Northernpathy
Everything posted by Northernpathy
You can get still get the general "SE", "LE", "XE", "V6" and "NISSAN" decals, but like everyone else stated, nothing else. I wanted to replace the decal package on the side of my Hardbody, but I knew they didn't make them anymore so I took pictures with a tape measure before I ripped them off. I hope to get the local decal/sign shop place to reproduce them.
whats this part called for window
Northernpathy replied to NightWolf's topic in 90-95 WD21 Pathfinders
No idea at all, but do you see it in the picture on this page? http://www.courtesyparts.com/pathfinder-parts-wd21-1987-1995/genuine-nissan-parts/bodyside-rear/803-front-door-window-regulator/-c-5572_5573_5716_5723.html Edit: lol. Looks like crazyhayseed beat me to it -
Two on each side if you have a suspension lift is what I have read. I got mine aligned right after the lift and they never said anything about that even though I clearly told the mechanic and manager that I had installed two new camber bolts on each side after he told me there would be an extra charge if they were rusted and they had to heat them with torches. I brought the truck for another alignment after I removed one strut a few months later (as I had to fix something behind it) and while they said that everything was good and it only needed a very slight adjustment, they never said anything to the fact that I should only have one. I put in two and haven't had any problems.
Well that's what you have to do to afford the Taco Looks nice. When are you taking it off road?
I wouldn't want one of those. Is just a winch sitting on a brush guard. A brush guard that is not load bearing. Even the OEM brush guard had thicker main supports. Those are paper thin. That thing will get ripped off or very badly bent the first time it is used. If you can't find it anywhere, that is probably because it was a prototype or something. I can't see how those two tiny supports could take over 4000lbs of weight from the truck.
My stock ones are in the snow bank outside. I wouldn't put them back on. They are just a great way to hold water/mud/salt against the fender to rust it out.
I replaced mine. Bought it through NAPA which was a easy bolt on with no welding needed. Was pretty easy and straight forward: http://www.nissanpathfinders.net/forum/index.php?showtopic=25920&view=findpost&p=528542 Go under there with a reciprocating saw and cut it apart to make things easier to remove. Worst part is removing the studs from the cat's. Mine were rusted solid and I needed to heat them up until they melted off. Looks like you will have to do the same. I didn't replace the cat's as mine were in good shape.
How much does our pathfinder weigh?
Northernpathy replied to Cuong Nguyen's topic in 90-95 WD21 Pathfinders
You mean stock or once we had added all our mods? Stock weight should be on the VIN plate on the inside of the door. Not sure how much it weighs though with all the gear and my fat ass inside -
Ebay is your friend. Bought a new set of door locks for my Hardbody with 2 keys for $25. The little yellow clip things can be ordered at Nissan for like $1.50 each. Though if you are looking for a complete set of locks (including the ignition) so that you have only one key, it will cost you some good money as you will likely not be able to find a used set in good shape. A new complete set is $200 or so. I don't have a problem with two different keys. Though I would have bought a complete set from the start to have just one key if I would have known my ignition lock would seize up a month after I changed the door locks (requiring that I buy a new ignition lock assembly).
I am not a small guy either (6'1"). I removed the seat bottoms in the back, put down the back seats, advanced the front seats as far as I could, took out ALL the gear in the back and there was not much room in the back. I had to sleep in an angle to fit and it was pretty uncomfortable. Luckily it was just one night. Now with all the gear I have in the back that is impossible. It is doable, but I would recommend against it unless you really need to sleep in the truck for some reason.
has anyone seen these free wheeling hubs
Northernpathy replied to flyinwall's topic in General Forums
Have to agree with Dave and it looks like knock offs from China. Might work just fine but I am not sure if I would take the chance when, like Precise stated, you can buy MM ones for the same price. -
What would cause my temp gauge to read improper?
Northernpathy replied to WOT's topic in 96-2004 R50 Pathfinders
Get a new girlfriend. Problem solved Sorry, never had the problem. If all else fails, call the local Nissan service place and ask. When I ask they usually have no problem recommending what to do. Though the first recommendation is always to bring it to them to look, but I just make up an excuse like it is my only vehicle and can't bring it in for a while for them to look at it. -
Wire them to the original fog light wiring. Like the others have stated, there are relays built into the truck for them. That way you can use the original switch. Why add extra wiring, relays and switches when you can use the original ones? Well unless you plan on doing something fancy with them.
Snorkel for an 96-99.5 R50?
Northernpathy replied to OfftourRoadie96's topic in 96-2004 R50 Pathfinders
Starts here: http://www.nissanpathfinders.net/forum/index.php?showtopic=25920&view=findpost&p=553039 -
Cost me $80+tax. $20 for 6ft of straight pipe, and $60 for the three elbows ($20 each). So pretty much $100. Put a few pieces of pipe together and weld the connections. If I can do it, I am sure most people here could as well. Even if you have a cheap basic welder, you can do it no problem. If not, you could always use ABS plastic pipe. Still does the same job in the end. Yeah it is the most versatile and looks the best. Problem is the $450US+shipping price tag. I figured that by the time it got here it would have cost nearly $600. I was quoted $80 and $115 shipping by two places. Then add the customs/duties, etc. -
Yeah I have seen those cheaper ones on ebay from a company in Malaysia (I believe). They will probably fit, but I wouldn't put too much confidence in them (you get what you pay for). Only problem with fiberglass is that if you hit it hard enough with a branch on a trail or something, it will shatter to pieces. The more expensive plastic ones are made from a high-impact "super" plastic that will flex/bend when hit. This is the "offical" one made for the first/second gen R50's. It is nick-named "the leech" for a reason. Costs around $350+shipping. 4x4parts.com stocks them: http://www.snorkels.com.au/p/530501/airflow-snorkel-kit-nissan-pathfinder-r50-up-to-2005-.html Then there is the Safari snorkel. The one made for the Navara will fit on our trucks. Actually it will fit on a lot of vehicles. I have seen people put them on WD21's, D21's, R50's, Toyota's, Jeep Cherokee's, etc. It is not a perfect fit, but it seems to work very well. You can order it from most anywhere that sells snorkels. Problem is that it costs $450+shipping: http://www.safarisnorkel.com/snorkel/ss720hf/ss720hf.htm After that there is custom made. -
Yeah the heater in my Hardbody is really, really damn hot. You are sweating bullets after 15-20 minutes of it running. Even on the lowest setting I have to crack the window open to keep things comfortable
4 Wheel Drive Shift-On-The-Fly Not Disengaging
Northernpathy replied to Northeaster's topic in 96-2004 R50 Pathfinders
Happens sometimes on my truck, usually after a lot of wheeling. I turn the dial, but the lighted diagram in the dash indicating the status just blinks. Once it took 2-3 minutes before it finally went back into 2x4 (but that only happened once). Last wheeling trip in December it only took moving forward 10 feet or so for it to go back into 2x4. I just do like everyone else and just move forward and reverse 10-15 feet and it usually clicks back in. Might have something to do with the gears getting stuck and not wanting to fully disengage. Don't forget that it is a 10+ year old truck, so it will have its issues. Only other thing I could suggest is to do a transmission servicing (if you haven't already done it). Dump out all the fluid and change the transmission filter. Might be a tranny issue. After that the only thing you can do is to bring it to Nissan so that they can plug their fancy computer into it to see if something comes up. -
Jackson Autosport's R50 Missing Link
Northernpathy replied to tekazgtr1984's topic in 96-2004 R50 Pathfinders
Very true. I had a piece of steel and went under the truck on the weekend to see if I could make my own link and thought to myself "wow, that would be a great place to mount a skid plate to protect the oil pan with". At the very least, it could be used as a brace under a skid plate to make things even stronger. -
The original pumps have two connections. One is for the fluid, and the second is to pull air back into the pump when not in use.
Trail Gear Rock Sliders on R50
Northernpathy replied to SilverPath's topic in Solid Axle Swaps, Hardcore Custom Fab
Well if you are unsure, you could always buy a set and send them to me for testing. I will be sure to send you a full report afterwards! -
Been looking at picking up a set myself. If shipping up north is reasonable. It is pretty much cheaper to buy them them to make them myself. Took some measurements on my truck and it looks like it would be the 67" ones that would fit. -
finally got my lift and tires on
Northernpathy replied to pathyboy12's topic in 96-2004 R50 Pathfinders
Good looking rig. Those tires do sit well on it. -
alternative front and rear bumper mods
Northernpathy replied to haascncvf2's topic in 90-95 WD21 Pathfinders
I have to agree 132% here. Back in the day they use to make "real" bumpers out of metal. Now-a-days they are all made out of either plastic or very thin sheet metal, which won't even survive a hit by the neighbors poodle! -
If possible, I would try and either buy a quick connect/disconnect kit, or get one fabbed. Would save you a lot of time and effort. But if not, then just do what nunya said and use zip ties. I have a huge pack in the truck at all times and they always come in useful for things like this. Plus they are cheap at like 1-5 cents each, so it isn't going to break the bank Then there is always duct-tape. But that might be too getto for your rig
