All Activity
- Today
ThatOneNissanGuy changed their profile photo
- Yesterday
SAS'd on portals! That thing isn't messing around.
LOL, Kamchatka is in a galaxy. far, far away. Nice ride for your conditions! I wish mine was a diesel.
peejay76 replied to gamellott's topic in 90-95 WD21 Pathfinders
Sorry about the late response! I think the leak is gone, or was never leaking from the valve covers to begin with. The gaskets were installed round-side down. I have to do them on my D22 pretty soon, I'll try to give more info then! - Last week
Ermak started following In a galaxy far, far away...
https://imagizer.imageshack.com/img921/9211/GzWVNS.jpg https://imagizer.imageshack.com/img923/2815/4WG976.jpg https://imagizer.imageshack.com/img923/8076/Ttayb6.jpg https://imagizer.imageshack.com/img922/3552/AQg7Ko.jpg https://imagizer.imageshack.com/img924/6560/hUsYgQ.jpg
DWB joined the community
04R50P joined the community
Long trip with 2“ lift - Will i get CV-Issues?
FirstGenFreak replied to Nils's topic in R50 FAQ's & Pinned Topics
I've had 2.5" lift, with the same CV shafts for nearly 20 years, although I am talking about a WD21 with manual hubs, so there is only load when you lock the hubs. Plenty of sand, plenty of tough Vic High Country Trips etc. Easy to overthink it, I'd bet you will be fine, for peace of mind you could fit manual hubs, or take a spare set of CVs. -
yerukalapudi joined the community
rivenroche replied to Nils's topic in R50 FAQ's & Pinned Topics
A 2" lift by itself isn't automatically a deal breaker, but the condition of the CVs and the overall front-end setup matters more than the lift height when you're planning 17,000 km through remote areas. Since you'll be far from parts and repair shops, replacing any questionable CVs before leaving is probably the safer investment than hoping they'll last. Manual hubs are also worth considering because they reduce wear on the front driveline during normal driving, which several owners have had good results with. Before heading out, it would also be smart to inspect the boots, check alignment, and make sure the suspension isn't topping out. While planning a long-distance road trip, transportation logistics can matter too. Peacock Rentals offers premium vehicle rentals across several U.S. locations for people who need dependable transportation during extended travel or while their own vehicle is being serviced, so having a backup plan is never a bad idea if unexpected repairs come up. With fresh CVs, manual hubs, and everything inspected beforehand, a well-maintained Pathfinder with a 2" lift has a much better chance of completing that trip without major issues. The key is making the weak points as reliable as possible before you head into the outback. -
rivenroche joined the community
Looks like this topic isn't the duplicate one. Because I'm a nerd, I tabled all the FSM data for Pathfinders, Frontiers, Xterras, and others long ago. 4.363 standard cuts were found in: 00-01 Xterra XE 00.5 Frontier XE 01 Frontier SC But now, are you going to a 4.363 from a 4.636 or 4.90 for fuel economy or something? Or did you go with smaller tires? Technically, you could find 4.375 from older Frontiers, Hardbodies, and Pathfinders if you feel like setting up gears or maybe swapping the R200A (not sure if they bolt up the same...I imagine they do, and maybe it's as easy as swapping the stub shafts from your R200A to keep the same 3x2 6-bolt pattern vs. 5x1 5-bolt pattern CVs). The ratio difference is negligible.
Looking for a source for a standard cut 4.363 gears for a low pinion R200A diff. So far I've only determined that these were in 2001 supercharged frontiers. Does anyone know of other vehicles that I might be able to source these from? Also looking for the same if there are any related differentials (C200) that has interchangeable gears with a low pinion R200A. I'm trying to regear my 2004 Xterra with a H233B rear and R200A front. I got the rear already from a (R50) 2000 Pathy and I also harvested the front diff too. Unfortunately. I just found out the R50 R200A diff is a high pinion, reverse cut gear variant of the low pinion R200A that is in all other R200A variants. If anyone needs it, I am in NW Ohio.
- Earlier
alx_auto joined the community
Nithish joined the community
Hi guys, I have a 1993 nissan pathfinder 4x4 se with 218000 miles on it. For a while now, it hasn't been driving the best, so I've replaced the air filter, done an oil change, cleaned the maf, changed the o2 sensor (found it through the codes), and just today changed the fuel filter. The car was running about the same or maybe a little better and the codes went away, but recently, maybe less than a week ago, it will randomly get super shaky (always been kinda shaky) and does not want to accelerate. It is loud and the car gets way shakier and struggles to gain speed but it kinda goes away once the rpms go up. It will stay for a few minutes and then randomly go away and become smooth again. I think I might try to get a video of this tomorrow and would really appreciate any advice. I know there's some other forums on here about this problem but most seem like it's a permanent problem and isn't coming and going like mine is. I think I will clean the throttle body and check the distributor tomorrow, but a mechanic should have replaced plugs and distibutor when it was takin in due to stalling issues about a year and a half ago. One last thing is, I could have sworn it's been happening more with the ac running since it's been hot here. Thanks a lot.
Bernie7044 joined the community
I have an old 2003 se that I bought brand new and am going to be trying to restore it after a lot of neglect (mostly the exterior, although there is a persistent p1456 code and not being able to put it in gear without a screwdriver in the gear shift assembly) Anyways, where are some good places to find oem parts? I know about Z1 but what else is there? I need new front windshield moulding and the auto glass place I went to had a hard time finding replacements. The top of my dash has a crack in it and if possible Id like to get a replacement put in. I guess could go to a junkyard bur how difficult is it to remove a dash or windshields if you’ve never done it before?
Hi members am having having a problem sourcing TD27 ETi can I just use TD27 in my LR50
I’ve been wanting to lift my r50 and I want to buy a 1.5 inch strut spacer BUT I wanna know if it’s safe on the CVs and steering rods, and recommended brands
I’m not sure what problem i have but ik i have a couple of them on my 95 pathy. My temp gauge isn’t reading anything and it would randomly work on day and another day it wouldnt. but most of the time it’s not even working. another thing is the fuel gauge, i really think it is reading wrong because it goes down to like half way after an hour of driving. and i pump gas every 4 to 5 days just regular driving i think i might be wasting a lot of gas im not sure. i still haven’t calculated how many mpg i get but so far today i filled it up to full and drove 82 miles and the gauge is already at half. Another thing is the ticking when it’s cold. i always thought it was a lifter problem or might be one. the mechanics said it was lifters and i see people on here saying it’s the exhaust manifold so im not sure. another thing is how loud the engine gets when it’s been running with the ac on and it sounds like an 18 wheeler just breathing lol. but if anyone can help me out it would be amazing. im playing a road trip in december and want to have everything “fixed” by then so i would have less worrys.
Hi Aaron95,
If you have not already, I recommend that you either create a new topic in the appropriate section for your issues and questions, or post in an existing topic that's previously covered the symptoms you're experiencing... we'll never berate a member for reviving an old topic!
Although the status update feature is nice for quick, simple, questions and, well, updates, you'll always get your best answers and feedback from proper posts and topics.
as the title says I have this weird surge feeling on decceleration in my 1995 wd21 autotragic, it seems to happen when the engine goes to idle after engine breaking and will do it almost right until full stop. my suspicion is that my tranny is trying to go to neutral and engine brake at the same time causing this fluctuation in rpm and almost clunking. the conditions for this happen when the car gets hot and fully heat soaked while its summer (didn't happen all winter or fall) and the longer the distance (possibly hotter the car?) it gets worse, I've owned it for about 3 years and it has never gone away or necessarily gotten worse. I understand I'm pretty piss poor at describing this problem and can get a video of it doing it if wanted. Thank you in advance
94 Pathfinder blowing out smoke and hesitating
adamzan replied to 94pathynewbie's topic in General Forums
It sounds like when installing the injector you may have torn the o-ring or the injector itself is faulty. It isn't that uncommon for the aftermarket ones to be DOA if you went that route. I've had better luck with used factory ones. -
adamzan replied to gamellott's topic in 90-95 WD21 Pathfinders
How did it go? -
Additionally- since the torsion bars are needing to be pulled, we are going to do boots and clips. I would like to change all the front mounting bolts over to SS as well. Are there any other wear components on the torsion bars that should be swapped while they're out? Should the rear adjustment bolts be swapped with all new hardware (locking nut, jam nuts, pivot)? The front bolt sizes according to AI are below: can anyone confirm these? The Main Large Bolt (1 per side): Thread Size: M12 x 1.25 (Fine Thread) Length: 35mm long Tool Size: 19mm socket/wrench The Smaller Side Bolts (2 per side): Thread Size: M10 x 1.25 (Fine Thread) Length: 25mm long Tool Size: 14mm socket/wrench
So like the title says! I recently bought a 94 pathfinder but I was told it was going to need some work! Short story - the car sat for 10+ years before being started up and also no gas was removed before starting. Myself not knowing any better, I did not question this and drove the car 20~ miles home. Fast forward, I was diagnosing a ecu code 51 (trying to) and assumed it to be a bad fuel injector. So I replaced said fuel injector, got the check engine light to turn off, but then the car started to run horribly after filling up the tank the next morning! Blowing out clouds of smoke, hesitating at stops, and backfiring from underneath the hood. I really hope I didn't destroy the engine by driving it home. Anyways, where should I even start? I have since then drained the old gas out and replaced it with new gas. As well as changed the spark plugs, fuel filter, PCV valve, and the oil. I also changed the spark plug wires because mine were coming apart every time I pulled one. OH AND I changed what I believed to be the faulty fuel injector but that didn't change anything. The smoke coming from the exhaust doesn't smell sweet at all, in fact it doesn't smell like anything and if I had to guess I would say it's water but something else is leading me to believe it's unburnt fuel but again, it has no smell so.... The car has never overheated on me and I haven't been able to drive it enough to know if it's losing coolant, plus it drives terribly right now. Thanks for any help professionals!
My RMS needs doing too! It used to be a slow leak. 1. No special tools needed AFAIK. You can get the '90 factory service manual from cardiagn.com. The AT section has step-by-step instructions for dropping the tranny (AT-124), and the EM section has the same for doing the rear main (EM-20). 2. The gasket in the aftermarket kits goes between the retainer plate (which holds the seal) and the back of the engine block. Unless you're going to try and fish the seal out without removing the retainer, you'll need the gasket as well. I think I've got the Fel-Pro kit on the shelf for mine, don't remember--and of course I can't vouch for it as I haven't installed it yet. 3. I assume you'll need the gaskets for the exhaust crossover as well. You may need hardware or more depending on how much the exhaust fights you on its way out. These also tend to break exhaust studs (holding the manifold to the head), though I don't know that having the trans out would make these any easier to access. I would check breather hoses and exhaust hangers while you're under there. Might as well change the fluid in the transfer case too. 4. The trans cooler is a good idea. There are a few old threads on here with size and type suggestions. I don't actually know what mine's rated for, I got it secondhand and it's not marked. I installed mine in series with the existing cooler in the rad, and also added a Magnefine external filter while I was at it. If you just drain and fill, you don't get the old fluid out of the torque converter, so I did a flush through the cooler lines instead. Take the lines off the existing cooler, put them in a bucket, run the engine until fluid stops coming out, add that much fresh fluid to the transmission, do it again, repeat until what comes out looks more or less like what goes in. The trans fluid level is a bit of a pain to set. It has to be warmed up when you check it. If you set it cold, it'll be too high once it warms up. Either measure what you take out and what you put in and make sure they're the same, or undershoot a little so you have room to top it up once it's warm and you can check it properly. I thought mine was underfilled, warmed it up, and had to drain a bit back out of it. The manual calls for Nissan-Matic D, which is still available. From what I've read, it's basically just Dexron III, so I used generic parts-store-brand Dex-Merc, which was cheap and available locally. 5. Torsion bars are also a pain to set up. If you have to drop the bars (and the service manual suggests you will), mark, measure, or at least take a picture of where the adjusters are set and how the bars are clocked vs the adjusters. Otherwise you'll be screwing around for a while trying to get your ride height back where it was. I used spray paint to mark the adjusters on a friend's S10 Blazer when we swapped the trans, and reassembly was as simple as matching up the paint marks. This thread recommends filling the gap between the RMS retainer and the pan with silicone to stop mud from getting in there and causing corrosion. Seems like a good idea. Good luck!
A quick short I did on what needs to be swapped
micah3639 started following Rear Main Seal Replacement
Hello Nissan Pathfinder Community! I am the proud 4th owner of a 1991 SE-V6 with an auto transmission with only 85k miles. The truck was incredibly well maintained by the previous owner. The only issue with her is that there is a slow rear main leak. I got a few quotes from shops near me but my friend and I have decided to tackle it ourselves. That being said, I want to get this post out there and pick all of your brains about this job, especially those of you who have done it before! I already picked up a transmission jack on facebook marketplace and we've got all the regular automotive tools... Are there any other unique or proprietary tools we will need? We've got the Haynes repair manual for the truck so we have a pretty good idea of the process for pulling the transmission and another friend of mine is doing a manual swap on his gen 1 so we were able to connect with him and pick his brain about pulling the auto and get a visual on his Pathfinder with the transmission out which was really helpful. OEM Nissan rear main seal part number appears to be 12279-AD205. (12279-AD205 - Seal 1984-2010 Nissan | Official Nissan Parts Store) Can anyone confirm this is correct and are there any other parts we will need for this job specifically? Would you recommend an OEM seal or has anyone had luck with aftermarket parts on Ebay or elsewhere? There appears to be some complete kits out there with other components. By the looks of it, the seal itself and then the triangular shaped paper gasket for the top of the bell housing: Victor Reinz JV538 Engine Rear Main Seal & Gasket Set for Z32 300ZX 12279-AD205 | eBay Fel-pro BS40628 Engine Crankshaft Rear Main Gasket Seal Kit | eBay While we have the transmission pulled, what other components should we swap that will be easily accessible or require minimal extra work to replace, specifically wear components or other seals/gaskets? We've got all of labor day weekend set aside for this so the more we can knock out in one transmission removal, the better. While the transmission is out, we are planning to put a cooler in since we will be draining the fluid and disconnecting the lines...which ATF cooler kit would you recommend and what ATF fluid should we put in? Any tips, tricks, or recommendations for tackling this? Any other helpful notes, pictures, or information you can lend? Thanks in advance and looking forward to everyone's input!
if you cared enough to try, the caliber bolt spacing measures the same if I remember correctly from 96-99 r50 they run 17MM bolt calibers and the 00-04 use the larger 19MM and larger rotors
- 1 reply
- 1
