89_trailboss
Everything posted by 89_trailboss
  1. another one for the lucas. put it the trans of 94 and it smothed it out quite well.
  2. holy @!*%!!!! do you know if theres any tire places in Winnipeg or even western ont that sells them?
  3. chalk one more down for the path!!!
  4. now go get stuck!!!!!! Im in need of a winch, and tires. really want to hear how that winch works with the path half burried in mud. Costco by me has the 9500lbs ones in now too. for 450. wonder if it would be worth the extra??? those are 31" crawls, right?
  5. luve the mud finder one!!! gona go run out this weekend and get some cut!!! as for the font, why dont you just find one that is "boxy" like the OEM one, and just cut the lil parts of the B and the R of pathfindeR out, like the oem ones? know what I mean.
  6. what are the measurements? just ruffly looks great by the way!!!
  7. go with 31. you WILL kick yourself later on for only going with 30.
  8. sry, gettin used to the rears now that ive done them so many times , but at either rate its not that hard.
  9. hey runnerman, we gota do some wheelin together!!!! and you powder coat your skids, correct? think youd be interested in doing a set of rims for me? how much do you think it will cost? there 15" for my path.
  10. hmm. I just dont see the point in spending soo much time and money jsut so you can say its yours, and still be left with an almost stock truck. back on topic, There was a set of carpet that just went on ebay a month ago or so. you could check the JY and hope you can find a decent set and clean em up good. Husky makes some floor mat's that are HUGE!!! somthing like 3 or 4" deap. kinda like walls I guess and I belive they are formed too. there was a discussion on these just a while back on AC. main part sources I have found are: 4x4parts.com Calimin L&P performance then theres your local dealer and parts stores.
  11. take the 2 bolts holding the calipars on and just pull the rotors off. slide the new ones on. its THAT easy. ya, flushing is just like bleeding. just keep bleeding till all the fluid is out.
  12. umm... $5000+? why dont you just by one from down south and drive it back up? be alot better shape.
  13. great thanks I searched ford filter but obviously it came up with nothin. Thanks again!!!
  14. Hey guys. time to do an oil change and I remembered seeing a post a while back by 88 saying you can use a ford oil filter in place of the stock one which will give you a bit more capacity. anyone know the model/year of fords or better yet the Fram PN? thanks guys
  15. the rust under the seat is a PITA. but you have almost nothing. My seat belts were just hanging in the air and I just pushed the back of the seat a bit and it ripped right out. NOT FUN TO FIX!!!! also check the floor boards too. mine looked fine under neath the truck cause it was under coated, and with the carpet off it looked fine b/c of the sound deadener. once I riped the SD out, DAMN BIG HOLES!!!! you can fix it if you have a welder, and time. LOTS of time
  16. haha. no. it is in the same spot the VGE air box is
  17. HAHA, That is NOTHING!!! I had to cut my whole passanger rocker out and the front passanger fender is lookin for a new home in the dump. best bet it so cut around the rust and weld new stuff on.
  18. Ive come up with a intake for my TBI. used some 3" ABS. still have a few things to figure out but it does have a tight seal and a cheap cone filter(wasnt gona spend big money on a K&N till I knew this would work). I will see if I can fix my camera and get the pics off
  19. hey duffman, how did your truck drive with 33's and only a SL? how much trimming did you have to do? gonna have to soak that colomn with WD40 or pbblaster for a while.
  20. If it was for my path, yes. I would make some sort of sheald/gaurd. but its for my dads and it proply wont see too much, if any offroading...
  21. awsome!!! thank you guys very much.
  22. hey guys, Im looking for Mr. Jims How-to to install the K&N filter on the VG30E. I cant find it for hte life of me. Can anyone post a link? Thanks.
  23. unless its unlocked then yes, its 100% locked.
