nissandoms47
Everything posted by nissandoms47
  1. the hand is healing. I rewrapped the whole thing last night not just the coban and i'll have a sick scar lol. They had to cut more skin to go find the tendon. I'll take a pic if a rewrap in soon. Its hard typing with 8 fingers lol. Speaking of hydrolocking heres the xterra pictures from the 3 ft deep river in moab lol. aftermath AFTER driving home after changing the oil and getting all the water out. 3 bent rods, 1 shattered piston skirt and i drove home like that. The engine had so low miles i replaced the broken parts and i still have that engine running great in the xterra today. When it hydrolocked i replaced the cams with some 89 300zx cams for a little improvement in power. Not much though.
  2. I didnt know they ever made a VH40, its more like the VQ40. They made a VH41 and a VH45, VK45, VK50, VK56. None of which will bolt up to any VG trans.Your best option for a huge power increase would be a VQ35 or a VQ40. I guarntee if you use a VQ35 out of an r50 and use the wd21 engine mounts it would be a very close bolt on. The drivetrain is about the same length as the vg drivetrain so you still have room for a fan, rad, accessories, ac condenser, etc..
  3. epic fail? okay, VQ35de is not. you need to drive one to understand.
  4. Just got home from the hospital. The surgery went well and i have a follow up visit in about a week. they have just a splint on just the finger now and not clear up to my elbow so i can use all fingers but my index. so i shhould be able to start getting some work done (lifts) but it'll be slower obviously. i hav to keep this splint on for 2 weeks then therapy. but it should be too hard to just move my finger up and down once its healed lol. typing is still hard lol.
  5. Well i know there are 2 qx4s in the yunkyard here with the complete hvac system. maybe ill take the dash apart and see what all you need to make a swap.
  6. i have the digital climate control and swapping from the manual to digital will require everything from a path/qx4 with one. ive already looked into it and its really not worth it unless you can get all the parts for super cheap.
  7. the whole clutch system in the tcase is for the auto setting on the switch. also the tcase has a secondary oil pump. you should be fine as long as you dont use auto with the hubs unlocked.
  8. it cut thru my skin, the tendon and some @!*% under that. its a semi circle cut but 3/4s of the way around. i guess i sgoulda wore gloves but its one of those things where its like wtf??? good thing im left handed this wont stop any production of the lifts. im still waiting on the guy to cut those flanges and send them to me. his engineer is out and theyre busy.but its nothing hard to do for him. he had to make a CAD and all that.
  9. it was actually a coolant tube on an isuzu. tbelt job and i was trying to pry on the crank pulley and the thing i was prying with slipped and that dull coolant tube cut me right open. wanna see pics? lol
  10. i gotcha. i just injured my hand big time. cut it trhu the tendon and everything. so i guess ill see how good i am at one handed welding.
  11. K guys. Question for you guys. Depending on how the next week or so goes the price on building these lifts might go down a good bit. But I want your feedback. What would YOU guys pay for a 4" SFD??? Just the SFD, no new struts, AC coils, rear extended shocks. Just the brackets and spacers and steering extension etc. I want to be able to offer this at a price that everyone can afford but not so cheap that im just doing it for free. I also what your constructive criticism. but not too constructive lol. Feel free to send me a PM too. also tell me what other products you guys want that could possibly be built. Dont say things like bolt on SAS cuz thats not possible lol. Ive even thought of it.
  12. I think its the 21.1 gal. Ive hard that go around more then a few times.
  13. Just some 1/4" x2" strap welded to the bottom of the frame most likely. Nothing too difficult but ive never seen something like that on an r50. Personally I really need it down here since im always up in the rocks.
  14. I am not going to lie though, I wish nissan designed some of the other trucks like they do the newer ones. With coilovers in the front. The r50 is for sure unique though.
  15. Its about 1/4"-1/2" back from the mating line. It is still on the flat part of the bellhousing, about one inch wide, before it starts to cone in if that makes sense.
  16. Just to make it more clear, its located on the transmission bellhousing itself. I got to mine via the top of the engine and the bottom. When i did a tranny swap I actually ripped out the wires so it was a bigger pain but it can be done. I went through the top to disconnect the plug that was still on the back then I went in through the bottom with a 10 mm wrench to loosen and take out the sensor. I was able to take it out from the bottom if i remember correctly. You could try jacking the back of the trans all the way up and then going through the engine bay again. The same for letting the trans droop all the way.
  17. To clear the strut. wheels are 200 for the black steelies for a set of 4.
  18. I'll be the one to ask the question of what did you hit? Or what hit you?
  19. That might be too wide for stock wheels., but you can always try one and see.
  20. Nope, my 96 was an automatic and my 02 is a manual. No problems with the different drivetrain. This will work on VG and VQ series with auto/manual trans. The company cutting all the pieces i need for the lifts will be doing that tomorrow then ill get that shipment and then ill be delivering lifts. Right now im actually working on a secondary shock setup for the front. When im done with my suspension i'll probably be running a custom lower control arm, modified strut spacer and a longer axle for more travel which means ill also need to figure something out for steering. I'll be running the stock strut setup, and bilstein 7100 series shocks on the front and rear. 6" travel front and 12-14" travel in the rear depending on if i decided to replace my rear control arms with custom units. After that ill be working on putting air bumpstops in the front and rear to make those landings a little smoother. And im also working on a way to reinforce the strut body, ive bent struts in the past. oh and some of you guys might think this is cool. uniframe skids, for when just sliders arnt enough...
