Precise1
Moderator-
207
Everything posted by Precise1
Yep my 95XE has HG43... V6, you sure SW didn't just miss read the 3 for an 8, he seems to be the only oddity here... B
That is very odd... I've not heard of a problem like this before. I'm still not sure it is the ECU. Any chance that it got wet recently ?? As for the blinking, thats how you read it while in diagnostic mode, but I think you mean something different. Here is the link just because... http://www.nissanpathfinders.net/forum/index.php?showtopic=21 Sorry that I'm not much of a help, but I'm not that good with electrical issues compounded by not being there... Maybe that wire shorted something ? You may have to take it to a good shop. B
Yep, yep and yep. I'd pull a few plugs to see what they look like also... Make sure to check, play with the WIRING CONNECTOR at the MAF, many people have reported problems there... B
I saved a fellow Pathy over the weekend...
Precise1 replied to TrailChaser's topic in General Forums
Personally, thats what I figure... Anyone who takes a 2x car or truck on the beach is asking for it uless it is set up specifically for sand/mud. Sand can be wierd with soft areas and such. I've almost burried a 1500 pound (MAX) VW Baja that had 10.5x31" in the rear !! Got out by my buddy pulling on a cable that was attached to the front. That little bit was enough to get me moving and make it to harder packed sand. Damn Dowser, it actually sounds like it wasn't your buddys fault... It's yours for recovering a complete POS... B -
PARKING BRAKE !!!!!!! B -
Good point V6, I was assuming the person ramming me was my friend. If that were the case, I'd just present him with the bill after yelling and and some mild strangulation. If it were someone I just stopped to help, I'd probably fire a 12 gauge slug into their engine block for good measure. Regardless, I agree. That is a totally inexcusable and completely stupid thing to do ! To even touch, much less do serious damage is incomprehensible to me... I think the possibility of alcohol being involved is great. Thats still not a good enough excuse !! You don't have an axe ?? Need me to send one, I have several... B -
I understand the Y pipe leak issue, and that certainly wouldn't help things, but to get so hot, wouldn't you hear and/or smell it ??? I make a point of occasionally driving with the stereo off and the windows down just to hear the cacophony of creaks, thuds and squeals my truck makes to determine if anything is seriously wrong or about to fall off... B
Yes, your truck is out of crack and refuses to run... Sorry, couldn't help it... Yep, as per Simon, have you kept up on the timing belt replacement ? Just for kicks, I'd run the ECU codes, that NEVER hurts. Instructions in the Garage/How To section. B
Yow !! Thats quite a hole !! Remind me never to live in the snow/salt/rust states !! Glad you caught it before you fell through, and sounds like you are fixing it right. Please do share the picts !! Good luck ! B
Um, yeah... As has been said, please install a tranny cooler ASAP !! It'll cost about 5% of what a tranny rebuild will... Make sure to replace the tranny fluid also. To a certain extent, paranoia is good !! B
Well, thats pretty much case and point to what TrailChaser was saying... Sorry that happened 4wheeler !! While I wouldn't go so far as V6, I'd still be rather pissed off !! :furious: B -
Sleep well with your pict Simon... Don't let is come between you and the wife... B
Sun is shining in Cali !! I had my shirt off today... B
I'm thinking something on a HOT August weekend after BBQ and drinks... Maybe a lawn sprinker involved ? Maybe just a hose ? B
Oh, yeah.... *yawn* Thats just soooo... What, June'ish ?? Cripes, I have better picts than that !! B
Good job Bud ! A little help goes a long ways sometimes... I wish people would remember that. That truck would have been a total loss if you or someone like you had not happened by ! I thank you for them again. B -
Try it JJ !! PLEASE !! I'll cover you... B
I'd suggest just turning the rotors, installing aftermarket pads and braided steel brake lines up front, bleed well, etc. That should give you excellent braking as link as the master cylinder is working properly. As for after market stuff, I can't help. I have a 95 with stock rotors... I'm moving this thread to the R50 forum which may help get you some answers. B
Do you know what this loose wire goes to ? Why can you not read the ECU ? Start by checking all the main power cables, fusable link, fuses, etc. I don't understand why it would click or why you would have "spark spiratically"... I'm assuming the starter works and engages the motor. Please post any additional information. B
Good man Simon !! It sounds like you clocked the springs correctly. I'd slightly lower and level the front end before worrying about the rear. Calmini shows their drop mount in their 3" suspension package but I have no idea if they sell it seperately. You may want to call them and ask and get an idea about price. http://www.purenissan.com/wd21_3_kit.htm I'll draw something up today for you. B
I believe I saw leggo rims somewhere new for something insane like over $200 each so I'd say that if they are decent and 4 for $125, its a decent price... Personally, I don't care for them... B
Just trim levels, but even they blur... Generally speaking it's the possibility of having leather seats, seat heater, better dash gauges, 'leggo' style aluminum rims, ride adjustable rear shocks (useless in my book), roof rack, and a few other odds and ends. The rest of the truck is the same. Not easily... The hinge supports have backing plates that are in the rear passenger column. If you have no carrier, they are not there, and apparently it is not possible just to insert them without cutting metal. If you try to mount one without those plates, you'll be leaving the entire assembly on the road somewhere. More room and a nifty rear carrier that you can custom mount gas cans, hi lift jacks, shovels, whatever to... Also, you can easily mount any sized tire you would put on a Pathy. I have a 10.5x31" for a full sized spare. I don't want that inside or on the roof. My stock spare is a crappy little 215/75/15 which only goes with me on road trips or serious wheeling (so it never goes ) Out in the open is where tires live, and there is one pin drilled that accepts a 1" masterlock nicely. It would be hard to get a bite with lock cutters. I guess they could just unbolt the carrier.... B
Thule seems to be pretty popular for the modular, bolt on flexibility... B
What, the Le Baron is the Cadillac of the K cars !! I also like the louvre idea, plus, you are recycling one of the most valuable parts of a Le Baron... B
Hmm, I got nothing... Maybe just Mr Jim or 88. No worries... B
