adamzan
Moderator
Everything posted by adamzan
  1. I think I will just leave well enough alone. I don't have the time right now to do anything about it and I drive 95 percent in the day anyways now, if I even drive at all. But holy hell are the stock wires ever THIN.
  2. I wasn't looking to relay the lights I just wanted to know if wiring both high and low together would burn my truck down. I got my answer.......
  3. adamzan
    _____
    Are those the plastic ramp things? I see those at Canadian tire, TSC and princess auto. I don't know if i'd trust driving my truck up onto them :S
  4. I had this same problem a while back. Changing my fuel filter solved it.
  5. When I took it off, it had a few cracks when you bent it on the top but the teeth were fine.... The socket is a 27mm btw
  6. I changed my tbelt at 240k km. Guess I'm lucky
  7. Even with the 3+3 you will need to trim the fenders, if you go with the 33's. Hey Simon, when he's done his truck will probably look exactly like yours!
  8. mine is annoying, as you can see the tank isn't "empty" yet. The light will glow in and out. And once it gets onto the E and below, it'll go steady....Annoying at night!
  9. Alright thanks for the suggestions. As it stands right now, my DRL's are my high beams, and someone has run a wire from the drivers side to the passenger side, as when I unhooked it, my passenger DRL went out. I guess the module is fried and someone was too cheap/lazy/dumb to fix it. Might also be why my high beams suck... I will probably just put my lights on.
  10. Crappy pic, but if anyone had doubts....It took 65 liters when i filled it like 5km later
  11. Couldn't hurt to have it flushed anyways. I had mine flushed b/c it was brown, yet the shop said all fluids were "Good" and it shifted SO much better.
  12. The low beams on my pathy work awesome, the high beams, while better than my friends cars by far, still leave a lot to be desired. I noticed that if you hold the headlamp switch half way, that you can have low and high beams on at the same time. That really helped me see better. So my question is, could I wire some kind of switch, so that I could flick it into that mode? Would that cause the wiring to overheat unless I rewire with thicker wire?
  13. Also the ATF should be pinkish on the dipstick and smell sweet not burnt. I smelled a bottle of fresh ATF for comparison on mine when I wasn't sure.
  14. Yeah, there is one part of it, that is a bug screen that clips over the grille, and then the winter front part is a cover that blocks the grille it pops on with buttons, like on a thin jacket. There are 2 vents that can be opened and closed like little gates, they're sealed with Velcro...
  15. You could try checking the junkyards to see if anyone left their winter front on the truck. I have one on both my trucks, the 93 came with one and the 95 I got it from a JY for free, in mint condition too!
  16. http://consumerguideauto.howstuffworks.com...athfinder-6.htm I know it says 90-95 but maybe it's the same problem rearing it's ugly head again...
  17. Wow, looks like at least one owner actually cleaned their frame regularly.
  18. Only in Quebec. I heard on the radio yesterday about an accident that the guy on the radio's wife was in. He said that all 4 vehicles in the crash had winter tires on....I'm driving on bfg long trails... They are fine in the snow and are an all season tire. Winter tires do not compensate for stupidity and lack of driving skills!
  19. The most I've ever put in was 70 liters, or 18.5 gallons...The light was on at that point.
  20. Nice truck. Did it come with that npora sticker on the back?
  21. There was a post around somewhere saying if the trans doesn't shift properly before warmed up it means the wrong (I.e. not nissan) fluid is being used.
  22. mine 93 and 95 do. It glows in and out when its low ish and when it gets onto the E it stays on. At least it does in my truck. (At one point this year I couldn't afford to put 10 dollars in it)
  23. Dealer or junkyard is the best place for this item. In my experience at least, most of the parts stores only carried the bushings.... If you go to a junkyard either have them pull it or bring a breaker bar.
  24. I believe it's the Nissan-matc C fluid or something. I think its just so your tranny doesn't shift rough when it's warming up. I have regular dexron III in my truck and it's rough when cold but fine otherwise.
