KovemaN
6
Everything posted by KovemaN
Nissan Pathfinder $1.85 million lawsuit verdict will stand
KovemaN replied to Pezzy's topic in General Forums
This is what happens to a 1992 WD21 Pathfinder when it runs into the side of a Suburban at 40mph. I had a bruise from my seatbelt. I sued the driver that ran the stop sign. My guess is that this c@nt couldn't get any ca$h from the un-insured driver that hit her so her lawyer went after Nissan. My truck saved my life so I bought another. -
The link I posted goes straight to the headers that you need.
I've found them on ebay for as little as $40, but if you have to buy one new it should be around $100.
I think that Thorley is your only option. Thorley Headers - 4x4parts.com They will give you more power and IMO, better sound. The VG30 sounds really nice with headers and a decent muffler. If you have broken exhaust studs you may also have a warped manifold. That is what leads most Pathfinder owners to install headers. I actually have a set for my current Pathy. I am going to install them when I fix my broken exhaust studs.
I have had a Delta 50 on a VG30 Pathy. I liked it so much I bought another for my current build. It was a very good balance between sound and comfort. I have a Super 44 on my D21 pickup and it can get a little annoying on the highway. Luckily it doesn't see the highway much. I would recommend that you spend the extra $ on the Delta 50 if you're worried about the exhaust being loud. If you really want to save money, there are a couple of 40 series copies (v-force, flowpro, thrush) out there for less than $70. I haven't found a Delta 50 copy since the design is still patented. The only problem that I had with the 50 is that I couldn't keep my foot off of the skinny pedal.
I guess that depends on how far it is to the nearest puddle.
Discount Tire sells the exact same wheels under their Unique brand. They list for $59, but they will match prices in most cases. Summit definately has the best deal on the black steelies. I like these too: Black Rock 909
If you did it again, what would you do?
KovemaN replied to BonnerBB's topic in 90-95 WD21 Pathfinders
Cranked or aftermarket T-bars, rear lift springs, longer rear shocks and ditch the rear sway bar. UCAs if you can't get the front aligned. -
I built the cups from bearing races and big a$$ washers. The bushings are from Energy Suspension. I think I special ordered them through Vatozone.
I thought California was the mecca for users of Where's Beavis?
I just used a 24" x 1/2" breaker. Are you sure you're turning it the right way?
Correction: Lower BALL JOINTS are the devil.
If they arent' worn out, it's not worth it. The hard part is dropping the t-bars and getting the bolts out. To remove the bushing from the frame might be a pain too. If the whole thing won't slide out then you will have to burn out the inner sleeve and take a saw to the outer sleeve. If it's worn out, the inner sleeve should just drop out then you can take a sawzall to the rubber and outer sleeve (from the inside). Once you have cut through the sleeve it will be easy to hammer out with a chisel or punch. That is the method I had to use to replace the leaf spring bushings on my D21.
I had a problem with the lights on my 92. The connector had deteriorated and the pins were loose. I found replacement connector pigtails at Wal-Mart for a couple of bucks. After replacing the connectors I never had a problem again.
Before 1990, the V6 D21s and Pathfinders had 27 spline hubs. 1990 and later had 28 spline hubs. I couldn't say for sure whether the ebay hubs would fit.
Maybe I misunderstood. The black plastic things I'm talking about would be under the center caps of most wheels.
Nope. Those plastic things are for wheels that are balanced as "hub centric". Simply put, that means that the wheel is centered by the hub and not by the lugs. The dynamic balancer is a fluid filled ring that automatically balances the wheel using centrifugal force. The dynamic balancers are good for big off-road tires and they can make that plastic ring obsolete. Most tire shops don't know the difference and they might never balance your wheels correctly.
How to replace the plastic snap connectors in your door locks
KovemaN replied to beastpath's topic in The Garage
I was at the Nissan parts counter the other day and picked up two sets. The guy there didn't even need the part number. He knew exactly what I was talking about. It's one of the few things that fails on every older Nissan. I think there needs to be a how-to section to pin this stuff in. -
I just used a bunch of that grease yesterday on the seal for my swimming pool pump. It's the same stuff as most marine lube applications. The tube I have is called Magic Lube. It's way cheaper than buying the Energy Suspension stuff. I use it on all of my suspension bushings and it really keeps the urethane quiet. Totally nasty to clean up though.
People are trashing them because they can get free cash from the tax paying public. They are trading in their perfectly good Pathy so they can get $4500 for a car that only gets 4mpg better mileage or $3500 for 2mpg. It's free money for people that want to buy a car, but have no reason to scrap a reliable vehicle. Anyone driving a real clunker can't get financing anyway. What self respecting politician would be caught driving a vehicle that's worth less than $4500? Where's the "Cash for my dinner table" program? Or how about "Cash for SAS" or "Cash for Kegs"? F-it. I'm starting a new thread for people to list what they would do with $4500 in free money.
Remote Keyless Door Entry Transmitter Sender Units
KovemaN replied to DoctorBill's topic in 90-95 WD21 Pathfinders
If it says "Pathfinder" on it and looks like the picture below, it is a WD21 keyless remote. As far as I know, no other Nissan keyless remotes will work with this system. I bought my remotes used and programmed them to work with my truck. As long as it's not broken, it can be programmed to the vehicle. -
Using the interlock switch you can also drive the truck a short distance with the starter motor. Emergency situations only of course.
I've got good drill bits and extractors. I could give you a hand this weekend if you want. PM me or give me a call.
The OEM mounting kit used riv-nuts. Self tapping screws should do the trick though. If you are worried about it, pull the headliner and install t-nuts from the inside. The screws holding the rails to the roof strip very easily. You might want to take a cordless drill in case you have to take the heads off of the screws.
Returned from automotive coma - IT IS ALIVE!
KovemaN replied to darkflounder's topic in General Forums
Excellent news. One more back from the dead. Pictures would be good.
