John Boy Posted August 5, 2006 Share Posted August 5, 2006 So I was wondering can you get that oil filter from the top :confused: Link to comment Share on other sites More sharing options...
88pathoffroad Posted August 5, 2006 Share Posted August 5, 2006 Yup. I get mine through the fenderwell. Link to comment Share on other sites More sharing options...
John Boy Posted August 5, 2006 Author Share Posted August 5, 2006 Yup. I get mine through the fenderwell. Did you use a oil filter wrench or the cup? Link to comment Share on other sites More sharing options...
SC88Pathy Posted August 5, 2006 Share Posted August 5, 2006 88 has a body lift, which makes getting at the :furious: oil filter 10 times easier. I have been meaning to get one of those oil filter cap things that will attach to a ratchet for the nissan filter but I have yet to actually do so. So far I usually end up taking a big slip joint wrench and loosening it from above that way. Also (on my 88) it looks like there's enough room for you to remove the filter through the fender (if you take off the rubber gap gaurd) but mine just barely gets hung up (with the stock Nissan filter). Link to comment Share on other sites More sharing options...
88pathoffroad Posted August 5, 2006 Share Posted August 5, 2006 Did you use a oil filter wrench or the cup? I use a band wrench. There's lots of room in there now! Link to comment Share on other sites More sharing options...
FLApathy Posted August 5, 2006 Share Posted August 5, 2006 I go in from the fender well, i have no BL. Also get some sand paper and wrap it around the filter, makes getting it off and on and ton easier. Link to comment Share on other sites More sharing options...
90seven Posted August 5, 2006 Share Posted August 5, 2006 I find it easier to just use the FRAM O/F with the grip on the bottom. Link to comment Share on other sites More sharing options...
GrimGreg Posted August 6, 2006 Share Posted August 6, 2006 I put them on and take them off by hand, no wrench needed. Link to comment Share on other sites More sharing options...
88pathoffroad Posted August 6, 2006 Share Posted August 6, 2006 I find it easier to just use the FRAM O/F with the grip on the bottom. Ew...stop using the Fram filters. They're poorly designed and have been known to fail, letting dirt and debris shoot right through the engine. There's a reason they only cost like $4... Link to comment Share on other sites More sharing options...
wheelmanLS1 Posted August 6, 2006 Share Posted August 6, 2006 I put them on and take them off by hand, no wrench needed. Me too. I have a pretty sturdy grip so that's what I did. I have a couple of burn scars from the exhaust manifolds too. Link to comment Share on other sites More sharing options...
RedPath88 Posted August 6, 2006 Share Posted August 6, 2006 I put them on and take them off by hand, no wrench needed. Yep. same here Link to comment Share on other sites More sharing options...
unccpathfinder Posted August 6, 2006 Share Posted August 6, 2006 I put them on and take them off by hand, no wrench needed. me too...cept last time i had to use my roomates filter wrench to break it loose...i donno how it got on there so tight...i go strait in from the top and pull it out right up by the fuel filter... Link to comment Share on other sites More sharing options...
FLApathy Posted August 6, 2006 Share Posted August 6, 2006 Me too. I have a pretty sturdy grip so that's what I did. I have a couple of burn scars from the exhaust manifolds too. yeah me too, im 6' 2" and 230 pounds but I put them on so tight sometimes I cant get it back off 3000 miles later and they ALWAYS seem to get oil on them some way or another so now I use the sandpaper as a guide, i just get it tight with that and its done. Link to comment Share on other sites More sharing options...
Filthy Luker Posted August 6, 2006 Share Posted August 6, 2006 BEST $43 you'll ever spend! Link to comment Share on other sites More sharing options...
Eli Posted August 7, 2006 Share Posted August 7, 2006 BEST $43 you'll ever spend! I second that :-) Mine's *in* my fenderwell! Link to comment Share on other sites More sharing options...
zack1978 Posted August 7, 2006 Share Posted August 7, 2006 I put it in and pull it out from the top. Zack Link to comment Share on other sites More sharing options...
RedPath88 Posted August 7, 2006 Share Posted August 7, 2006 they ALWAYS seem to get oil on them some way or another Do you prep the seal with oil before installing? Link to comment Share on other sites More sharing options...
cdhicks99 Posted August 7, 2006 Share Posted August 7, 2006 Ew...stop using the Fram filters. They're poorly designed and have been known to fail, letting dirt and debris shoot right through the engine. There's a reason they only cost like $4... I ran a parts store for many years. We cut several filters apart and I will confirm, FRAM IS THE WORST FILTER MADE! Link to comment Share on other sites More sharing options...
unccpathfinder Posted August 8, 2006 Share Posted August 8, 2006 Do you prep the seal with oil before installing? i do... Link to comment Share on other sites More sharing options...
Casey.T Posted August 8, 2006 Share Posted August 8, 2006 I like my Relocation kit so far on my 91.... Link to comment Share on other sites More sharing options...
FLApathy Posted August 8, 2006 Share Posted August 8, 2006 Do you prep the seal with oil before installing? i do, but i get oil on my hand it then its just a mess from there Link to comment Share on other sites More sharing options...
RedPath88 Posted August 8, 2006 Share Posted August 8, 2006 Ahh ok.... may I recommend hand cleaner and towels Link to comment Share on other sites More sharing options...
zack1978 Posted August 8, 2006 Share Posted August 8, 2006 (edited) I have never run anything other than an OEM filter on my Path since day 1, or 170,000 miles. I guess the OEM filters are good? Zack Edited August 8, 2006 by zack1978 Link to comment Share on other sites More sharing options...
cdhicks99 Posted August 8, 2006 Share Posted August 8, 2006 OEM is usually made by a major company probably WIX, so yes carry on soldier. Link to comment Share on other sites More sharing options...
zack1978 Posted August 8, 2006 Share Posted August 8, 2006 OEM is usually made by a major company probably WIX, so yes carry on soldier. Is the OEM filter made by WIX? Anyone know? 15208-55Y00 Zack Link to comment Share on other sites More sharing options...
