221
Everything posted by adamzan
Re-Filling The Transfercase...without Making A Huge Mess?
adamzan replied to kcpath's topic in The Garage
The guy who did mine had a bottle with a piece of tubing hose clamped to the end of it. Worked great. -
They are on opposite sides in the r50. Alternator is on passenger side and the ps pump is on the drivers side.
Have you checked your MAF sensor? You know how the wiring can be wiggled and it will work right again. Mine would go up and down then stall sometimes. I don't think it is only for cali vehicles as I have gotten it on my 95 XE here in canada. I think I remember you telling me the procedures for testing it. I had the catalytic converter replaced and it hasn't come back since. It used to come on every few months but it hasn't in a long time now since the replacement.
I know the 94-95 wd21s with the 31" package came with general tires. The parts truck judge had with the original tires (only 60,000kms on the truck) had general grabbers on it with an ancient date code. Mine has a 235/75/15 general ameritrac spare and I've seen several of these tires in the JY in the back of XE pathys. Also my 93 SE and 95 SE have bridgestone dessert dueler or something spares. Going on that, my assumption is bridgestone/firestone and general tire...
Plus the filter is smaller but I don't hear about people having many problems with the VG33
Oil pan gasket? You recently did your tranny right? I remember reading somewhere that if the motor is not supported that it could damage the oil pan or something.
3.5L V6 Nissan Power Adds - Best Practices?
adamzan replied to Oregonian's topic in 96-2004 R50 Pathfinders
Take an 87-2000 VG powered pathy for a test drive and you will never complain about power again LOL. Kidding aside there really is no specific performance parts for the r50s which sucks! -
X2 I did this to 4x4pathy94's truck and now it starts everytime instead of click click click, wait a few mins, click click START.
I would go for it.
Neither of my 95's have an airbag.
Just so you know what kingman is talking about, these are the tension rod bushings. Also known as compression rod. Same thing.
Excessive Rear End Shimmy And Movement
adamzan replied to RustyButTrusty's topic in 86.5-89 WD21 Pathfinders
Not sure about local stores but rockauto has them and 4x4parts.com has the polyurethane ones which are much better but cost more. -
At that many miles I would replace the upper and lower link bushings as well as the panhard rod bushings. I did it to my pathy at 170k miles and it really tightened things up. -
If it was code 13 (the other way around) engine coolant temp sensor, that could also cause it to put WAY too much fuel in.
Injectors? I don't really know how the tbi works but I do know it has 2 injectors.
I had a severely worn lower ball joint on my drivers side and it amplified the shimmy. It was so bad you could move it up and down easily in the socket.
You are probably right. Just for the record I bought 3 of mine in august 09 (two uppers one lower) and one lower in may 09. They were all either moog or TRW, I can't remember. It's been 9 months now and my ball joints are still nice and tight. I've put about 15,000kms on the truck since then and I have gone on 4 or 5 wheeling trips. Plus the random playing in the snow. Given the quality of our roads here I am surprised they lasted this long! My drivers side outer TRE is pretty loose right now though...
You know, I bought new ball joints for my dads r50, and they were the lifetime warranty TRW ones from partsource, no zerks either. Even the oem lowers on his truck (that were only slightly worn at 240,000kms) didn't have them. The new ones I bought for my wd21 the lowers had no zerks but the uppers did and they were all the same brand
I think he was just saying that the ones without the grease fittings tend to be the cheaper ones, while the higher quality ones, like moog, have grease fittings.
They are full of @!*% some dealers just don't want to do it. Bring it to another one. I'm lucky the first dealer I went to said it was covered.
I found if the alignment is not PERFECT it will cause the truck to shimmy at random times.
I paid 1200 even to have my entire system replaced...It was the damn Y pipes that cost the most.
Just snug up all those hose clamps on the fuel rail. Takes you 5 minutes. I did that to my pathy when I first got it just to prevent this issue. Some were getting loose.
I used the same stuff when I was broke. It held up for about 2 weeks. For that summer I just kept reapplying it every 2 weeks
The only time I ever smelled brakes was when my friend was driving the @!*% out of his old gmc sierra and would accelerate and stop very hard. Are you hard on your brakes?
