nissandoms47
Everything posted by nissandoms47
pm me for a CAD picture of the strut spacer.
Just finished my AC lift - topping out question...
nissandoms47 replied to willray80's topic in 96-2004 R50 Pathfinders
well i have no sway bars, and i do moderate speed offroading stuff, and its a world of difference with that shock, handles so much better on the road and everything. -
If that happened around here, that "ricer" would have had at least 5 cars chasing him down.
ha same here.
its not the ZJ its a WJ.
k, i dont know what to do with my car situation. Which is why i came to the fellow board members. I always suck at making decisions like this. I want something with a solid axle for sure. So Should i buy this 99 jeep grand cherokee limited with the 4.7 v8? It has a custom 4" long arm front and rear with 285/75/16 toyo MTs Nice interior, heated seats SICK system etc.. he wants $5k for it. Buy this 03 toyota 4runner. Ive always had a thing for the 4th gen 4runners and i found a black with tan interior for $8,600 with the 4.7 v8 Keep my r50 and deal with being ifs forever or try and sas it. But the r50s size has always bugged me. The jeep and 4runner are wider inside and longer.
The first gen Q45 had the RE4R03A tranny. Its similar but bigger everything.
if i wanted something that everyone else has id go buy a new JK, if i wanted something unique, ill stick with my r50. Whats the point of going to a dealer and buying an off the lot car that will do whatever you want it to for 40k when you could buy an r50 and do what you want to do it and see you build it over time and have a ton of fun.
each control arm has 2 sides to it so you would need a total of 4 bushings.
the pop could be your shock not being tight enough. Bushings starting to wear from age. anything.
VH45 Swap & SAS Update (Merged Threads)
nissandoms47 replied to tmorgan4's topic in Solid Axle Swaps, Hardcore Custom Fab
Im pretty sure those are sway a way coilovers. but thats badass tyler. -
Ha,you guys should go drive an audi in the snow.
You dont need the entire center console just the trim that houses the boots for the shifters. It'll snap right in place of the auto one. You might also wanna get the floor pan rubber boots and stuff that goes under the console.
For reference.... The factory camber should be between 0 degrees and 1.0 degrees positive or negative. more then that and its not good. You could even adjust it yourself. I do it all the time and my tires wear even. I still haven't gotten an alignment since i put my lift on and it wears even and drive straight.
like i said in my message, the shop should know what the factory camber spec is. You dont go to an alignment shop with measurements telling them what you want unless its specific. All you need is the toe adjusted and the camber to factory specs. The shop should have this in their alignment computer.
What dean said ive had that happen a lot on my x but never on my older r50. On my new r50 i didnt use the black studs because really i think theres no point. I had just as much thread as the pic you showed andres for the washer and nut. The studs provided with the warns are for the xterras and older pathys and stuff like that where they dont have studs and drive flanges like the r50. i kept the black studs in my toolbox just incase one ever snaps out on the trail or whatever. its nice to have spares and stuff like that.
VQs take the double platinum NGK plugs. Try those and see what happens.
Cigarette lighter socket not working
nissandoms47 replied to daopi's topic in 96-2004 R50 Pathfinders
replace the fuse anyways. then try it -
Yeah the tx10 tcase will both up to the VH45DEs RE4R03A auto trans. You just need a custom output shaft and the adapter plate to go from the back of the automatic to the front of the tcase. Ive got a RE4R03A v8 4x4 trans with the tx10 sitting in my garage lol. That and the vh45 was going to go into my x, but then i didnt swap it and it all just sat, i sold the engines but still have that tranny, then i bought a VQ pathy a while after which has more then enough power so i dont even care anymore lol.
My lift is Half Done, And thats all that I can do
nissandoms47 replied to 01silvapathy's topic in 96-2004 R50 Pathfinders
You got the extended shocks right andrew? 29-30 inches extended? It would suck if you had to buy new shocks again haha. And i hate how you have no snow... -
Yah you have no idea how hard it is doing things with 1 hand while the other one is all fskced. Its so nasty looking when i look at it close haha. Cuz i like never ever get serious injuries.
ya thats antibiotic ointment on there not any other fluid haha just to let you guys know. Pretty much like neosporin.
ya the scar will look like an upside down 2 with a curve at the bottom of the 2. haha
Cuz its been neglected lol. SES light on for 80k? damn
control arm bushings will fix the death wobble. Its not the tranny or diff. Radio, you're screwed but thats a common problem. Get aftermarket windows, try replacing your master switches on the drivers door. the turn signal problem can be a bad stalk on the steering column engine problems, sounds like a bad mass air flow sensor which could also be why it shuts off at lights check the fuse for the clock. or the clock unit could just be dead. replace that. How many miles on this? any service engine soon lights?
