ejin4499
Everything posted by ejin4499
  1. The backup lights wire to a switch on the side of the shifter. When you put your manual in did you happen to notice them just below where the shifter bolts to the transmission case? I ended up cobbling a wiring harness together from two that I had previously cut to shreds but I think if you take one out of a truck with a manual trans you can put in in yours with a minimum of work. Double check the manual for all your connections.
  2. To get to those hard to reach places without removing stuff you might use propane with the engine running and see if it changes pitch. I took a weed burner bell off (it just threads on) and used the wand to gas a potential leak. Just make sure to do it in an open area and let the propane dissipate every now and again. Also a quick way to confirm that there is a vacuum leak somewhere spray a little propane or starter fluid in your intake. If your engine races you have a vacuum leak if it dies there probably is not a leak or it is really small.
  3. Next time I post a question do me a favor and keep any opinions or facts to yourself. I would rather blow up an engine than have you poison another thread. In other words BUTT OUT!!
  4. There is no right or wrong only the one with the price you are willing to pay. Trying to get back on topic increasing compression can be achieved by milling the heads down a certain amount taking into account the change in timing and clearances. Another method that I have read about is overboring and using pistons from a VH45. Does anyone have any information on this or any other type of pistons that might be used in a vg33 short block. I remember reading someone from this forum did do that and posted a right up but I can't seem to find it. So far from this conversation I have gathered that you have several ways to increase compression in our engines. 1. Pressurize the air going turbo or super charger. 2. Shorten the cylinder by milling the heads. Which I assume you could also mill the block and get the same result? 3. Change how far the piston pushes with a different shape 4. Has anyone seen a way to change how far the rod pushes the piston? Isn't this called a stroker ??? Found a company that would do a set of custom pistons though they don't post pricing. www.reacetep.com
  5. tungsten why is it that you always have such strong opinions on different topics but so little to back it up with? Don't do it because it will be out of spec? Doing anything to raise compression with or without boost is going to take the truck out of factory spec. Out of spec is a prerequisite of this conversation. Isn't the whole point of having our trucks getting it out of factory spec and into our own specs? As well as help each other out when we take it a little to far? :/end rant
  6. Whats wrong with adjustable cam gears. I thought people ran them on stock setups so they could mess with there timing anyway? So what happens that causes the parasitic drag?
  7. Ahh and here I thought you would have some clever calculator on the internet that would do the math before I tore the engine down. does anyone know what the clearance between the pistons and the valves is on a stock setup?
  8. As always I can count on you to provide an answer that is both thorough and research/question provoking. If I were going to use the jwt s1 cams that provide .440 inches of lift how would I figure out if the valves would clear my pistons? All assuming a vg33 with stock pistons and bore with a head that was milled 1 mm.
  9. So I've been doing a little reading and was wondering about some ways to raise the compression in our engines. I've heard of using q45 pistons to get it up to 10:1. I was wondering if the people who have made the vg34 conversion could post any hp gains or gas mileage gains that they might have gotten from the upgrade. I've also heard of "decking" the heads and using a thinner head gasket but I'm skeptical of the compression gains from that. Anyone have any personal experience with that?
  10. And what do you base your opinion on? More oxygen + more gas = more power until the thing blows up was my line of thinking.
  11. I think I'll abandon the project. Part of the reason I was looking at it is I can produce almost pure O2 for free using a solar cell I have. I would need way more cells in order to make enough O2 for this to be a worthwhile project but it was a cool mind experiment. If anyone comes up with another way to do this cheap I'm totaly willing to pick it back up.
  12. Someone check my math on this. If we are flowing approx 280 cfm at 6000 rpm at 21%O2 that means that we are getting about 58.8 cfm of O2. If I displace some of the atmosphere with O2 say 49 cfm O2 that would give me an intake from atmosphere of about 231 cfm 21%O2 = 48 cfm O2. So to double the amount of O2 coming into the air intake I only need to push about 49 cfm pure O2. Am I right on that? Edit: doing a little more math means that in order to supply this with enough O2 to double the charge I would need about 4 pounds of O2 at STP per minute. So either a reformer or a trailer full of solar panels and tank of water. Dang!!! Thanks B for the calculator.
  13. Do you happen to know how much cfm they do flow through that? If I want to be able to make a worthwhile experiment I need to be able to figure out how much O2 would be required to make a difference. I'm thinking I want to try getting up to 25 30 40 and 50% O2 in the intake charge. If I can get it up to 50% O2 that would be like more than doubling how much air gets into the engine without using any kind of turbo or super and staying smog legal. On the other side if I can only push the stock ecm so hard I would like to know how hard. Then one of these guys who doesn't have to deal with CA smog can try and go further.
  14. Assuming that the O2 sensor only has the ability to fine tune the fuel mixture what about putting a variable resistor on the mafs to tell the ecu that more air is being pulled in and then feed in the appropriate amount of O2. Thinking a little more about that once you figured out how much resistance to add you could put in just a regular resistor, as long as you had a constant feed of O2 for as long as the truck was running. For controlling how much O2 was being fed in I was thinking about using the part of the throttle where the cruise control attaches back to a valve that comes after a regulator. Or calibrate the regulator on the O2 tank and mount the variable resistor to the regulator in some elegant and clever way so that as I turn up the O2 it turns up the resistance. All of this assumes that putting a resistor on the maf will tell it that more air is going into the intake. Edit: Also doesn't the ecu try and maintain like 12:1 but stoich is 14:1. If so even just a little O2 might help a well maintained engine run a little better?
  15. I've been toying with an idea of injecting a certain amount of pure O2 into the intake just before the mafs. would this make the engine run like it has a vacuum leak? Mafs sensor works off the idea that for a certain mass of air there is so much O2 present. right? By messing with the air mixture (CO2 O2 and N2 not air to gas mixture) would that throw the system off or would the O2 sensor see it and start compensating for it? N/m where I get the O2 at this point. Thanks
  16. shop vac (that's on its last legs anyway) to the drain hole, dw40 to thin out the oil and flush the cap to the drain port so the shop vac can suck it out. Flush the dw40 out with cheap gear oil then put the good stuff in. You might also just use compressed air in through the fill port with the shop vac pulling from the drain port to make a wind tunnel effect to move that crap out. HTH
  17. wasn't aware they made depends for our vehicle.
  18. Cut it off then drill it out. The insides are mostly ceramic and really brittle. If you mess it up real good grind off the old bung and threads weld a new bung in place. You should be able to do all that from under the truck. Good luck.
  19. except get a set of jwt cams if you have the cash after all the other upgrades.
  20. are you going to do a dual exhaust or just run a y-pipe? With a body lift you should have lots of room on both sides of the transmission.
  21. Dude I get this too. I've been trying to track it down. Have you made any progress on this?
  22. ejin4499
    3000rpm
    the maf works by heating a wire to a certain temp then measures how much voltage it takes to maintain that temp. The more dense the air is the more heat it can pull from the maf the more heat the air pulls the more voltage it takes to maintain temp.
