yourmomsbull Posted March 25, 2023 Share Posted March 25, 2023 16 hours ago, rx_o said: Thanks! The hubs are RugedRidge.. Big mistake getting those, one just went bust. Popped it open thinking it was the bearing, just to realize that they DONT have a bearing. I'm on the hunt for WARN ones, do you know if they do use bearings? Must be user error or a defect. Many guys here use these hubs with no problems. Link to comment Share on other sites More sharing options...
hawairish Posted March 26, 2023 Share Posted March 26, 2023 On 3/24/2023 at 1:34 PM, rx_o said: Thanks! The hubs are RugedRidge.. Big mistake getting those, one just went bust. Popped it open thinking it was the bearing, just to realize that they DONT have a bearing. I'm on the hunt for WARN ones, do you know if they do use bearings? What part failed? None of the hubs use ball bearings; not RR's, Warns, or even OEMs. They have sleeve bearings that do need light lubrication (hub grease) however. Link to comment Share on other sites More sharing options...
rx_o Posted March 26, 2023 Share Posted March 26, 2023 11 hours ago, hawairish said: They have sleeve bearings that do need light lubrication (hub grease) however You just taught me something. The bronze bushing has wear, so the shaft ist not snug anymore. This creates vibration. Did apply some grease and the rubbing/vibration stoped. How ever, its just a patch until I change de Hub. Now just have to decide to replace that just one, or buy a pair in other brand. Warn seems to have a wider bushing? at least, seems so in the pics. Link to comment Share on other sites More sharing options...
hawairish Posted March 26, 2023 Share Posted March 26, 2023 3 hours ago, rx_o said: You just taught me something. The bronze bushing has wear, so the shaft ist not snug anymore. This creates vibration. Did apply some grease and the rubbing/vibration stoped. How ever, its just a patch until I change de Hub. Now just have to decide to replace that just one, or buy a pair in other brand. Warn seems to have a wider bushing? at least, seems so in the pics. The contact width on all of them isn't that wide, maybe < 0.5", but I'm not sure wider is necessarily better. Probably don't want things being too snug either. It's ok if there's a little tolerance (the exposed tip of the CV has a little play, too), so long as it's not wobbling around or creating high/low spots in the sleeve. Main thing is lubrication, but not too much (otherwise the clutch ring won't disengage easily). Not sure how easy it is to just find a single unit, but if you get a new pair, you'll have at least a spare. Though, seems like these may be ok still. Is there still a gasket in place to keep elements out? 1 Link to comment Share on other sites More sharing options...
tobin_r50 Posted March 27, 2023 Share Posted March 27, 2023 On 3/24/2023 at 6:41 PM, Mrelcocko said: I replaced my entire front suspension. Also replaced both axels. I didn’t replace wheel bearings. I replaced inner and outer tie rods, swaybar bushings and links as well. Anything that had to do with the suspension I replaced. good to know, thank you! Link to comment Share on other sites More sharing options...
JcLopez Posted April 14, 2023 Share Posted April 14, 2023 Found a great spot for a photo!Enviado desde mi iPhone utilizando Tapatalk 8 Link to comment Share on other sites More sharing options...
Mrelcocko Posted April 14, 2023 Share Posted April 14, 2023 Sent from my iPhone using Tapatalk 1 Link to comment Share on other sites More sharing options...
tobin_r50 Posted April 19, 2023 Share Posted April 19, 2023 On 3/31/2016 at 7:56 PM, Underoath said: I haven't posted a pic here since I joined last year. Here she is after my 2" lift http://i721.photobucket.com/albums/ww212/summerluv06/Mobile%20Uploads/20160221_170901.jpg http://i721.photobucket.com/albums/ww212/summerluv06/Mobile%20Uploads/20160312_193211.png.jpeg Is anyone familiar with how this roof rack is set up? Would it have issues with a sun roof? Also would it be safe to stand on? Looking for something similar for my pathy. Link to comment Share on other sites More sharing options...
tobin_r50 Posted April 27, 2023 Share Posted April 27, 2023 On 7/24/2018 at 2:43 AM, RainGoat said: Out & About in Mount Baker NF last week. @RainGoat what kind of brush guard is this? 1 Link to comment Share on other sites More sharing options...
tobin_r50 Posted April 27, 2023 Share Posted April 27, 2023 On 8/26/2018 at 4:42 PM, R50JR said: Spent the morning at a friend’s winery. Sent from my iPhone using Tapatalk What is the roof rack setup used here as well? It is super clean! Will it work if my '01 LE has a sunroof? 1 Link to comment Share on other sites More sharing options...
Guest Posted April 28, 2023 Share Posted April 28, 2023 (edited) 15 hours ago, tobin_r50 said: What is the roof rack setup used here as well? It is super clean! Will it work if my '01 LE has a sunroof? Do this: Edited April 28, 2023 by R50JR Link to comment Share on other sites More sharing options...
Mrelcocko Posted June 11, 2023 Share Posted June 11, 2023 Sent from my iPhone using Tapatalk 1 Link to comment Share on other sites More sharing options...
deltaR50 Posted July 25, 2023 Share Posted July 25, 2023 (edited) Indian Valley Reservoir 2022 its been a while since the last time i dropped by Edited July 25, 2023 by deltaR50 1 Link to comment Share on other sites More sharing options...
deltaR50 Posted July 25, 2023 Share Posted July 25, 2023 2 Link to comment Share on other sites More sharing options...
deltaR50 Posted July 25, 2023 Share Posted July 25, 2023 (edited) Basset Station 2021 downieville, ca Edited July 25, 2023 by deltaR50 2 Link to comment Share on other sites More sharing options...
The_Oregonian Posted July 30, 2023 Share Posted July 30, 2023 Beauty shot from camping this morning with the clouds below and Mt St Helens above. @zakzackzachary Should recognize this spot! 6 Link to comment Share on other sites More sharing options...
PathyDude17 Posted August 4, 2023 Share Posted August 4, 2023 On 7/30/2023 at 5:28 PM, The_Oregonian said: Beauty shot from camping this morning with the clouds below and Mt St Helens above. @zakzackzachary Should recognize this spot! Did you swap out your headlights? 1 Link to comment Share on other sites More sharing options...
The_Oregonian Posted August 4, 2023 Share Posted August 4, 2023 18 hours ago, PathyDude17 said: Did you swap out your headlights? Yes! I'll probably do a more in-depth post in my build thread when I can but these are headlight buckets that a guy in Australia designed & 3d printed, and allow you to swap in LED sealed beam style 5x7 lights. There are cheaper options for the 5x7 lights themselves, but I went with a set of Morimoto LED's. 4 Link to comment Share on other sites More sharing options...
Mrelcocko Posted August 5, 2023 Share Posted August 5, 2023 Yes! I'll probably do a more in-depth post in my build thread when I can but these are headlight buckets that a guy in Australia designed & 3d printed, and allow you to swap in LED sealed beam style 5x7 lights. There are cheaper options for the 5x7 lights themselves, but I went with a set of Morimoto LED's. Love the headlights Sent from my iPhone using Tapatalk 2 Link to comment Share on other sites More sharing options...
Mrelcocko Posted August 5, 2023 Share Posted August 5, 2023 Yes! I'll probably do a more in-depth post in my build thread when I can but these are headlight buckets that a guy in Australia designed & 3d printed, and allow you to swap in LED sealed beam style 5x7 lights. There are cheaper options for the 5x7 lights themselves, but I went with a set of Morimoto LED's. Nice!Sent from my iPhone using Tapatalk 1 Link to comment Share on other sites More sharing options...
Strato_54 Posted August 27, 2023 Share Posted August 27, 2023 I definitely need to fix the faded bumpers now. Gonna be a fun winter 1 Link to comment Share on other sites More sharing options...
deltaR50 Posted September 2, 2023 Share Posted September 2, 2023 (edited) last weekend. me and xplore and another pathfinder (dylan) not sure if he is here too. went up wheeling and camp out Pardoes Trail and Squaw Ridge Norcal Trail Run 2023 Edited September 2, 2023 by deltaR50 1 Link to comment Share on other sites More sharing options...
deltaR50 Posted September 2, 2023 Share Posted September 2, 2023 more pics ! 1 Link to comment Share on other sites More sharing options...
Slartibartfast Posted September 3, 2023 Share Posted September 3, 2023 Looks like fun! Nice bumpers, too. Link to comment Share on other sites More sharing options...
