. Still a bit surprising. I wouldn't imagine anything in that regard would wear out. I mean, how much time do you spend in reverse? Well, as far as the switch goes, since it's an OE one it probably has more than one contact. You need a multimeter to find the two contacts that show continuity when the switch is closed. Then just hook up the wires to those two contacts. Doesn't matter which wire goes to which contact; the switch just needs to complete the circuit.
  4. Sounds like you need an FSM! (Factory Service Manual) Steering: http://www.nicoclub.com/manuals/Pathfinder/1998_Pathfinder/st.pdf See ST-24 for all the torque specs. Suspension: http://www.nicoclub.com/manuals/Pathfinder/1998_Pathfinder/su.pdf See SU-10. The instructions for each procedure are also in those chapters. For everything else: http://www.nicoclub.com/FSM/Pathfinder/1998_Pathfinder/ For the tie-rods and ball joints, get a cheap ball joint separator. A pickle fork will work, but it's more work. Loosen the nut, but don't remove them. Put the ball joint separator on the knuckle, tighten it up, then give each knuckle a whack with a mini sledge, then tighten the BJ separator some more. They should pop right out. If you can avoid twisting the outer tie rod off the inner tie rod, you can use it to size up the new rods and potentially avoid needing an alignment.
  5. You do know that a replacement switch from Rock Auto is $6, right? And it's just a simple switch. Two wires; one from the battery, the other to the reverse lamps. Just put a switch between the wires. If you want confirmation, just touch the two wires together and the lights should come on.
  6. Haha, so yeah, that's been the kicker about this entire black/yellow wire conversation...it's only relevant to starting the truck, not shutting it down. But, seemed like a "better to know, than not know...you know?" discussion. I think the only way the alarm factors in is if it has some remote start and/or starter disable function, and it's malfunctioning. For remote starters, the alarm can purposefully shut down the vehicle...typical scenario is if the vehicle is started remotely and the alarm never senses the ON signal from the ignition switch within some timeframe, for instance. But, any malfunction here could shut the truck down. Honestly, if you have no dependencies on the alarm (is it even wired into the door signals or control power locks or windows?) and aren't even sure what it does (or doesn't), I'd be removing it. One less failure point. Conversely, if you want a new old remote start alarm I've got one from a long time ago that I never installed, I'll sell it to you for a couple bucks . Could also try a more brutish approach to recreate the problem: start the truck, and start smacking and tugging wire bundles, relays, harnesses, keys while in ignition, etc. Can't help on identifying those relays, but the quickest test is to pull them up and see what wire is grounded, put a 12v source on the opposite contact (typically labelled "86") and see what turns off. If the wires are connected using slide terminals, make sure they still have firm contact.
  7. Ha, what timing...I just got my renewal email today.
  8. You're missing it because you said yours started as a MT truck, which doesn't utilize an inhibitor circuit. That probably means your current AT inhibitor switch is part of the equation that's causing the black/yellow to read as a ground when in P/N. I'd guess that if you look into that relay socket, you're missing some of the slide connectors that would be necessary if a relay was installed. Take a look at this: http://www.nicoclub.com/service-manual?fsm=Pathfinder/1993_Pathfinder/Starting_charging_AT_wiring If you lacked both inhibitor switch and relay, the B/Y may in fact be grounded. For an MT, B/Y led to the clutch interlock. Guessing some magic occurred during the engine/trans swap. The FSM suggests there are two active leads when the ignition switch is turned to Start. B/Y is supposed to be one of them, but I can't determine from the FSM what the other is. It's the wire below the open/missing connector, and from a picture of the harness, it looks like it might be black/green. If that's true, perhaps it's the lead to your starter?
  9. That's why CA sets the (sub)standard. AZ is basically paperless, and it's awesome. Emissions process is super simple, good for 2 years on some vehicles, and is only required for Phoenix and Tucson area residents. You can even view real-time station wait-times online. Almost everything MVD-related (yeah, not "DMV" here) can be done online: vehicle registrations/renewals, DL updates/replacements, temp plates, sold notices, etc. Hell, just earlier in the year I needed them to overnight me a replacement driver's license...and they delivered it, on-time. They've come a long way since telling me my CA birth certificate was invalid when I first moved here in 1996... When I returned in 2010, they asked me if I wanted the same license picture I took in 1998 (when I was 18). Tempting, but no thanks. Glad you made it up there ok. Your posse, however, seems a little less enthusiastic.
  10. Haven't done it, but it wouldn't be difficult. Both diffs have a barb that you just need a hose to slip over (1/4"?) and then you just route the hose to your desired location. The front diff is already route to a point above the bellhousing, behind the engine. The rear diff just runs up to a chassis reinforcement, but would be easy to bring into the cabin. Here's an existing project, which also re-routes the transmission and t-case breathers: http://www.nissanpathfinders.net/forum/topic/33293-transmission-and-t-case-breathers/
  11. Have you tried disconnecting the ignition switch harness and testing the ignition switch for continuity scenarios (per FSM), as well as probing the live harness? Just to rule out the ignition switch...
  12. Hey, sorry for the hiatus. Couple things worth clearing up...maybe not the case for your specific vehicle since it's got the engine swap, but notables about what I see in a few Nissans (and what I can recall from my Frontier without having it in front of me). Black/Yellow per a 1989 W/D21, 1994 W/D21, and 1998 D22 is the signal from the ignition switch to the starter. You can confirm by checking the EL chapters in the Starting System diagrams. So, it's only hot when the key is at the Start position (can be confirmed by disconnecting the starter harness). One notable is that both W/D21 FSMs indicate that US-editions may actually have Black/Purple wiring, while CAN-editions have Black/Yellow. But, I also agree with Slartibartfast about possibly measuring this after the interlock switch and getting a false reading. I definitely don't see anything that suggests black/yellow is a ground, and it doesn't make sense to be—the ignition switch is just a switch between the battery and the rest of the systems, so it shouldn't ground anything. But without bastardizing that wiring (and I wouldn't see a purpose to it), I'm not sure it plays into anything here since it would only impact the ability to start the truck.
  13. Just to describe those acronyms better, SPDT (single-pole, double-throw) refers to the number of circuits (poles) and actions (throws) that switch handles. SPST is the simplest switch; with one circuit and one action, it's either on or off. SPDT is a step up in that it can toggle between two contacts to create "OR" logic for a single circuit; that is either one contact is connected to the circuit OR the other contact is connected to the circuit. SPDT On-Off-On is very similar, except it has a center state where no contact is connected. If you see something like (On)-Off-On or Mom-Off-On, it just means the 1st position is momentary (press and hold), the 2nd position is off, and the 3rd position is on. Lastly, if you see "NO" or "NC", this refers to the normal state of the if it's a momentary pushbutton switch; it's either normally-open (off) or normally-closed (on), noting that pressing (and holding) the button will do the opposite of the NO/NC state. The ARB switches are a type of rocker switch more commonly known as "Carling" switches. Most Carling switches I've seen are DPST because of the status LED being its own circuit, but the illumination circuit isn't switched and doesn't factor into the classification. Specifically for that switch, if you want the illumination LED to dim, you would need an illumination signal and metered ground (the dimmer switch is a potentiometer, and does this function)...both of which can be found on the back of the OE dimmer switch. You're basically following the "Do not jumper" note for terminal #7. But, keep in mind that dimming is a function of the bulb/LED, so this may have little or no effect if the bulb can't handle the voltage or current drop. But, to make it dimmable, on the back of the dimmer switch you'd need to splice the pink/green wire to terminal #6 and the pink/black wire to terminal #7, and not "jump" ("ground would be a better word) #7 to #8. OTOH, if you don't want/need it to dim, and only want the illumination LED to come on with the dash lights, you can still connect the pink/green to #6 and just ground #7 (or ground #7 and #8 together, doesn't matter). Since your switch is under the radio, you should have a pink/green wire in the radio harness that is on the illumination circuit (this normally connects to the orange wire found on aftermarket radios, btw). #8 gets ground in either scenario, as this is the ground for the status LED when the switch is in the On position. Clear as mud?
  14. Unless the alarm has an immobilizer and/or remote start feature, it's likely not the problem. If you don't see any thick wires coming from the alarm module (i.e., those that might be capable of handling high currents), then it's probably just used for arming/disarming. Although it might have an input for ignition sensing for some functions, none would (should) be capable of stalling the truck.
  15. Very easy. Two scenarios you might like: In this scenario, they'll be on if a) you're in reverse, or b ) if you flip a switch. In this one, you have a little more control and you can choose whether they're a) on with reverse, b ) off completely, or c) on with a switch. I didn't have better symbol options for a switch, so disregard the direction (and that it's for a rotary switch). A SPDT On-Off-On rocker switch (not shown) is a good choice here...the middle prong on the switch would lead to the relay; the outer prongs would be for the reverse and ACC/12V signals. A diode is probably optional, but a safe way to keep power out of that circuit just in case in that first scenario. For the switch, you can decide when to feed it power...do you want to be able to turn them on even with the truck off, or perhaps only when the key is in the ACC or ON position? The reverse signal you can get from the park/neutral position switch (AT) or the back-up lamp switch (MT). FSM says it's a yellow wire, so just need to splice into that. You can also take it directly from one of the taillights (also yellow). The switched lead can come from multiple sources. The radio circuit is usually the easiest place since it has both a constant (blue w/yellow) and ACC/ON (green w/white) circuit. (BTW, these wiring colors are specific to your 00MY per the FSM.) On a side note...the existing back-up lights are not on a relay, so I don't recommend powering your new backup lights on the same circuit unless you're certain the overall load is below the amp rating on the circuit (10A). Even with LEDs, it might work, but it's a long circuit run and you may just end up popping fuses (and you should not simply use a larger fuse) or heating up the wires. Best bet is a separate fused source. If you plan to add any other electrical accessories to the vehicle, consider adding a fused distribution block instead of just adding a bunch of wires to the battery. On the relay: 30 - battery 85 - reverse/switched signal from SPDT switch 86 - ground 87 - to lights
  16. The loose key in the slot is probably normal, as the key and tumblers have worn down over time (the keyed part is just for the steering wheel lock anyway; it's the key's tip that engages the ignition switch). In re-reading your original post, can you confirm something for me? The systems that were on seem like those that would be available if the ignition were turned to the ACC position (noting that headlights and the hazards should always work, regardless of position), right? I don't know specifics about an 88, but it's usually the case that AC/fan, dash functions, and power windows don't work until the ignition is in the ON position (truck started or not). The ignition also returns to ON after starting the truck and must remain ON, of course. My thought is that if the truck returns to an ACC state and not an ON state when it stalls, instead of staying in an ON state when the key is still pointing to it, then I'd still be suspicious of the ignition switch. If it's anything else (like a bad relay, engine/mechanical failure) it would stay in ON in theory.
  17. If the relay isn't unique for your setup, do you have another you could swap it with? Could always test the relay, too, but sounds like it would only fail intermittently. Could take it apart to check for corrosion or any residue from arcing.
  18. To answer your 2nd question first, I think it might just be coincidental that reconnecting the cables seems to reset things...but by the same token, it's very possible that some connection at the cable could also be a culprit, and a small amount of flex is "fixing" it. Any signs of corrosion, fraying, looseness at the terminals? When you say circuit breaker, and you talking about a fusible link? The reason for suggesting the ignition switch is that, short of a cut cable or something more obvious at the battery or fusebox, is that it's the only moving part of the equation. It has contacts that can wear and solder joints that can crack...both of which can randomly stall, or prevent starting, the engine. Here are also 3 personal experiences about the delicateness of electricity for some components: Friend's VW Cabriolet was dying randomly mid-drive. The contacts on the ignition switch had worn down...the tiniest key wiggle would not only shut off a running car, but would prevent it from starting if at just the slightest incorrect position (pulled the fuel pump fused, and listened to it pause during cranking with tiny key movements in the Start position). On my Frontier, I had a Clifford Immobilizer. The heavy gauge wires for the ignition switch run through it, and one day, my truck mysteriously died in an intersection (when my parents were driving, no less). Happened to me very randomly over a few weeks, but could seemingly always start it up immediately after. It died around a turn one day, couldn't restart it. Traced it to the Clifford unit...tiny hairline solder fracture on the circuit board was the problem. Although it wasn't directly an issue with the ignition switch, the implication is clear. On a Infiniti J30, the headlights kept shutting off randomly. Usually stayed on, sometimes flickered. Took me HOURS to find this tiny headlight control module with...you guessed...a cracked solder joint inside. Not ignition related, of course, but similar random electrical issues. I do a fair amount of soldering on various other projects, and usually when I have unpredictable electrical problems, I pull out a magnifying glass and check the solder joints first. Doesn't take much to open a circuit. Even had a similar problem on one of my kid's toys recently. Simple fixes, but tedious to locate. Bottom line is that a tiny solder crack can cause a myriad of odd symptoms, but there are also contacts that just wear down sometimes. And the ignition switch is the first point in the circuit with them, so that's the basis for the suggestion. Replacements are pretty cheap, though I'm not sure if yours would be screwed or riveted on (I want to say the one on my Frontier is only screwed on).
  19. Found a Spicer catalog. http://media.spicerparts.com/cfs/files/media/pJJfDdtvqTwkxbSCA/k350-1-dssp.pdf See page 249 for WD21 and R50 4wd applications; the p/ns match what Steve provided earlier (5-135X front, 5-1505X rear). The latter is also used on a Subaru Brat, lol. It reads like 1310 is the series, and not an actual p/n? And it looks like 5-135X is a part of that series, but uses outer clips...which is a problem because the front shaft uses inner clips. They list an alternate p/n, 5-785X, which also uses outer clips. So really, this can't be correct. 5-1505X is confirmed as having inner clips on page 281. I can confirm the bearing cap diameters as being correct at 1.102", but they provide 2.208" as the distance "between snap rings" and I'm not exactly sure what that really means. I measure a min 2.045" and max 2.240" on the channel (i.e., 0.195"-wide clip channel), but since their dimension is closer to the outer edges of the channel, it couldn't possibly account for the snap rings being installed (and hence not really between snap rings, which would be closer to the min distance). But, if the distance between "installed" snap rings is really 2.208", that would be closer to the ones I just installed, and theoretically as much as a PITA to install. Hopefully I'm just misreading 2.208" as the max width of the c-clip channels, not accounting for snap rings, which would reasonably coincide with the joint I removed. Kingman, recall any experience with this particular joint by chance?
  20. This was going to be my first suggestion as I was reading it. Try some continuity checks while jiggling the keys, slight key turns, and maybe tugs on the wiring harness. Not sure if the contacts are exposed, but check for any hairline cracks on the solder joints.
  21. I took the truck on a 150-mile shakedown yesterday. Included about 20 miles of a popular off-road trail here (Crown King), 50 miles of dirt/washboard road, and 80 miles of highway over about maybe 6 hours (it was a much longer day with family riding along and several stops). I'm very pleased with the brakes. Holding and slow-stopping power is surely improved. Had one particular "oh-@!*%" moment on a hairpin turn that I didn't see too well in the twilight on the dirt road, and my impression coming out of it was that while the drums would've held, it would have surely been deeper into the turn. The experience with them has been hard to quantify so far, but driving with them has been like this: there are many times already that I forget that I've even swapped. That's good in the sense that nothing feels degraded or compromised. Driving around in traffic, coming to gradual stops at intersections, slow curves around the neighborhood...you just don't even notice it. But for the few instances I've need a little more (deliberate or not), I've not been disappointed. I've not had similar sensations since owning the truck, but then again, I've not changed the shoes or drums (well, sort of changed the shoes with thicker used ones from my spare axle)...but I have properly adjusted the shoes and bled the brakes several times to be as optimal as possible. Overall, it's still one of those upgrades that I wonder if fiscally beneficial, though. I did end up popping the LH-side end stop on the parking brake cable, so it's clear that using these isn't ideal unless you crimp them further. Even then, without removing them, they'd still have the insulation in them. I'm thinking the proper approach would be to cut off both end stops, strip the insulation, and crimp on new end stops (or salvage the end stop from the cut piece...heating it up would likely melt the insulation and allow the stop to slip off easily). It may even make sense to move the crimp point up maybe 3/4"-1" on the cable to take up some slack from adjustment at the parking brake lever.
  22. Way to put the shop to use one more time. And go figure on the bumpstops...
  23. Did a 150-mile highway + off-road shakedown on the truck to test lockers and disc brakes...on a scale of 1 to 10, it's awesome. Aimed it towards one particular obstacle that I've bypassed for a lesser obstacle twice before. Made it my bitch this time.
  24. No, there are bumpstops. You're thinking about the dust cover (aka bellow), but I'm talking about a bumpstop (aka jounce bumper). It's the yellow thing in the pic, included in the bellows kit: If you're missing that, you're allowing more up-travel, and consequently more spring compression (than expected). As for the strut bearing...in Towndawg's case, those clowns didn't even install them. It was metal-metal contact. The upper coil bucket stayed stationary until the coil's resistance forced the bucket to move when he turned the wheel...and it only moved slightly at the very end of the turn. That means the spring was twisting when/how it shouldn't, which could ultimately weaken it.
