Towncivilian Posted June 2, 2011 Share Posted June 2, 2011 (edited) I don't recall seeing one of these threads, and since we've got "What did you do to your Pathfinder today?", a "what's on your to-do list" seems like a nice companion. Anyway, I've got: Install auxiliary transmission cooler and an in-line Magnefine filter Paint new bumper and driver side quarter panel (see pic) Fix rust on new tailgate door, and move it down a bit so it's more flush Put threadlocker on power valve screws Fix this dent on my driver door somehow so it stops obliterating the door switch I could probably get all that done in one weekend, it's not a whole lot... but I still need to get the paint & clear coat for the bumper and panel, and get some replacement bolts/nuts for my upper intake manifold since they are stripped before I can those done. I'm also probably missing a few minor things for the list since I don't write these things down, it's just a mental list. What's on your list? Edited August 10, 2011 by Towncivilian Link to comment Share on other sites More sharing options...
sewebster Posted June 2, 2011 Share Posted June 2, 2011 -rebuild transmission (5 speed) -pull huge dent out of a rear door -weld on new compression rod cups -patch holes in floor under drivers feet and rear passenger seat -replace windshield -replace abs speed sensor -replace front left bumper end -fix smashed rear left bumper end -spray salt off bottom of truck and possibly apply some sort of rust proofing? Link to comment Share on other sites More sharing options...
trenton163 Posted June 2, 2011 Share Posted June 2, 2011 New bushings all the way around New torsion bars New Shocks Fix rear drivers side locks and window New tint and paint New speakers fix fuel gauge,rear-wiper, power mirror switch. And new timing belt ( in about 30,000 miles) Link to comment Share on other sites More sharing options...
teixeira Posted June 2, 2011 Share Posted June 2, 2011 - Getting the complete AC in place, figuring out what goes where, first. Link to comment Share on other sites More sharing options...
Dowser Posted June 2, 2011 Share Posted June 2, 2011 My list would be like typing out the PoHo thread so I'm going to just leave it at that. Link to comment Share on other sites More sharing options...
Precise1 Posted June 2, 2011 Share Posted June 2, 2011 Ditto. Not that I don't want to play, but way to many things to list... B Link to comment Share on other sites More sharing options...
WarehouseRat Posted June 2, 2011 Share Posted June 2, 2011 install calmini lift get a set of slider from Mr510 replace hydro/slack adjusters replace egr valve replace o2 sensor install complete exhaust system including headers figure out why the f'in tach keeps wierdin out, speedo shop says it works fine when they bench test the cluster for 10 miles finish weeding the flower beds in yard spread moss out go buy more chickens, dont laugh chickens are cool as hell and there is more but im sure im forgetting some Link to comment Share on other sites More sharing options...
adamzan Posted June 2, 2011 Share Posted June 2, 2011 (edited) re index torsion bars replace egr or bpt valve replace a/c compressor with quiet one replace drivers door, hood, and tailgate with rust free ones (have them already) install headers (sitting in garage) new tires take it back to the glass shop because the windshield leaks change lifters remove AT from parts truck and tear apart fix rust under rear seats and rear quarters figure out what to coat frame with new center link install idler arm brace (have already) alignment paint trim replace rear bumper (again) with spare or build custom sliders skid plates winch lower control arm bushings install volt meter and new trans temp gauge install oil filter relocation kit replace heater core and possibly radiator if funds allow change universal joints change rear upper link bushings change pinion seal full fluid flush figure out what im going to do to utilize the arb mounts that attach to the factory bumper spot Wow that is a long list. There is probably more too. Edited June 2, 2011 by adamzan Link to comment Share on other sites More sharing options...
nunya Posted June 2, 2011 Share Posted June 2, 2011 Ditto. Not that I don't want to play, but way to many things to list... B pretty much covers it Link to comment Share on other sites More sharing options...
BoneZ Posted June 2, 2011 Share Posted June 2, 2011 Will try to make it short -finish making links -finish 3 more mounts 4 links -finish coil bucket mounts -Get last IFS bracket off frame -figure out how im going to mount shocks -make winch bumper -make front drive line -remove leaf spring hangers -reassemble as 3 link That is leaving off a ton of stuff but enough for now. Link to comment Share on other sites More sharing options...
Kingman Posted June 2, 2011 Share Posted June 2, 2011 Wire in the IACV, O2 sensor, replace the trailing arm bushings, change gear oils, and fix the rear main seal leak. Link to comment Share on other sites More sharing options...
Zibi Posted June 3, 2011 Share Posted June 3, 2011 (edited) Too much I have stages I'm planning. First: - Install efans - Timing belt / water pump - Trans cooler - Upgrade alternator (possibly) - Install skidplates - Finish sound system Second: - Install levelling spacers - Manual hubs - Redo front brakes Third (aka things I'd like to do but have no plans to do in the immediate future): - Bumpers - Cams - Reflash ECU Ultimately I'd also like to cut my fenders to run 33s and install mudflaps and fender flares but I'm not sure really when or what I'm going to do there. Might just keep the 31s in which case I won't cut my fenders. I'm undecided on which course to take though. Part of me always wants to go bigger and better, but my truck is my daily driver and sees almost exclusively pavement right now. Edited June 3, 2011 by Zibi Link to comment Share on other sites More sharing options...
jadm4x4 Posted June 4, 2011 Share Posted June 4, 2011 ill just start at the front and work my way back Link to comment Share on other sites More sharing options...
Slartibartfast Posted June 5, 2011 Share Posted June 5, 2011 (edited) Oh man... Reindex the torsion bars Undercoat Oil change Trans cooler/ATF change Replace an exhaust gasket where the local grease monkey half welded the pipes together Driver side door hinge Tinker with the headlights/install driving lights Then I need to actually take it off road. Priorities have changed a bit. Fix frame rot. Undercoat. Undercoat. Undercoat. Fix exhaust. Trans cooler. Lights, maybe. Probably more undercoat. Edited July 30, 2011 by Slartibartfast Link to comment Share on other sites More sharing options...
adamzan Posted June 25, 2011 Share Posted June 25, 2011 re index torsion bars replace egr or bpt valve replace a/c compressor with quiet one replace drivers door, hood, and tailgate with rust free ones (have them already) install headers (sitting in garage) new tires take it back to the glass shop because the windshield leaks - Done change lifters remove AT from parts truck and tear apart fix rust under rear seats and rear quarters - Done figure out what to coat frame with - Done new center link install idler arm brace (have already) alignment paint trim replace rear bumper (again) with spare or build custom sliders skid plates winch control arm bushings - Done install volt meter and new trans temp gauge install oil filter relocation kit replace heater core and possibly radiator if funds allow change universal joints - Done change rear upper link bushings change pinion seal full fluid flush figure out what im going to do to utilize the arb mounts that attach to the factory bumper spot Wow that is a long list. There is probably more too. updated Link to comment Share on other sites More sharing options...
sewebster Posted June 25, 2011 Share Posted June 25, 2011 updated What did you coat the frame with? Did you do anything to the inside somehow? Link to comment Share on other sites More sharing options...
adamzan Posted June 25, 2011 Share Posted June 25, 2011 I used the black asphalt undercoating from CT. And then I painted it with some rust paint. There are a couple different kinds of undercoating in the same aisle. I got the paintable one. I use fluid film on the inside. Link to comment Share on other sites More sharing options...
sewebster Posted June 26, 2011 Share Posted June 26, 2011 I used the black asphalt undercoating from CT. And then I painted it with some rust paint. There are a couple different kinds of undercoating in the same aisle. I got the paintable one. I use fluid film on the inside. Cool. Paintable sounds like a good idea... I saw that asphalt stuff and I just thought "sticky." How do you apply the fluid film? Link to comment Share on other sites More sharing options...
adamzan Posted June 26, 2011 Share Posted June 26, 2011 How do you apply the fluid film? It comes in spray cans. I empty 3 or 4 of them into the frame via the access holes after I've power washed it out. It is like 14.99 a can at CT. I saw at TSC that you can buy a paint can size version but I would need a way to spray it. Link to comment Share on other sites More sharing options...
sewebster Posted June 26, 2011 Share Posted June 26, 2011 It comes in spray cans. I empty 3 or 4 of them into the frame via the access holes after I've power washed it out. It is like 14.99 a can at CT. I saw at TSC that you can buy a paint can size version but I would need a way to spray it. Gotcha. I guess it doesn't get absolutely everywhere in there, but better than nothing. Link to comment Share on other sites More sharing options...
jwmyers23 Posted July 29, 2011 Share Posted July 29, 2011 It seems like as soon as I cross one thing off my list I add two more. It's a vicious cycle. Link to comment Share on other sites More sharing options...
Joel97R50 Posted July 29, 2011 Share Posted July 29, 2011 Install my EMU springs Purchase 31 x 10.50 tires Install manual hubs Install Rock sliders. Maybe a winch someday. Link to comment Share on other sites More sharing options...
Towncivilian Posted July 30, 2011 Author Share Posted July 30, 2011 It seems like as soon as I cross one thing off my list I add two more. It's a vicious cycle. I agree. I've knocked out two things on my short, easy list in the span of about 2 months (damn I'm slow) but now I need to replace the PSF with some M1 ATF, try to fix my clock by reflowing some solder, apply some grease to my back hatch struts where the cup snaps into the ball, fix the ashtray light and grease its rusty hinge... all easy stuff, but it's still that many more things to do... You guys all have such big plans compared to me, but then again I'm a poor college student and can't afford the nice things you all do Link to comment Share on other sites More sharing options...
