R3DN1CK
Everything posted by R3DN1CK
  1. if the resistor is bad the fan will only operate on high. if the fan isn't working on high now, its the switch or the fan motor.
  2. that thing is burly as hell, you drive a tank for aliving or a 6x6?
  3. flush the fluid and refill with proper fluid. Had a friend of mine use the wrong type brake fluid in his bike and the rear caliper froze up from the fluid boiling, when I went to move the lever the line bust and he got steam in his face. Try to open the bleeder first and if fluid comes out, keep trying to press the pedal with it open. Should release any pressure in the system. might also be something wrong with the throwout bearing arm?
  4. dude, the part unbolt and rebolt. Just fix it yourself and keep it or if you really want to sell it. fix it yourself, then sell it. It might grow on you. At least it will be easier to sell it for more with it fixed.
  5. Yep, lots of places to offroad. I just have been going out to ocotillo for over 16 years. It's my comfort zone.
  6. you got a link for those rough contrty arms?
  7. fuses, find them, pull them, problem solved? put them back in the summertime.
  8. bad mileage and bucking, I am going to suggest getting a junk yard maf to try. $20 or so used. Worth a shot. I have an old I30 that would stall out. Was told it had bad grounds and that the ecu was toast. I work at a dealer and they were telling me this... took it to a performance tuning shop in the area and it was a bad maf. Changed it out, no more stall or bucking and my mileage couldn't be better. I tried cleaning it with CRC mass air flow sensor cleaner to no avail.
  9. Get a JWT popcharger, you won't regret it. You river crossing people are nuts. I will stick to my desert.
  10. I went thought the menus and didn't see it either... I would call them.
  11. A lot of techs at my shop have started using 1/4" stuff for clearance issues.
  12. I was just saying if you had a rub issue, maybe you could adjust the bolts or replace them with longer ones?
  13. 4 lightly used BFG all terrains for $40 cash.... you can have my man card, Got plenty of saved $$$ to buy another one.
  14. Transfer case is Matic-D which is just mercon dexron(MD3)
  15. The Nissan Motorsports borla exhaust is a 2" can with 3" tip.
  16. the one for the ecu has two wires with a f/i injector style connector, the one for the gauge is a single wire.
  17. my work has a site: nissanpartscheap.com it's 20% off of wholesale msrp.
  18. just follow the directions... if you let the smoke out it won't work.
  19. confirmed, but the oil leaks outta the lifters when the truck sits too...
  20. The fsm has different length specs for adjustment on the steering stop bolts depending on tire size.
  21. Factory one is like $15, just get a stock one.
  22. got my FSM on ebay, like new under $50 shipped. I work at the dealer and that was way below my cost. I have had luck buying the FSM on dvd/cd on ebay for other cars but prefer the printed bible version as I don't need the computer.
