nismothunder
Everything posted by nismothunder
  1. I say top it off with fresh stuff and seafoam. Then run it till the filter starts too clog. I've ran gas that looked like antifreeze without issue and odd cocktails. If it'll burn a gasser will run on it.
  2. Note, I could get my 3.0 too bark the rears on 20 mph down shifts too first. But I have the 4.6 gearing.
  3. I'm guessing you have the TBI 305 in that Camaro. Then you have 170 hp. The LB9 is the Tune port 305 and the L98 is the tune port 350. FYI, the TPI 305 with a 5 speed had a more aggressive cam then the same motor with an auto. But just looking it seems the 3.3 made 170-180 hp at 4800 rpm. My advise too you is too change the fluid in the diff in your F-body. I know for a fact that if you have an LSD in that car you should spin both off the line for about 25 feet. You pathfinder is simply a LSD rear that is operating correctly.
  4. Are you looking for just a muffler or a direct replacement with a section of pipe that will connect up/down stream of your current muffler location?
  5. I ran 1/2 inch different height tire on mine when it was stock. I wheeled the piss out of it too boot. Never broke anything. If you have a lsd rear and are worried about maybe burning the clutches up you can run it on the front. I would not worry about the transfer case or anything being hurt.
  6. ATF is the problem. Try running some Bars or Lucas in that bitch. Atf will pour out faster then generic Prestone fluid. I loved how one of my full sizes blew the high pressure line and after I replaced it and bled it, it starting leaking from the pump it self. Which is how I know that ATF leaks faster then prestone.
  7. Wheres my dawg. Sic 'em C, Sic 'em
  8. I was just going too say I could make the same part out of a peice or two of squire stock.
  9. Ban 4 or 5 coming right up.
  10. New job in the AM. Let the fun begin.
  11. The goodyear authority is a walmart special. The thread lugs will literally fall off.
  12. I thought a shop made that exhaust for him and welded it? Don't worry. He has seen the light and moved onto a blue oval monster.
  13. If there replcing the center link, master cylinder, lights, grill and all for free then yes, I would hang my own fenders.
  14. That pile should get 21-22mpg at 75. Mine did with its ultra rare oil burning vg. Mine acutally loved 10 year oil out board mix. I moved mine too put an rv in its place. I acutally forgot about it all summer. Maybe I will throw a plow on it this winter and see it the Baja's are any better in snow.
  15. Never mind I'm retarded. That's Kenny Lauters '87.
  16. I saw it a long time ago. I think theres two brothers/relative/lovers? that have a exocage one and a truggy. I think this was on NOR or something though. GG may know whom I'm talking about because I've brought it up before.
  17. What ever happen too boobs?
    1. 5523Pathfinder
      5523Pathfinder
      So do mine! Whierd!
  18. I just won an arguement wth some guyI never meet over the internet. I. Am. Legend
    1. RedPath88
      RedPath88
      Sooo... the other personalities have finally found the interwebs.?
    2. Precise1
      Precise1
      "Arguing on the internet is like running at the special olympics. Even if you win, you're still retarded."
      Just some quote I've heard... :shrug:
    3. nismothunder
      nismothunder
      Never heard since you had the stroke?
  19. Wash it out with a pressure washer. You could drill larger holes too get those flakes out.
