k9sar
Everything posted by k9sar
  1. I can open a locked vehicle with a racquetball. 1. cut a dime sized hole in a racquetball 2. to a cup of dry portland cement, add enough water to mix to a 'wet sand' consistency. 3. pack the racquetball with with the cement mix 4. Let harden/dry for a few days 5. approach the locked vehicle with the racquetball in hand 6. Pretend you're Roger Clemens and throw the ball as hard as you can through the side glass
  2. also... that crap needs to be added to a full tank (or added then the tank filled). If your tank was low, you're running too wierd of a mixture
  3. first thing is to check your ECU for error codes (search for it ). It definately sounds like a fuel problem and could be the fuel pressure, filter or possibly the injectors. The VG30 will run on 3 cylinders if you let it (not well but it will) so the chance of 3 or more injectors going out at the same time is unlikely. how'd it run before you put the gumup in it? Any chance you used th wrong stuff for the wrong application? Have you checked your MAF? You can pop the hood, have someone start it and you can wiggle the wire/connector on the MAF to see if it makes a difference. If it runs rough always as opposed to running ok for a little the dying, maybe it's the timing. There are a few things to check but first is the ECU. Keep us posted as to what you find and we can continue the diagnostics and hopefully help others who may have similar issues
  4. wow... someone revived this thread
  5. canola oil would be a nice alternative to coke
  6. yes. look on page 1 for the ebay search. I think there are a couple that show up
  7. k9sar
    LF axle
    I'll have to try that when I do the drivers side
  8. k9sar
    LF axle
    the hardest part was seperating the tie-rod. I couldn't seperate the ball joints so I just unbolted then from the control arms.
  9. k9sar
    LF axle
    front axle? easy. I just did mine 58 bucks from the parts store and about 2 hours of work. linky
  10. I think that's my problem. I was gonna throw 32's on but my rims won't handle them. I'll have to go with 33's, keep my rims and drop some change on a body lift for clearance
  11. I try to run in 2wd when I'm wheeling. If I can't make it, I click into 4
  12. I use the gas pedal. never been stuck on the hitch yet.
  13. there's a lot to be said for being able to get out of a snow drift by staying nice and warm and dry and just throwing a lever. Would suck to have to crawl out, dig down and freeze my fingers locking my hubs. of course, the first time I blow apart my autos, I'll change my story
  14. the searching wasn't too bad. The dogs did most of the work. Body recovery never got interesting though.
  15. former. I led a k9 SAR team for about 3 years while I lived in New Mexico.
  16. I have one off my 95 that I'm not using since I bought the black panthers. What's your location so we can give you estimates on shipping etc.
  17. ROFL Mr. P! Your terminals are nicely attached using heat shrink sleving. I should post a pic of mine.... they used masking tape. not electrical tape, MASKING TAPE!!!
  18. I have a 95. I'll pop out at lunch and look for you. ok... my switch is installed with the indicator light on the uphill side and the diagram on the downhill. there are 4 terminals. Holding the switch in position (but above the slot), the wires are: uphill passenger side - Purple downhill passenger side - Yellow uphill drivers side - Green downhill drivers side - open (no wire) hope this helps
  19. my point dealt more with the 'qualified mechanic' rather than the actual suspension. I checked the play in all the joints and found that my drivers side lower ball joint was out of spec with respect to the amount of play in it. Actually, it kind-of rattled around rather than trying to point upright. That was MUCH cheaper than replacing the C-link which was 'just a guess' from the mechanic though they'd be more than willing to replace it for me for a price.
