Random picture of your R50
CDN_S4
16 hours ago, rx_o said:
Thanks!
The hubs are RugedRidge.. Big mistake getting those, one just went bust. Popped it open thinking it was the bearing, just to realize that they DONT have a bearing.
I'm on the hunt for WARN ones, do you know if they do use bearings?
Must be user error or a defect. Many guys here use these hubs with no problems.
On 3/24/2023 at 1:34 PM, rx_o said:
Thanks!
What part failed? None of the hubs use ball bearings; not RR's, Warns, or even OEMs.  They have sleeve bearings that do need light lubrication (hub grease) however.
You just taught me something.
The bronze bushing has wear, so the shaft ist not snug anymore. This creates vibration. Did apply some grease and the rubbing/vibration stoped. How ever, its just a patch until I change de Hub. Now just have to decide to replace that just one, or buy a pair in other brand.
Warn seems to have a wider bushing? at least, seems so in the pics.
The contact width on all of them isn't that wide, maybe < 0.5", but I'm not sure wider is necessarily better.  Probably don't want things being too snug either.  It's ok if there's a little tolerance (the exposed tip of the CV has a little play, too), so long as it's not wobbling around or creating high/low spots in the sleeve.  Main thing is lubrication, but not too much (otherwise the clutch ring won't disengage easily).
Not sure how easy it is to just find a single unit, but if you get a new pair, you'll have at least a spare.  Though, seems like these may be ok still.  Is there still a gasket in place to keep elements out?
On 3/24/2023 at 6:41 PM, Mrelcocko said:
I replaced my entire front suspension. Also replaced both axels. I didn’t replace wheel bearings. I replaced inner and outer tie rods, swaybar bushings and links as well. Anything that had to do with the suspension I replaced.
good to know, thank you!
  • 3 weeks later...
On 3/31/2016 at 7:56 PM, Underoath said:
Is anyone familiar with how this roof rack is set up? Would it have issues with a sun roof? Also would it be safe to stand on? Looking for something similar for my pathy.
On 8/26/2018 at 4:42 PM, R50JR said:
Spent the morning at a friend’s winery.
What is the roof rack setup used here as well? It is super clean! Will it work if my '01 LE has a sunroof?
Do this:
Edited by R50JR
  • 1 month later...
  • 1 month later...
18 hours ago, PathyDude17 said:
Did you swap out your headlights?
Yes! I'll probably do a more in-depth post in my build thread when I can but these are headlight buckets that a guy in Australia designed & 3d printed, and allow you to swap in LED sealed beam style 5x7 lights. There are cheaper options for the 5x7 lights themselves, but I went with a set of Morimoto LED's.
Love the headlights
Nice!
  • 3 weeks later...
last weekend.
me and xplore and another pathfinder (dylan) not sure if he is here too. went up wheeling and camp out Pardoes Trail and Squaw Ridge Norcal Trail Run 2023
370398156_6421887707860851_3986066012834
372906774_6418468501536105_4826085618816
372906764_6418468754869413_8921628558089
372966394_6418470354869253_7434984141487
371930653_6418470578202564_2207941977704
372913181_6418471441535811_2498964501248
372984992_6418476921535263_5436069717028
372924501_6418477024868586_5709629389576
372916965_6418477231535232_5938315239267
372979063_6418477824868506_9187250307636
372980708_6418478134868475_1152349233377
372912691_6418479604868328_5676324541327
371548063_6418479711534984_4054390293563
372982333_6418480098201612_4533449639519
371915422_6418480901534865_7078906190932
371367232_6418481154868173_7828841341634
372920048_6418482481534707_2610424127695
371327244_6418482818201340_1902906473266
372924788_6418482841534671_7660238529035
371862773_6418482934867995_2655707670353
Edited by deltaR50
