Low pinion R200A front diff with 4.363 standard cut gears (not R50 reverse cut high pinion)
Triangles
Looking for a source for a standard cut 4.363 gears for a low pinion R200A diff.  So far I've only determined that these were in 2001 supercharged frontiers.  Does anyone know of other vehicles that I might be able to source these from?  Also looking for the same if there are any related differentials (C200) that has interchangeable gears with a low pinion R200A.
I'm trying to regear my 2004 Xterra with a H233B rear and R200A front.  I got the rear already from a (R50) 2000 Pathy and I also harvested the front diff too.  Unfortunately. I just found out the R50 R200A diff is a high pinion, reverse cut gear variant of the low pinion R200A that is in all other R200A variants.  If anyone needs it, I am in NW Ohio.
Looks like this topic isn't the duplicate one.
Because I'm a nerd, I tabled all the FSM data for Pathfinders, Frontiers, Xterras, and others long ago.  4.363 standard cuts were found in:
  • 00-01 Xterra XE
  • 00.5 Frontier XE
  • 01 Frontier SC
But now, are you going to a 4.363 from a 4.636 or 4.90 for fuel economy or something?  Or did you go with smaller tires?
Technically, you could find 4.375 from older Frontiers, Hardbodies, and Pathfinders if you feel like setting up gears or maybe swapping the R200A (not sure if they bolt up the same...I imagine they do, and maybe it's as easy as swapping the stub shafts from your R200A to keep the same 3x2 6-bolt pattern vs. 5x1 5-bolt pattern CVs).  The ratio difference is negligible.
