UPDATE - Unfortunately, the data that was lost is unrecoverable by the host.  If you joined between May 26th and Jan 13th please feel free to sign up again.  In addition, all posts and messages during that time have also been lost.  At this point there is nothing that can be done, other than to move forward from here.
Thank you for your patience and understanding.
-NPORA Mod Team
*Updated: 02/06/2022 5:26PM PST
Relace Starter Motor in WD21 for the real world.
vf24renegade
I couldn't post this in the garage so I put it here.
In the interest of humanity, here is a write-up of my experience changing a starter on a WD21 Pathfinder. A vehicle I loved and wanted….until I had to work on it.
Situation: 1994 Pathfinder XE – parts vehicle. 1995 Pathfinder XE – starter just clicks. The starter motor doesn’t turn. The click was loud enough that I knew it was the solenoid engaging. At first, I could turn the key several times and get the starter to turn. After a while, no more. To make things even more comical, my 1987 Chevy Silverado did the exact same thing at the exact same time. I changed the starter on it, much sooner and more quickly.
I read several posts on this procedure and, while all were somewhat right, I had to combine several techniques to successfully swap mine out. There is some misleading information out there, probably due to faulty memory. Also, mine are not lifted, so the ‘take out 2 bolts and starter comes right out’ does not apply here.
First task: Remove starter from 1994 parts vehicle. Both my Pathfinders are stock in that they are not lifted at all. Many posts decry removing the bolts as difficult. I found it the easiest part of the process. I used a 3/8 ratchet, 1- 8” extension, 2- 3” extensions, a universal adaptor and a 15 mm socket. I jacked up the vehicle, removed passenger tire. The battery was already out, so the positive cable was already disconnected. The mud shield was already out of the wheel well. From underneath, threading the socket affair alongside the transmission and behind the exhaust pipe, I unbolted the starter. A trouble light is very useful and goggles highly recommended. I live on a dirt road so there was a constant shower of sand and dirt as I worked. The bolts came loose and unbolted rather easily. The bottom bolt has the transmission cooling lines right next to it, so it is somewhat challenging. I anticipated this to be the most difficult so I was in good spirits after that, looking forward to a relatively easy removal. Ha ha. Working from the wheel well, I reached between the frame and the various lines in the way I removed the orange cover and plug to the oil pressure sensor. Then I proceeded to work the starter towards the front of the vehicle. Then I moved to the front, underneath. The rock guard there was already removed. I worked the starter out towards the front using the cables to pull with and rotating the starter in different positions to get the shield and or the solenoid past the engine and the engine mount. I was then stopped by the transmission cooling lines. I removed their mounting bracket (10mm bolt) and bent those towards the driver’s side. This was not easy. The fuel and brake lines in the rear of the vehicle rusted and are like tissue paper, but these were like solid steel bars. But I got them bent out of the way between the oil pan and the tie rod. I was then able to pull the starter forward, up and over the tie rod and it plopped out like a newborn baby. I used a small phillips screwdrive to remove the shield for the solenoid connector. There were 3 screws instead of the 2 mentioned in other posts. And I can see no way to get them out with the starter still in the vehicle as some claimed to have done. Perhaps theirs were lifted. I unplugged the solenoid connector and removed the nut holding on the positive cable (14mm). Note: Pay attention to the orientation of the cable on the starter. It must go back on at same orientation or it will short against the frame or motor mount. Total time was about 3 hours.
Second Task: Remove the faulty starter from the 1995 driving Pathfinder. The procedure was the same for the 1994 Pathfinder until it came time to remove the starter. This vehicle, still driven on the dirt road has the benefit of a leaky front seal so it has a nice mixture of sand, dirt and oil all over everything underneath. With the starter unbolted, I reached in through the wheel well and moved the starter forward. Moving, to the front, with the rock guard already removed, I removed the 10 mm bolt holding the transmission line bracket to its mount. I moved the transmission cooling lines towards the driver’s side as before. Utilizing the cables and various rotation positions, I worked the starter towards the front as before, but I was stymied by the solenoid or the positive cable hitting the engine mount and I couldn’t move it out further. I tried for several hours and had to stop for the day. Then the rains came, but that’s another story. I did more research and read where others had removed the oil filter and exhaust heat shield. I looked down through the engine compartment and saw that there might be access that way. I removed the battery. Then I unbolted the power sterring reservoir from the wheel well and moved it out of the way as far as allowed. (4-10mm bolts and 1 bendable bracket holding down the negative cable). I did the same with the fuel filter (2- 10mm bolts). This gave me good access to the heat shield. There are 2 10mm bolts on top and 3 on the side. Only the two front-most bolts on the side need to come out as the rearmost bolt on the side does only holds the pieces of the shield together and does not thread into the manifold. I managed to wring the head off only 1 bolt. These were fairly easy to get to and not difficult to remove with some care. Next, I placed a plastic bag over the loose starter to catch the oil, drained the oil and removed the oil filter. I looked and there was the starter in plain sight. I lowered the vehicle so I could reach the starter (a step stool would’ve been handy) and quickly and easily, rotated it and slid it forward past the engine mount. After jacking it back up, I then moved under the front of the vehicle and fairly easily worked it out the rest of the way, up and over the tie rod. Next, I removed the shield and 3 phillips screws, unplugged the solenoid connector and removed the positive cable.
Third Task: Put the 94 starter in the 95 Pathfinder. I cleaned up the replacement starter. I also repaired the broken wire and connector for the oil pressure sensor on the 95. I also cleaned all the electrical connections involved. I plugged in the solenoid connector, bolted on the positive cable and inserted the starter up and over the tire rod. I pushed it back as far as it would go then moved to the top of the engine and pulled it back. I moved to the wheel well and put the starter in position. I looked from the top and saw something of concern. The positive cable metal part was touching the motor mount. I thought it might clear once it was bolted up, so I moved underneath and started tightening the mounting bolts (bottom first). I looked up top again, and it did change. The metal cable end wasn’t touching the motor mount anymore, it was touching the frame. So, I had to take the starter back out. This wasn’t so bad because everything was still in position from before. I had mounted the positive cable 90 deg. out of position. This is why I said take note of the position when you take it off. I once again used the above procedure to put the starter back in place and made sure I had good clearance from the electrical connections. I bolted it back up from underneath. ( I never completely removed the bolts and don’t know if you can easily, so they threaded back into the starter without difficulty. Also, I pried the transmission lines away from the bottom bolt a bit with a screwdriver to give me a bit more clearance.) Before I did anything else, I re-installed the battery and gave the key a quick twist just to see if the starter would turn without starting the engine. It did! Success. I again removed the battery. I plugged the oil sensor wire back in. Put the oil drain plug back in. Installed a new oil filter. Added oil to the engine and let the oil bottle drain into the engine while I put the exhaust heat shield back on. I re-attached the fuel filter and the power steering reservoir. I made sure from underneath that the wires and cables were clear from potential damage. I reinstalled the transmission line bracket. Reinstalled the battery and the passenger tire. Fired her up and put her in a better parking position. Total time, about 14 hours. Most of the time was struggling and figuring out what to do. If I had all this information before hand, it would’ve only taken a few hours. Also, I have the service manual, and while it shows how to rebuild the starter, it had nothing about removing and replacing it. The Haynes manual is useless on this matter as well. I hope this helps somebody else who has this daunting task ahead of them. My only fear is that there was a rubber vent or drain tube on the bottom of the starter, but brittle from age and oil, it broke off. Now there’s a small open hole in the bottom of the starter. I think I’ll put some silicon over it unless someone else has a better idea. Whew!
Don't silicone the hole on the starter. That is a drain. If you plug it and take on water, well you should be able to figure out the rest.
Honestly I didn't read the whole thing. It's really difficult to read without paragraphs. Just trying to help.
I replaced several starters in my pathfinder until I found the starter relay mod. Turns out that was where the real problem lay for me. Once completed I have had no further starter issues. Yes it was a PITA getting starter out but I managed to wiggle it out thru the top (while running through my entire vocabulary of curse words) You might want to have a look at that mod if the starter goes out again less than the expected time and you have not already done the mod.
What diagnosed it for me was running a jumper wire to the solenoid. When the starter wouldn't crank, I would check the battery and if battery was good, I would just touch the jumper wire to the Positive battery terminal. Truck would start every time and I knew that the problem was not getting adequate power to the solenoid. Starter relay mod fixed it permanently. Jumper wire is still in place just in case ;)
  • 1 year later...
I'm in the process of changing the starter on my '95 and got stuck on the removal of the top mounting bolt. The bolts are 14mm but I'm curious if the OP intentionally used a 15mm socket to make the combo of extensions and universal joint work. I just couldn't grab the bolt using a 14mm socket. The exhaust pipe is in the way. Someone actually posted a video on YouTube on how to remove the starter using the same combination of extensions and a universal joint but it didn't really show how it engaged the top bolt.
I was thinking of denting the exhaust pipe a bit to make room.
I'd appreciate any insight from members who have done this. Thanks!
Stock exhaust? You could pry the heat shield on the pipe out of the way a little.
The way I did it was use more extensions and go from further back to get a better angle.
Hmmm. It's been a while since I replaced mine. I Youtubed how to get it out after trying, to no avail, to get it out without prying it past the fender. Turns out I had to unmount the idler arm to pull it out the front. Aside from that, it was pretty simple, But mine is a Manual, not an auto magical hydraulic pump. ;)
Yes, stock exhaust. I will try to pry the heat shield - a very small change will help a lot, I think. I was playing with various combinations of two 8" extensions, three 3" extensions and two universal joints. I have tried it from way up and way back.
I finally got the top bolt out! Slightly denting the heat shield around the area of the socket and extension really helped a lot. The 14mm socket sat nicely over the bolt - followed by a 3" extension, a universal joint, an 8" extension and the 3/8" ratchet, in that order. I used a short pipe to increase my leverage.
Thanks for the help!
Next is the challenge of pulling the starter out through the front.
I had to remove the last two bolts holding the A/T oil lines to make room. While pulling the transmission lines downward and towards the center, I was able to squeeze the starter out. You're right adamzan, installation is so much easier! I hope my new starter will last a long time.
There is some oil on the starter and it seems to be coming from the oil pressure sending unit. The sending unit appears to have been replaced by the previous owner with one that has the wrong connector housing so the housing was totally removed to expose just the spade connector to make it work. I replaced the sending unit with the correct replacement.
Thank you for the assist!
Usually the starter gets covered in oil when someone is doing an oil change. The oil filter is right above, so when you pull it off it dumps oil on the starter. I have only ever changed it once or twice without spilling on the starter a little. You can relocate the oil filter to an easier location though.
I've found the easiest way 3/8 drive14mm wobbly impact socket 2 12 inch extensions that will take care of the starter bolts
drop the idler arm and the starter will slid out if a autotragic drop the cooler lines.
It does help to be an retired mech with the right tools :):)
  • 3 weeks later...
Punch a hole into the bottom of the oil filter before removing it and let it drain. This keeps from douching the starter in oil.
Yes, for removing the filter. But, when installing the new filter full of oil, sometimes it tends to get a little messy.
You don't have to do that. The engine will survive a couple of seconds when the oil filter is filling up.
  • 3 weeks later...
To stop the oil going onto your starter motor, cover the oil filter with some plastic bags while unscrewing it so the filter falls into the bag and any drips too. Then just leave it there for a few mins until it's stopped dripping then you can clean up anything else with a shop rag.
  • 4 years later...
I pulled the starter motor out of my 1993 wd21 pathfinder/terrano yesterday, it was quite a mission. The hardest part was accessing the top bolt. My suspension lift on the truck made access pretty easy so no need to jack it up and didnt need to remove the right hand side wheel either.
Now to learn how to rebuild the starter motor....
