adamzan
Moderator
Everything posted by adamzan
  1. I had the higher end NGK's in my pathy and when I changed them to the factory V-power ones because they were on sale I noticed absolutely no difference...Other than the fact that the higher end ones may last longer. But I'd go with what the manual says.
  2. Good point. Didn't know how many km's were on them. Does this frame look bent to you. Maybe that is why my pathy drives like @!*%. Never noticed it in 4 years...
  3. Sounds like something is rubbing against the brake rotor. Pull the tire off and see what's there.
  4. May as well replace them if you're pulling them. I made mine jealous as I contacted 4x4pathy94 asking how much he wanted for his. I am tired of dealing with mine.
  5. Autolites are cheap garbage plugs. Put the NGK ones in (factory plugs) and I am willing to bet it runs fine.
  6. Wow you sounded like a total douchebag (tungsten). Good work ak9849cy Another example of the bracing would be for the factory spare tire carrier.
  7. Sounds like either bad connections or a dead battery. When mine died I got nothing, except the clock that is on the dash, that was the only thing that was working.
  8. Actually it wasn't the windshield it was where the plastic clip things that hold the screws for the trim go. The water dribbled into there and would cause me all sorts of grief. It started right after the new windshield was installed, the shop fixed it no questions asked.
  9. adamzan
    V-Belts
    Maybe it is too tight.
  10. adamzan
    V-Belts
    What the hell are you doing to wear out the belts so fast. Are your pulleys misaligned or something. I still have the belts I put on the truck 4 years ago and they are fine.
  11. I had the same problem with the speed sensor it turned out to be a leak in the windshield messing up the wiring but it had the same symptoms, the truck would be humming along fine, then the cruise would stop and blink, and I'd get a CEL. Maybe you have a loose connection under there.
  12. If you don't keep up on greasing things, or buy cheap parts, or live in the salt belt, these all can add up to faster wear.
  13. Mine doesn't have one, and I do not have any alternator whine through the stereo.
  14. The idea behind the non powered deck was to use the amps for power...
  15. The r50 pulley is different from the wd21 pulley. The r50 one only has 2 holes.
  16. Working fine for me on Ubuntu.
  17. haynes manual makes good toilet paper if you get stuck out in the bush.
  18. Where can I get those pathfinder stickers for the windows? Whoever tinted my windows in the past must have removed them (idiots).
  19. I used a set of these for various things on my rig, they've worked well so far.
  20. Cody, maybe I can check my pin 16 and see if it is the same, if it is that would rule out another item.
  21. Here is the radio wire colors: Uploaded with ImageShack.us
  22. This^^^ I am willing to bet someone put the wrong fluid in or didn't fill it up all the way, it happens all the time. When I took my dads to get the oils change I took it to 3 different places before I found one that knew what I was talking about when I said gl5=death.
  23. Yeah check the vacuum hose, though, when mine leaked, it would just not hold higher speeds. Like, you'd set it to 110 and it would slowly lose speed then the computer would drop it out of overdrive and still go no where lol.
  24. Probably could, and that is retarded that rock auto sells only 15 gallon tanks. I know mine is 21 because I drove from Kitchener to ottawa one time with a flaky o2 sensor and when I got home it took 78 liters which is 20.6 gallons. Scary!
