More Horsepower!
1994pathfinder
There are no "quick" and/or "easy" ways to make noticeably more power in these motors. A decent intake AND exhaust will help a little bit, but without getting into ECU reprogramming and cams, they just don't make a whole bunch of power.
That said, in my case, I figure with the modifications I've done (headers, hi flow exhaust) and a K&N drop in, I've probably brought my 14 year old truck back to factory spec for power output. I may be harnessing ALL 153hp now. :tongue:
Nitrous is the easiest and quikest way to get more power...But I wouldnt go over a 100 shot on any stock engine...
But a cold air intake and exhaust are pretty much the stand by on hear...
I have 2 1/4 pipe and a glass pack from the last cat back and a K&n air filter...the air filter I cant say that I noticed any more power over a paper fram one but it seems like I Have more midline torqe then the paper...but this comes at a lose since it feels like I lose some low end power.But these are the drop in filters and not cone style...
cams areanother thing,if I remember there are 2 performance style cams for this engine...But I have never tryed them so I cant give you any data or any thing...
Intakes and exhausts are the things you does first in any engine,from a 1.9 escort to a 8.1 chevy...there usally the easiest and the lest complacation(exhaust stud not counted).
But the first thing you should do if you havent done it already is a simple tune up and fluid change.
You going to race your truck, wheel your truck or just dyno it...
Skip the Nismo cold air intake, you can get a snorkel for that price which gets you totally away from the engine bay.
Headers, high flow exhaust are all somewhat strait forward upgrades. If wheeling get a locker as horsepower spinning tires gets you nowhere.
If you want to race get a Z...
Welcome to NPORA :welcome:
Better than my friends volkswagen jetta that has a 90hp engine. Now THAT is gutless.
But they can be made fast...
a guy I knew had a 4 banger 91 escort and and changed it from fi to carb and made like 210 hp(a lil bit up from the stock 92 hp...but it ate trannys...
I have a buddy with a turbo chevette (scary @ss ride) looks like a piece o crap until the hood is popped.
I only went for 1 ride and that isn't for me; like a rocket tin can.
headers + a JWT S1 or mild schnider cam is prolly the best way to wake up your vg in a hurry.
If you do it all yourself prolly under a grand.
Edited by MY1PATH
Yeah, ive done exhaust and intake upgrades and it sounds nicer but no new power. I plan on adding cams and ECU when i rebuild the engine sense im 300 miles away from 200k :-)
My s10 makes 120 at the crank and maybe 70-80hp at the rear wheels....
the toyota yaris loaded with people is faster than my truck in 0-60.
Try the Z24 (available in a few pathys) that I had in my D720 (kingcab 4x4) 106hp at the crank, fresh. Imagine it at 160,000 miles... :D Damn thing never died though...
so you want more horsepower? the quickest way is to buy a faster car :D
*snort*
Or a tow vehicle... :D
I had my pathy on a dyno.(with headders)
103 HP and 133 ftlbs to the wheels.
if you factor in about 20% drivetrain loss for the 4wd tranny thats about
130 HP & 165 ftlbs to the crank
and the original rated output for the CA model vg30i was less than
135 HP & 165 ftlbs crank
So I'd say my pathy has held up fairly well with its 235+ miles on it but still leave a bit to be desired...
Quick power?
Step 1. Open hood
Step 2. Remove radiator cap
Step C. Push truck from spot
Step 4. Push a car with power into spot
Step Square. Re-install radiator cap onto new car
Step orange. Close hood
Step 7. Turn key and enjoy!
Or...engine swap?
And you don't know power like a KA powered HB on 31"s with a bad head gasket dumping coolant into the block. I did have a Yohimura carbon fiber silencer off of a GSXR on it for like a month... that added awsome hp!
umm 314 XXX and counting
and on another note has anyone used those cams from 4x4parts?
yeh, a guy on N4W used the mild cam on his fronty. Search there and you will find. I think he had very slight lope @ idle and the power doesn't come on untill after 3k rpm IIRC which is how he liked it. yeh its a 3.3 but its the same cam for the 3.0.
Imagine losing more bottom end w/ the 3.0 since there is less dispacement to overcome...
