ejin4499
Everything posted by ejin4499
Fuel injector wiring/connector repair (damn rats!)
ejin4499 replied to TXPower's topic in 90-95 WD21 Pathfinders
Its not a bad pull as long as your willing to take the upper manifold off. Its only 4 or 5 bolts and some hoses which you probably need to replace anyway. Everything on the top of your engine including your injectors goes back to that bunch of wires and connectors at the front of your engine. The only tricky one is the knock sensor which is under your lower intake but you can get your hand in there if your patient and don't mind the squeeze. Personally with all the rats you have described I'd take the intake down to the heads off so I could clean it all out and make sure they didn't leave you any more presents. Even with all that its easier than chasing down wires and plugs and heaven only knows what else, And I would seriously hate to be chasing a wiring problem that turned out to be a vacuum leak. Here is a pic of the bugger with the lower intake out of the way. yes that is a vg33 but its close enough. -
you might consider getting some nitrogen and freezing the new one so it shrinks down some before you put it in. I don't know what liquid nitrogen would do to the rubber but the metal would be fine.
Sorry I just have to ask the obvious question. Why not just go get a complete harness from a yard? For my expenses I'd ship you a injection harness from Cali as long as you don't need it in a hurry. -
Assuming all the time in the world to do things slowly and as cash permits I would pull everything down to the bare metal, save what is still in decent shape for later, get a donor vehicle and swap everything over wholesale. If I had an option I would get something with a VQ engine. Then once I know how heavy the engine is going to be SAS it.
Difficulty lvl of swapping Manual for Auto?
ejin4499 replied to mikestewart395's topic in The Garage
The wiring isn't that bad three or four plugs to rewire on the harness but a donor vehicle would be really really nice to have. If you don't have that then make sure you read up on what people take out for the manual swap so you know what you need to put back in. If memory serves you would need a Tranny computer all the wiring from that (look under driver side seat) The key lock in the ignition Harness from the tranny to the shifter Harness from tranny to engine bay Compatible speed sensor yours being an 88 would have a mechanical speed sensor i think you can take yours and put it on a newer automatic but you may want better confirmation than that. You're going to have to do something about the clutch pedal and neutral safety switches and interlock switches There is a switch for changing something about how the tranny shifts to the left of the steering column don't know if you need that or not but its there. Good luck hope that gets your started -
Sealed mine up with grey rtv can't even tell it's there. Used it like it was spakle.
that info would be awesom just to have if you can post it.
what year maxima is that fan out of?
I have had the maf O rings get old and lose a seal. You might be hearing air whistle through that.
you could always just weld it
Did anyone ever try to swap the hardbody ebrake to the pathfinder? I remember a thread on it but couldn't find it.
As stated before it depends on if you have made other mods to your engine. stock engine absolutely not worth it larger engine with better exhaust maybe.
Update Found a patrol website (foreign cousin of the pathfinder right?) http://www.patrol4x4.com/forum/general-patrol-discussion-17/donator-maf-sensor-booster-65671/ Where they discuss a voltage modifier. Tell me this doesn't sound like exactly what I was trying to do but better because its programmable. also found this http://3rdstrikeperformance.com/index.php?main_page=product_info&cPath=23_73_192_1260_3289&products_id=1660&zenid=38b1aadd7f1a041fce16ea05b470c371
Ours is a hot wire element not a vane type MAF. The fsm only posts 1 temp vs voltage output at idle no load. The fsm for the 97 posts 2 idle and 2500 rpm. As Nefarious pointed out there is some where around 100 different steps. I need enough points to estimate the current maf curve and then see if I can match that curve with a different hot wire. My hope is that I can make the same shape maf curve with the new element but make the MAF report that the air has more mass than it really does. If the computer thinks the air has more mass it will richen up the mixture. Once I know how much then I can tune the bore to the right size for the new element.
Does anyone know where I can find any specific documentation about our maf. The only thing I am able to find is generic to MAFs in general. I'm hoping for a break down of what its output vs input is and what the darn thing is made out of. I am reasonably sure that it is a platinum resistor similar to what is used in thermometers but I would love some manufacturer specs on it.
Ok I totaly understand that, but where I'm lost is we are talking about making the MAF bore larger not the throttle body. The other part of this discussion wich is unstated is that some of us are using a VG33 block on VG30 equipment. How can we uncork the intake so we can make the most of that bigger block? To me the throttle is the easy part to figure out. Bore it out and put a bigger plate in there. The tricky part is the maf. How can we open that up without having to reprogram the ecu for a new sensor? Thus my question what is the hot wire in the existing maf and can we replace it with a bigger lower resistance one to recalibrate the sensor for a larger bore/maf body?
Unless he was trying to dial his rig in for a certain speed would changing the gears really net him any better mileage?
why not swap your hood with a MPFI pathie so the vacuum diagram matches what you have? How would they know at that point?
Could you go into what you mean by un-driveable? I always figured more air means more power and on naturally aspirated engines more air means less restriction.
I get what your saying about not being able to use a different maf, but what about replacing those two wires (pictured below) on our stock maf (what are those by the way) with a slightly larger diameter wires? That would lower the resistance inside the maf itself. That way I'm not messing with the output I'm messing with the input the sensor is useing. Everything else that the maf does says the same. It just now thinks that more air is getting in. Which is correct because we would use a larger diameter maf housing. Either bore out a stock one or build one. Credit goes to Precise for the picture
The vg30/33 doesn't make enough power to add a 6th gear at highway speeds. Want better gas mileage get more efficient engine. VQ35 with the tranny out of a 350z.
Our maf works by putting out x volts through the hot wire and measures what it gets back. Depending on how hot that wire is allowed to get will dictate the resistance and thus the mass of air moving through a known diameter pipe. If I want the computer to think less air is going through the housing I would add a resistor to the line making the computer think the hot wire is hotter than it is. And if I wanted the computer to think more air is getting into the engine I would reduce the amount of resistance. So if my above statement is true then if we want to use a larger MAF housing(boring VG33 etc) then we need a way to reduce the resistance of the hot wire circuit by an amount proportional to how much larger our new housing is. I think the ways to reduce resistance is to cool the conductor (not likely) shorten the circuit (also not so likely) or increase the size of the conductor. Since the copper wire that goes to and from the maf doesn't really bring a lot of resistance we would have to look at changing the hot wire in the maf in order to change its resistance. So assuming everything I have just typed is correct what is that thing made out of and can we get a slightly larger one proportional to the size of our new maf housing. I am sure after the crack wears off this will make absolutely no sense but right now it sounds good.
Awesome So I can lift to my little hearts content. I saw that write up and did it the next day. Way easy and super simple. for anyone who later finds this page and is looking for that writeup http://www.nissanpathfinders.net/forum/topic/29777-flipping-my-axles-this-weekend/?hl=%2Bbrake+%2Bswap+%2Bmy1path&do=findComment&comment=564975
You nailed it. Sorry about my poor grammar that's what I get for posting between service calls. I'm interested to know more about that Porsche swap too.
How far can we lift a wd21 before we need a different shaft ? Just curious.
