The_Magicians_Eye Posted September 20, 2012 Share Posted September 20, 2012 Ok I need to replace all my door windows seals, scrapers (not sure what they are call), and whatever else I need to keep my windows from rattling around and letting wind whistle through the cracks. Where do I find them? Is there a website or is this strictly just something I have to hope the dealers can find? Link to comment Share on other sites More sharing options...
Precise1 Posted September 20, 2012 Share Posted September 20, 2012 Most, if not all is still available through the dealership IIRC. I'm sure the info has been posted before, but don't know where the thread is. Rob at factorynissanparts.com will be able to help you and probably have the best prices. Tell him you are from NPORA... B 1 Link to comment Share on other sites More sharing options...
The_Magicians_Eye Posted September 21, 2012 Author Share Posted September 21, 2012 thank you Link to comment Share on other sites More sharing options...
Alkorahil Posted September 21, 2012 Share Posted September 21, 2012 I heard my name mentioned! I think Precise1 is my #1 fan! LOL In the industry jargon, the outer black moulding strips on the top of the door are called 'belt mouldings'. Nissan is also very proud of theirs.......... PART NUMBER: 80820-01G00 DESCRIPTION: MOULDING, BELT, FRONT, RH $53.22 (NISSAN LIST:$72.12) PART NUMBER: 80821-01G00 DESCRIPTION: MOULDING, BELT, FRONT, LH $59.47 (NISSAN LIST: $80.58) PART NUMBER: 82820-83G00 DESCRIPTION: MOULDING, BELT, REAR, RH $92.09 (NISSAN LIST: $124.78) PART NUMBER: 82821-83G00 DESCRIPTION: MOULDING, BELT, REAR, LH $92.09 ( NISSAN LIST: $124.78) And the inner ones that go along the top and attach to the top of the door panels: PART NUMBER: 80834-01G00 DESCRIPTION: WEATERSTIP, INSIDE, DOOR, FRONT, RH $33.76 ( NISSAN LIST: $45.75) PART NUMBER: 80835-01G00 DESCRIPTION: WEATERSTIP, INSIDE, DOOR, FRONT, LH $33.76 ( NISSAN LIST: $45.75) PART NUMBER: 82834-83G00 DESCRIPTION: WEATERSTIP, INSIDE, DOOR, REAR, RH $18.56 ( NISSAN LIST: $25.15) PART NUMBER: 82835-83G00 DESCRIPTION: WEATERSTIP, INSIDE, DOOR, REAR, LH $18.54 ( NISSAN LIST: $25.12) Last time I checked I could still get all of them....I think we stock the front belt mouldings. -Rob 1 Link to comment Share on other sites More sharing options...
JIPPERR Posted September 23, 2012 Share Posted September 23, 2012 Yo! i'm thinking of replacing some of the seals on my doors as well. The seals at the bottom outside of my windows are shot on about three of four doors. everything else looks about fine. I think the 'scraper' bit you mention is part 80820 and 80821 in this parts fiche: http://www.nissanpartszone.com/Page_Product/PartDetail.aspx?ModelName=Pathfinder&ModelYear=1995&ModelSeries=WD21&FileType=277&SelectConditions=(1%3dW%3b2%3dVG30E%3b3%3dST%2fXE%3b4%3dMT.F5%3b5%3d4WD%3b6%3d4D%3b7%3dFED%3b)&ShowConditions=(1%3dW%3b2%3dVG30E%3b3%3dST%2fXE%3b4%3dMT.F5%3b5%3d4WD%3b7%3dFED%3b)&seeDesc=False&goBack=True&SectionNo=K&ComponentsNo=800&ComponentsIndex=5 Maybe that helps? i'm going to try and find some junk yard parts or just ignore it, not sure how far into the door you'd have to dig to replace them. I guess i was kind of hoping to find a quick cheap easy fix , you know, the holy grail lol. JP Link to comment Share on other sites More sharing options...
redbeard32 Posted September 24, 2012 Share Posted September 24, 2012 What about for the rear passenger side glass only...The glass that has Pathfinder on it..I need the moulding for the whole window. 2 Link to comment Share on other sites More sharing options...
The_Magicians_Eye Posted September 24, 2012 Author Share Posted September 24, 2012 damn those moldings are expensive. If I replace all of them I'll have spent more on them than I did to buy the truck lol. Link to comment Share on other sites More sharing options...
redbeard32 Posted September 25, 2012 Share Posted September 25, 2012 Hahaha, Yeah I hear you on that one. Link to comment Share on other sites More sharing options...
JIPPERR Posted September 25, 2012 Share Posted September 25, 2012 some searching around on this site has revealed that the lower door window molding seal things are pretty easy to remove if you have a putty knife off to the junkyard this weekend! 1 Link to comment Share on other sites More sharing options...
Alkorahil Posted September 27, 2012 Share Posted September 27, 2012 (edited) Yo! i'm thinking of replacing some of the seals on my doors as well. The seals at the bottom outside of my windows are shot on about three of four doors. everything else looks about fine. I think the 'scraper' bit you mention is part 80820 and 80821 in this parts fiche: http://www.nissanpar...mponentsIndex=5 Maybe that helps? i'm going to try and find some junk yard parts or just ignore it, not sure how far into the door you'd have to dig to replace them. I guess i was kind of hoping to find a quick cheap easy fix , you know, the holy grail lol. JP Yep, those in that diagram are thse parts: PART NUMBER: 80820-01G00 DESCRIPTION: MOULDING, BELT, FRONT, RH $53.22 (NISSAN LIST:$72.12) PART NUMBER: 80821-01G00 DESCRIPTION: MOULDING, BELT, FRONT, LH $59.47 (NISSAN LIST: $80.58) Getting them off the vehicle is easy, just pull them off. But you will destroy them in the process though. Getting them off a vehicle once installed without damaging them, even with a putty knife....dont really think its possible. Definately would take some patience! I would be impressed if you did! Putting the new ones on you have to be careful and apply even pressure to avoid bending the pot metal under the rubber. Edited September 27, 2012 by Alkorahil Link to comment Share on other sites More sharing options...
Alkorahil Posted September 27, 2012 Share Posted September 27, 2012 (edited) What about for the rear passenger side glass only...The glass that has Pathfinder on it..I need the moulding for the whole window. There is an upper and a lower piece for that glass 83816-83G00 MOULDING-UPPER, REAR SIDE, RH $22.14 (NISSAN LIST: $46.80) 83814-83G00 MOULDING-LOWER, REAR SIDE, RH $21.35 (NISSAN LIST: $45.14) There is also the L shaped plastic upper corner moulding: 83822-83G00 MOULDING-CORNER, REAR SIDE, RH $17.54 (NISSAN LIST: $37.08$ Edited September 27, 2012 by Alkorahil 1 Link to comment Share on other sites More sharing options...
JIPPERR Posted September 27, 2012 Share Posted September 27, 2012 Getting them off the vehicle is easy, just pull them off. But you will destroy them in the process though. Getting them off a vehicle once installed without damaging them, even with a putty knife....dont really think its possible. Definately would take some patience! I would be impressed if you did! Putting the new ones on you have to be careful and apply even pressure to avoid bending the pot metal under the rubber. Good to know, heading to see a 'for parts' pathfinder tonight, it'll be a good opportunity to practice I've got a few odds and ends I'm trying to find including those mouldings so all is not lost if they do break. I may just end up getting a new part for the front drivers side window as its the worst offender. JP Link to comment Share on other sites More sharing options...
RedPath88 Posted May 12, 2015 Share Posted May 12, 2015 Content Removed And you can read and abide by forum rules NPORA Guidelines Including, but not limited too: 6. Do not use this site to promote your own business or Website without the permission of an administrator, this will include links to external sites attempting to sell products and/or services to other forum members. No spam! Link to comment Share on other sites More sharing options...
V8path Posted May 8, 2018 Share Posted May 8, 2018 There is an upper and a lower piece for that glass 83816-83G00 MOULDING-UPPER, REAR SIDE, RH $22.14 (NISSAN LIST: $46.80) 83814-83G00 MOULDING-LOWER, REAR SIDE, RH $21.35 (NISSAN LIST: $45.14) There is also the L shaped plastic upper corner moulding: 83822-83G00 MOULDING-CORNER, REAR SIDE, RH $17.54 (NISSAN LIST: $37.08$ I've to repair a front windshield leak, and given the existing hardware/molding is going on 30 years old, most look like they will need to be replaced. Was wondering if you have part numbers and all the windshield retaining and molding parts, and a diagram would also be really helpful. Thanks Link to comment Share on other sites More sharing options...
Slartibartfast Posted May 8, 2018 Share Posted May 8, 2018 Alkorahil hasn't been on here for a few years, unfortunately. This diagram and parts list is probably what you're after, though. 1 Link to comment Share on other sites More sharing options...
RobinRio Posted August 6, 2018 Share Posted August 6, 2018 On 9/27/2012 at 12:56 PM, Alkorahil said: Yep, those in that diagram are thse parts: PART NUMBER: 80820-01G00 DESCRIPTION: MOULDING, BELT, FRONT, RH $53.22 (NISSAN LIST:$72.12) PART NUMBER: 80821-01G00 DESCRIPTION: MOULDING, BELT, FRONT, LH $59.47 (NISSAN LIST: $80.58) Getting them off the vehicle is easy, just pull them off. But you will destroy them in the process though. Getting them off a vehicle once installed without damaging them, even with a putty knife....dont really think its possible. Definately would take some patience! I would be impressed if you did! Putting the new ones on you have to be careful and apply even pressure to avoid bending the pot metal under the rubber. I found the whole set of inner and outer Belt line moldings (4 pieces) for the front doors here: https://www.ebay.com/itm/171518441000 Link to comment Share on other sites More sharing options...
adamzan Posted August 13, 2018 Share Posted August 13, 2018 Nice. Just ordered a set... Would be nice if I could find some for the rears though. Link to comment Share on other sites More sharing options...
djeffrey Posted August 14, 2018 Share Posted August 14, 2018 I am going to order a set hopefully also, I messaged the seller he gave above and asked about the rears, he mentioned he does not sell them but he has had people simply cut them shorter to fit. Link to comment Share on other sites More sharing options...
Beard Posted December 7, 2019 Share Posted December 7, 2019 Any leads on all the window trim pieces? Needing the driver And passenger side front and rear, as well as the trim around the rear side hatch windows that have “pathfinder” on it. Looked online found this forum post. Tried the factorynissan page, all discontinued. Wanting them to be new and wanting them to last. Trying to figure out how much it’s gonna cost so I can replace them when I repaint (actually gonna bed line) my 93 pathfinder. Thanks for your time! Link to comment Share on other sites More sharing options...
Volox Posted April 4, 2020 Share Posted April 4, 2020 (edited) @Beard Did you end up finding any? I'm looking for some of the same. Edited April 4, 2020 by Volox Link to comment Share on other sites More sharing options...
