ejin4499
Everything posted by ejin4499
I'm looking now but incase you already have a solution do these guys have a connector for the m30 maf plug? N/m no they don't
Pulleys for VG30E accessories on a VG33E engine
ejin4499 replied to Dizer92Pathfinder's topic in 90-95 WD21 Pathfinders
stripped it down to the shortblock cleaned new gaskets and seals swapped the mounting brackets from the vg30 to the vg33 so all my accessories mount up in the stock locations. I didn't have to build or modify any bracketry. swapped the crank from the vg30 swapped the oil pump 4x4 water pump from a 95 cams from the vg30 intake from the vg30 installed oil filter stud and little ball thingy that I can't remember the name of that goes next to the stud. orginaly I used the vg30 fuel rail but switched to the vg33 fuel rail and changed out the clips. I wouldn't bother with this again cause the flow rate of the injectors is the same. basicaly made a bigger bore vg30. It was great to learn from and is giving me a great foundation to build from. If you look at my engine everything is in stock wd21 locations all my wireing harnesses are stock so all the manuals still apply with out any futzing around. -
What speed and rpm are you driving during your commute?
I know that Mr. 510 is working on a pulley adapter to use the 33 crank with 30 accessories. Has anyone seen a hybrid pulley that would allow you to use the ribbed pulley for the super charger from the frontiers and xterras and use the rest of your vbelt vg30 accessories?
my maf harness connector was loose and worn out. I tried retensioning it and made a mess out of it. doh Also at some point I intend to swap in the maf and ecu from an m30 that I have laying around here. I've been chasing a intermittent idle issue for a while. I wanted to get that sorted first. Thus trying to retention the loose maf harness.
Maaaaaannnn (end whine) Why is it all the cool stuff comes out after I get done with the project? -
Those look sweet. I like that option alot better than splicing stuff from parts trucks. Any idea who the manufacturer is?
To splice or not to splice that is the question. Wether it is nobler to cut and splice existing cable or to replace the whole thing and repin connector and the conection at the ecu. Obviously running new wire would be the better way to go but is splicing a new plug on the maf wireing harness a problem?
My thought was to install a pan in the rear cargo area that dropped down into where the gas tank would be then be able to cover it with a panel and the cargo mat. That way its not dropping to low just the thinkness of the tire (wich is less the the thinkness of the tank) I don't have to lift it on top of my truck, I can mount what ever I want to the carrier or I can remove it altogether and I can still get to it if I get my truck stuck up to its axles in something.
has anyone swaped the gas tank from a 96 -up pathfinder to a 90-95? I was thinking if I move the tank I could move the spare under the truck and be able to mount something else to that tire carrier ie gas can.
Hell if the whole engine is there just grab the whole thing swap your accessory brackets from the 30 to the 33 with a new water pump swap your crank and cams and your set. almost all that work is just ratchet wrenching.
have you checked the reset of your hoses for cracking esp the ones under the intake manifold?
you will need to drill out your bolt holes on your headers to get them to fit over the 10mm studs I would make sure your have a little slack in there for expansion and cooling. I think you will need to notch out one of the water channels to get them to line up properly. The intake manifold I would use off the vg33 I think it is a little larger but don't quote me on that.
I think it depends on where the leak is. I have always been told that if you have a leak anywhere before your O2 sensor that it can throw off your reading.When I put my headers on they use a slip fitting on the cross over pipe; I had a lot of trouble with my idle until I got that welded. When I had a leaking manifold I don't think I had any real issues with emissions or idle. Personaly I think its not that big at deal as long as its right at your manifold or after your O2 sensor. YMMV
dude that sucks. Pick up a vg33 rebuild it or at least give it a good inspection and go with that. Not much diff in the gas mileage.
What happened to your old ones? If they warped you have other problems that need to be fixed first.
EGR Function Check Engine Light problem.....? RESOLVED!
ejin4499 replied to leeuniverse's topic in The Garage
Have you checked to make sure all your connections are good and tight and your not just suffering from a bad electrical connection. Shouldn't need a mechanic for that one. -
why rebuild a vg30 when you can drop in a vg33 out of a 2003 xterra? While your at it drop in the transmission out of the same xterra along with a cooler bypass and your set.
well sure if you want to take the easy way out.
If you switch your ecu to a federal 90-93 and switch your o2 sensor to the old smaller style I think you can side step the whole issue. Also for anyone in Cali the federal will still pass smog but give you a little bit better fuel map. I swapped mine out and could tell the difference, not a huge difference mind you but a difference.
Sorry man but your tranny sounds like its shot. Reverse is the first to go. I'd start trying to find a junked Xterra and pull that one to replace yours. But you could go through the factory manuals pinned in this forum. I think it has a diagnostic procedure to go through for each gear.
just for kicks disconnect the o2 sensor and see if it leans out or stays running rich. If it leans out there is your problem an $80 o2 sensor. If it stays running rich see if something is impeding air intake.
not quite. Remember that giant loom of wires that attached to the side of the automatic tranny some of it was probably covered in white cloth. I wired the reverse lines from that loom to the reverse switch. I also ran the neutral lines from that same loom to the neutral safety switch that is right next to the reverse lamp switch. by using the existing wires I didn't have to mess with rewiring a jack. The only problem is I can't for the life of me remember how I figured out which wires went to what gear selection. section AT page 71 shows you each pin out for each gear selection that should be all you need to wire those switches up. Let me know how it goes for you.
I"m not sure what the proper harness looks like. I made a custom one, but the one you are using is not hooked up to the two switches at the top of your tranny. Check that you can find them. check out page 33 of MT in the service manuals. That should show you the ones I am talking about. On the automatic those are built into the gear selector that mounts to the side of the transmission.
there are actually two switches for your 4x4. You just don't have the switches hooked up right. Spend some time with the manual to figure out which switch does what and where it is supposed to hookup. You might need to custom wire a harness to make them all work. did you just reuse the wiring harness that came with your automagic tranns? That harness doesn't have the all the plugs that you need. if you did you can cut the gear selection harness that was on the side of your transmission and wire up the reverse and neutral safety switches to the appropriate switch on the tranny.
