What's on your to-do list?
Towncivilian
I don't recall seeing one of these threads, and since we've got "What did you do to your Pathfinder today?", a "what's on your to-do list" seems like a nice companion.
Anyway, I've got:
  • Install auxiliary transmission cooler and an in-line Magnefine filter
  • Paint new bumper and driver side quarter panel (see pic)
  • Fix rust on new tailgate door, and move it down a bit so it's more flush
  • Put threadlocker on power valve screws
  • Fix this dent on my driver door somehow so it stops obliterating the door switch
I could probably get all that done in one weekend, it's not a whole lot... but I still need to get the paint & clear coat for the bumper and panel, and get some replacement bolts/nuts for my upper intake manifold since they are stripped before I can those done. I'm also probably missing a few minor things for the list since I don't write these things down, it's just a mental list.
What's on your list?
Edited by Towncivilian
-rebuild transmission (5 speed)
-pull huge dent out of a rear door
-weld on new compression rod cups
-patch holes in floor under drivers feet and rear passenger seat
-replace windshield
-replace abs speed sensor
-replace front left bumper end
-fix smashed rear left bumper end
-spray salt off bottom of truck and possibly apply some sort of rust proofing?
New bushings all the way around
New torsion bars
New Shocks
Fix rear drivers side locks and window
New tint and paint
New speakers
fix fuel gauge,rear-wiper, power mirror switch.
And new timing belt ( in about 30,000 miles)
install calmini lift
get a set of slider from Mr510
replace hydro/slack adjusters
replace egr valve
replace o2 sensor
install complete exhaust system including headers
figure out why the f'in tach keeps wierdin out, speedo shop says it works fine when they bench test the cluster for 10 miles :shrug:
finish weeding the flower beds in yard
spread moss out
go buy more chickens, dont laugh chickens are cool as hell :aok:
and there is more but im sure im forgetting some :/
  • re index torsion bars
  • replace egr or bpt valve
  • replace a/c compressor with quiet one
  • replace drivers door, hood, and tailgate with rust free ones (have them already)
  • install headers (sitting in garage)
  • new tires
  • take it back to the glass shop because the windshield leaks
  • change lifters
  • remove AT from parts truck and tear apart
  • fix rust under rear seats and rear quarters
  • figure out what to coat frame with
  • new center link
  • install idler arm brace (have already)
  • alignment
  • paint trim
  • replace rear bumper (again) with spare or build custom
  • sliders
  • skid plates
  • winch
  • lower control arm bushings
  • install volt meter and new trans temp gauge
  • install oil filter relocation kit
  • replace heater core and possibly radiator if funds allow
  • change universal joints
  • change rear upper link bushings
  • change pinion seal
  • full fluid flush
  • figure out what im going to do to utilize the arb mounts that attach to the factory bumper spot
Wow that is a long list. There is probably more too.
Edited by adamzan
Will try to make it short
-finish making links
-finish 3 more mounts 4 links
-finish coil bucket mounts
-Get last IFS bracket off frame
-figure out how im going to mount shocks
-make winch bumper
-make front drive line
-remove leaf spring hangers
-reassemble as 3 link
That is leaving off a ton of stuff but enough for now.
Too much :D
I have stages I'm planning.
First:
- Install efans
- Timing belt / water pump
- Trans cooler
- Upgrade alternator (possibly)
- Install skidplates
- Finish sound system
Second:
- Install levelling spacers
- Manual hubs
- Redo front brakes
Third (aka things I'd like to do but have no plans to do in the immediate future):
- Bumpers
- Cams
- Reflash ECU
Ultimately I'd also like to cut my fenders to run 33s and install mudflaps and fender flares but I'm not sure really when or what I'm going to do there. Might just keep the 31s in which case I won't cut my fenders. I'm undecided on which course to take though. Part of me always wants to go bigger and better, but my truck is my daily driver and sees almost exclusively pavement right now.
Edited by Zibi
Oh man... :D
Reindex the torsion bars
Undercoat
Oil change
Trans cooler/ATF change
Replace an exhaust gasket where the local grease monkey half welded the pipes together
Driver side door hinge
Tinker with the headlights/install driving lights
Then I need to actually take it off road.
Priorities have changed a bit.
Fix frame rot.
Undercoat.
Undercoat.
Undercoat.
Fix exhaust.
Trans cooler.
Lights, maybe.
Probably more undercoat.
Edited by Slartibartfast
  • 3 weeks later...
  • new tires
  • take it back to the glass shop because the windshield leaks - Done
  • change lifters
  • fix rust under rear seats and rear quarters - Done
  • figure out what to coat frame with - Done
  • new center link
  • alignment
  • paint trim
  • sliders
  • skid plates
  • winch
  • control arm bushings - Done
  • change universal joints - Done
  • full fluid flush
updated
I used the black asphalt undercoating from CT. And then I painted it with some rust paint. There are a couple different kinds of undercoating in the same aisle. I got the paintable one. I use fluid film on the inside.
Cool. Paintable sounds like a good idea... I saw that asphalt stuff and I just thought "sticky." How do you apply the fluid film?
It comes in spray cans. I empty 3 or 4 of them into the frame via the access holes after I've power washed it out. It is like 14.99 a can at CT. I saw at TSC that you can buy a paint can size version but I would need a way to spray it.
Gotcha. I guess it doesn't get absolutely everywhere in there, but better than nothing.
  • 1 month later...
It seems like as soon as I cross one thing off my list I add two more. It's a vicious cycle.
I agree. I've knocked out two things on my short, easy list in the span of about 2 months (damn I'm slow) but now I need to replace the PSF with some M1 ATF, try to fix my clock by reflowing some solder, apply some grease to my back hatch struts where the cup snaps into the ball, fix the ashtray light and grease its rusty hinge... all easy stuff, but it's still that many more things to do...
You guys all have such big plans compared to me, but then again I'm a poor college student and can't afford the nice things you all do :headwall:
