CDN_S4 build thread
CDN_S4
Sounds like you've got er covered, for all the grief you've been through at least you will get a good return on the trails, and the road after one of our 4' snowfalls ;)
The only other thing that would be great for one of these massive lifts is longer/extendable trailing arms. Fleuries ones looked great I don't understand why no one bought them.
Fleury has longer trailing arms?!? I've been thinking about having my guy fab an extension for them. He said chances are I could find longer ones from another vehicle if I looked hard enough. But if Fleury has some, then heck yes! Thanks
He doesn't make them anymore. No one was buying them. They were made of square aluminium, adjustable length, and with poly bushings greasable via zerk fittings. I've had a thread up for a while in parts wanted looking for used ones, nothing yet :(
That's too bad. Maybe I'll have to have my own extension bracket built after all. We'll see, it doesn't really seem necessary to extend them but it would look better if the rear wheel was actually cantered in the middle
Your compressor broke?! Oh man...when things fail under load it can go bad very quickly. I had a 2ft section of 7/8 allthread pull out of a bulkhead when using a 50ton hydraulic ram. I'm still alive for some reason, unscathed from that incident. I hate using that kind of equipment in an uncontrollable situation. Have a shop do it. They have the cage to protect themselves and your rig
No, it didn't break. I couldn't get it compressed tightly enough. It popped off one time and scared the crap out of me....luckily no injuries. I wouldn't do stiff springs again.
With the TJM bumper and knowing I was going to add a winch, I opted for the HD springs and can't be happier with my choice.
I've been considering a SAW, but can't find a thread with this being done on an R50.
Yes, one of my compressors broke. It went flying away from me and I jumped off my chair lol. It was definitely scary. So I bought a new set of compressors that actually lock onto the coil instead of just claw it.
Luckily the other side held up and kept the spring from exploding entirely. Also it was on the strut so the coil itself wasn't gonna go flying. I'll take a pic of it tonight
Holy crap. Very lucky. Even if the spring and strut are still assembled the compressor itself becomes a projectile, as you experienced, with the potential to do some serious damage. Maybe use a tie down to secure everything in place, even with the locking type compressor. Never can be too safe.
OT here on the spring compresser story.
Back in 2002 I was putting in Eibach springs in my 92 Z28. I had just pulled out on of the stock coils compressed. Went to set it down when it let go. In the process it went to the left of me bounced off the wall of the house. Ended up across the street by the neighbors front door. A good 200ft away. It had hit and smash my thumb pretty good. Scared the bejesus out of me. I only use wall mounted for struts now. And if its on the car and center style compressor. I add a rachet strap as some kind of extra measures.
Sent from fat fingers on S6
Yeah I'll have to augment with ratchet traps as well as its one of the scariest things when they let go. Mine wasn't nearly as bad as Rebellord's but a scare nonetheless.
If someone has an ingenious solution to getting these top bolts out, that would make my life a million times easier as it would allow me to keep the strut fully assembled. Otherwise I'm gonna have to take it apart and get into the whole spring compressing business again lol
hahahaha OMG I can't believe I was hung up on the thought that the whole bolt had to come out. My god, it's so simple it's stupid. Thanks for giving my head a shake lol, it's been a crazy long day.
Regarding the idea of longer control arms...here's my thought on that (I'm lifted too...just recently, so am in the same boat).
As the axle drops from the body (or the body lifts up from the axle) the tires swing slightly forward and can look out of center. But when the suspension compresses out on the trail, especially so when articulating, it swings back up, centering the wheel again just as it's tucking in to the rear fender.
If we lengthen the control arms to center it at static height, then as it tucks upward, it will move too far backward and rub the back side of the wheel well when fully tucked (if it ever gets there???)
So I'm wary of the idea of lengthening my control arms. What do you all think?
You make a very good point. I guess the deciding factor is in how you use your vehicle for the majority of the time. Or better even, have a telescopic control arm that can be moved into 2 or 3 positions and locked in place depending on requirements.
Woooohooo!!! Success at last! All done. I even adjusted the camber bolt on the driver side too much that I now have negative camber!! So it's all within proper specs now. What a relief!
:aok:
If you extend your bumpstops, then lengthening the arms to re-center the axle shouldn't be a problem (i.e., it can't "get there"). But you should extend them when you put larger tires or spacers on anyway. My rules of thumb have been to lengthen the bumpstop 1" for every 2" of tire size increase, or 1" for every 1" of spacer lift. This generally ensures there won't be rubbing at the top of the wheel well, which (with longer control arms) would also prevent the tire from swinging too far back (er, up?) to hit the rear of the wheel well.
You may also need to be mindful of the extendable length of the driveshaft if going with longer control arms...but nothing a small driveshaft spacer can't resolve if the driveshaft is too short.
I used 2" body lift spacers (Performance Accessories BB02), a longer bolt (8mm x 1.25 x 70mm), and a nylock nut (to secure the bolt to OE bumpstop, center the spacer, and so I could just twist them on by hand) when I added spacers:
Edited by hawairish
At this point, I'd like to give a big thank you to Hawaiirish, you have been super helpful throughout this process both on and offline. Kudos and thanks man. I really appreciate it. And I also really appreciate everyone's input and help with with this. It started to feel like a community effort. I definitely wasn't alone in this, so here's a cheers to all of you!
Much better! Glad it's all sorted!
You know it!
Next is the rear to get raised higher.
Also on the list are rock sliders, something like these hopefully:
I've been thinking about hood louvers too for a while to help the air intake a bit with the high temperatures.
I plan on swapping the overhead console to a display one. But the install seems pretty tricky.
Not a modification but some rust spots need to be addressed. Along with a fresh undercoat.
Then a rear bumper with carrier is likely also going to be in the future. But for now I'll just modify my rear hitch carrier.
Might swap my blue interior dash LEDs for amber ones, not sure yet. I think Amber is a bit more grown up lol.
These are just the things floating around in my head right now.
good job brother, glade to see you've sorted things out.
I've got one of the OEM overhead consoles (JY find) however no wiring or sensors for it to work. If you find a JY one remember to pull all the wiring that goes with it.
