edicer2
Everything posted by edicer2
  1. hmm i thought you had to remove the speaker thing to to get back there thats why i didnt even try it. ill have to see if i can get that panel off easy and do it then its worth not having that happen anymore!
  2. edicer2
    LED's
    Hope this helps... the front side lights are 168. I bought the cool blue ones from my 92 pathfinder i also have 8k hids in my projectors and they look like the exact same color and match great but i have different headlights and all clear side markers (from aus) and then i bought hard body front blinkers which are clear with mirrored bulbs so they arent orange inside. I didnt install leds for blinkers because i didnt want to deal with soldering resistor to make them not blink fast. Like others have side you might of bought the wrong bulb for the brake light. reference on here. I normally get my bulbs from superbrightleds.com 1995 NISSAN Pathfinder High & low beam headlamp 9004 9004SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility. 9004ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility. 9004EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19. 9004XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility. 9004CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility. Parking light 168 168ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider. 168LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety. Front turn signal 1156 1156ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider. 1156LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety. Rear turn signal 1156 1156ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider. 1156LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety. Tail light 1157 1157ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider. 1157LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety. Stop light 1157 1157ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider. 1157LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety. High mount stop light 168 168ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider. 168LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety. Fog/Driving light H3-55W License plate 168 168ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider. 168LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety. 89 89LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety. Back up light 1156 1156ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider. 1156LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety. Front sidemarker 168 168ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider. 168LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety. Step/Courtesy light DE3175 DE3175LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
  3. I like it! i personally lift my suv but it snows a @!*% load here so i dont want to risk getting stuck...if i lived down south i would do the same thing!
  4. o ok well... mine were junk and the oem ones were probably about the same if not more. Im just hopeing its a litter better ride like they claim they are. If not then o well atleast ik they will be cranked evenly on both sides instead of oneway more than the other.
  5. yeah thats what i bought was some sway away units but they are on a month back order...o well i guess. I hope they help with it being less stiff its so bad ha!
  6. apparently....my mechanic who did it said he reindexed them but the passenger side one wouldnt get cranked all the way up and my driver side one is barely cranked. It is causing a really uneven bounce in the front because of it and it is also way to stiff for my linking my air intake keeps popping apart its so stiff.
  7. Hi William I will try and measure that for you might he hard now with the grill and brush guard back on there. C and D are the same size as the OEM headlights but ill measure them anyways I will also get the measurements for A and B
  8. https://www.4x4parts.com/nissan/turn-stopper-caps-p-6072.html (they were cheaper from my dealer though but i would order some or get them at the dealer) see that little metal cap that is in the lower left of the picture kind of a hexagon shape? replace them there are 2 on each side they will help with the sweaking alot! i just did it on my pathfinder.
  9. the maxima one should work fine its a very common swap for the z31 I would check your ground and also get the alt tested again. have them test the new one at the store also. I have one on both of my z31's and they get 14.5v constant at idle and we both have a vg33 or vg30 in them and it works on both so theres no reason it shouldnt be working in the pathfinder too.
  10. Like others said i would check the speedo and gear if they seem ok maybe try a different cluster
  11. I got my ac 3" lift finally installed and pan hard drop bar. I also bought some aftermarket torsion bars since mine are shot.
  12. i think those are part of that ebay set of wood stickers for the interior they have a whole bunch of them
  13. i recently bought a 97 manual pathfinder center counsole for the wd21 pathfinder im waiting to swap it in
  14. do you have a friend who can borrow you a cluster? it take a few mins to check
  15. im willing to bet its the cluster also.
  16. you do some amazing work! I wish I could drive mine out there and have you do a sas!
  17. where did you get that? http://www.amazon.com/Display-Pressure-Monitor-Sensors-Koolertron/dp/B004CUGB6Q
  18. received my 3" ac lift springs friday. I am going to try to get that along with the pan hard drop bracket installed and tbars cranked this week sometime and then ill be getting my 96+ center console soon too and then all i need is some new tires! BL will be later this winter.
  19. im trying to find a good aggressive 33x10.5 that is good in snow, mud and water...i dont really care about the noise level any suggestions (dont want to spend like 1000$ on tires though)
  20. 33x10.5 would work though on legos right?
  21. could i run a 33x10.5 on the factory wheels with a 3" ac lift?
  22. Installed my clinometer today with blue leds i had left over from my dash conversion in my 87t 300zx came out well and it all works! I didnt cut holes i bent the tabs and velcroed it down. If i ever want to sell it i dont have holes in my dash and i can just bend the tabs back down again. I have it wired to the cig lighter light so it lights up when i turn the parking lights on. Its to light out for me to get a picture right now with it lit up. Took about 30 mins to do most of it was planing how to mount it.
  23. in my 300zx which used the same motor the only belt i run is a alternator belt...i dont even have a ac or ps belts so you should be dine not using it. You just wont have ac it wont affect anything at all besides give u a little extra power and maybe .5 mpg
