jyeager
Everything posted by jyeager
Old-timer finally joining the SFD bandwagon
jyeager replied to XPLORx4's topic in 96-2004 R50 Pathfinders
You don't have a cut-off wheel or a sawzall? Hmmm... Have a friend cut them. For some reason, I never had a moment of heartache cutting the new springs I had purchased. But I would prefer a solution that doesn't require cutting....A simple insert for the top perch that accepts the pigtail would solve that. The WJ springs are a good option because they are so plentiful and inexpensive in different lift options. If you have found something even more plentiful, then kudos! And these have both ends identical to the Pathfinder springs? Out with it! What vehicle??? -
Well, just call or email KRFabs. Perhaps they just aren't taking the orders online at the moment for technical reasons. A lot of guys have those 2x4 blocks, ask around to see if anyone's blocks have bent. They are pretty much in straight compression, rather than sheer (except when cornering hard when doing autocross!). Consider welding them in. You could also internally gusset them if you are worried. -
This is great! I'm glad to see you doing this. I've done mine since we last talked about our trucks (back when I was newer on this forum). So there really is no one making SFD kits for R50s except for KRFabs. The reason his 'kits' don't include the rear end parts is simply because they are off the shelf components you can source more cheaply elsewhere. So here is what you will want for the rear: springs: Jeep WJ lift springs. 3" springs net you 4" on the R50. Get 4" lift springs for a WJ and get about 5.5". You can get a 5" spring and maybe get 6.5"+ Springs must have half of one pigtail cut off to fit the top spring perch. KRFabs now offers a coil spring adapter that nets 1" lift and I am assuming, lets you use the spring without cutting the pigtail? Check on that if you might want that option. Shocks: for the 4" lift everyone has been getting F-250 shocks. They bolt right in with the small exception that they need bushings to net the right spacing at the eyelet. Are they suitable for 6" lift? Sure, but if they aren't long enough, they could limit the articulation. If you want maximum articulation then look up their specs. You wouldn't expect this, but my Rancho 5000 shocks for the F-250 are not valved firm enough in my opinion. It's not bad, mind you...just not optimal. But the more expensive Rancho 9000 shocks are probably adjustable??? So you would have no problem tuning them to your liking. You can probably use KRFabs' PHB drop bracket with 6" lift, even though it's for 4" of drop. Or you can make your own if you have a welder. If you want to make your own 4" spacers for up front, you just need some square tubing stock, cut and drilled appropriately. You could get the steering spacer from KRFabs, or buy it yourself from the vendor he sources his from. I bought the kit and a few options and have no buyer's remorse. It's his 4" strut spacers that have the correct angle built in to maintain camber, that I really like and that you would probably want to buy even if you custom make the rest of the lift yourself. But then again, you were wanting a turnkey solution. So you will want his full kit and just those aftermarket springs and shocks to finish the job. -
1999 pathfinder with an annoying alarm! Help please!
jyeager replied to bolbol's topic in 96-2004 R50 Pathfinders
My guess is that the security system isn't seeing the key turning the lock cylinder and that's why it set it off. If you go over to the passenger door and unlock that side with your key it will turn off the alarm. I don't know how to simply disable the system...it might be an easy thing to do, or it might create other side effects/problems that you won't like. But it should be able to be figured out by a careful reading of the service manual and schematics. Simplest fix might be to diagnose why the security system doesn't know you unlocked your door. Might just be a bad connection inside the door. Here again the service manual's schematics will prove valuable. -
2002 Oil leak at main real seal. Serious?
jyeager replied to oklafornia's topic in 96-2004 R50 Pathfinders
That's no problem whatsoever as long as you keep tabs on your oil level and don't ever let it drop below the dipstick's hash marks. You could leave that without any concerns whatsoever....just get in the habit of checking your oil level every time you put gas in it. -
You can't adjust the bulb, but the entire assembly can be adjusted up/down left/right with the adjuster screws. If that's not a good solution you could try to take your housings apart and craft a solution. I believe you can remove the glass from the metal by heating in the oven at 400 degrees to soften the glue. If you simply scatter too much light upwards in to other people's eyes, perhaps blacking out the bottom surface of the reflector?
I may not grasp all the ins and outs of headlight design, but I would have expected the diodes to be top and bottom. With the high beams very possibly being on the bottom which would reflect off the bottom of the reflector thereby shining upward down the road.
97 SE, slight hesitation when warm. (Intermittent issue)
jyeager replied to FriedEGs's topic in 96-2004 R50 Pathfinders
"Lately, the starting issue has since gone away but now I have experienced an intermittent hesitation, mostly after the engine warms up. Basically feels like a misfire and typically happens under hard loads, such as accelerating up-hill on the freeway. The other day I was able to 'create' the misfire by jolting the steering wheel hard in order to 'shake' the truck while at medium speeds. (around 30mph)" This is what I've experienced a number of times over the years when the plug wires need to be changed. You have new plug wires, but if one of the boots isn't tight, it can create a situation where it's just a bit hard to jump the gap and will miss when the load is high, such as your uphill freeway situation. But I'm perplexed by your ability to induce it by swerving your truck! I would check in to the ignition coil and the rotor under the distributor cap. I know your distributor is newly remanufactured, but do not know the status of your ignition coil itself. I once had my ignition coil crack and my truck would try to stall when I came to a stop light. I would have to put it in neutral before stopping and keep my foot on the gas pedal. It was fine above 1300 rpms, but would stall below that...the problem was simply the cracked coil. -
CV Joint Axle issues after lift 2 inches
jyeager replied to thejazzid's topic in 96-2004 R50 Pathfinders
There are no better CV axles available. But you could always go custom if it were worth the $ for you. I keep hearing that 1.5" is the maximum safe lift. You may simply have gone 1/2" too far. You could remove the front spacer and put an equal amount of spacer inside the strut top hat. You would ride the same height, but the wheel won't be able to travel any further downward than stock and your joints would be safe. You could also leave it the way it is, but add limiting straps. Most people add front lift with stiffer springs (about 1.5" or so) and perhaps 1.5" spacer above the strut. Then, only the spacer above the strut is added to downtravel, keeping you within safe operating range, but netting 3" of overall front lift. -
Oil Leak: 3.3L Above Pan, below cam seals/valve cover...?
Put some UV dye in your oil and then a few days later look at it with a black light. -
99 Pathfinder error codes and issues with starting.
jyeager replied to cctaco's topic in 96-2004 R50 Pathfinders
Did these codes show up after you changed the plugs? Or did the starting problem show up afterwards? Is it hard to start when the engine is warm but starts right up when it's cold? -
I was going to remark about how bright those LED headlights are, then I see that you had your off-road lights on too so I don't know what to think...
01 3.5 Not blowing hot. Safe to drive?
jyeager replied to PrecisionX's topic in 96-2004 R50 Pathfinders
If you have air in the system, you can try to bleed it like this: - start the truck and turn the temp to full hot for at least 10 seconds. Turn off engine. (that opens flow through the heater core) - open the air bleed port (it's at the top of the engine in the water feed line) - remove radiator cap and fill to the top, or until coolant starts to come out of the bleed port. - close bleed port and top off radiator - replace radiator cap - fill reservoir to full mark run the engine until hot and alternate the rpms between 2000 and idle a few times. shut the engine off and allow to cool completely then refill radiator and reservoir as necessary and repeat Or you can substitute normal driving and just top off the coolant before each trip you take until all air is out, which will be indicated by no drop of coolant level when checked cold. Typically, air in the system gets forced to the radiator and stays there (since coolant is drawn from the bottom of the radiator). So bleeding out stubborn air isn't generally a concern. None of this will help you if you have an unresolved issue with your cooling system. Make sure your cooling system is sound. I suggest you find out exactly where that small leak is coming from....that might be bringing in air every time it leaks. -
Once you get over 30,000 lumens, they can vaporize the Zombies too....not just spot them.
Roof lights are self-explanatory. What are the Zombie Lights?
You say you are getting fuel all the way to the rail. How did you determine this?
*video* 01 3.5L Wont Start. Cranks hard, has fuel pressure
jyeager replied to Canadian's topic in 96-2004 R50 Pathfinders
I love a happy ending!!! Good job! -
2000 PF with Bose system front speakers popping
jyeager replied to Andrew101's topic in 96-2004 R50 Pathfinders
All looks good except for that situation where things go flakey and the voltage is being dragged down. I really can't say whether it's a problem with that device (little amp thing?) in the door, or the relay that sends the voltage there when the radio is turned on. Question: when you were measuring the voltage, was the connector still connected to the thing and you were probing the pins from the back? or was it disconnected and the probing happening at the front of the connector? So regardless, at this point, if you are more inclined to get it working even though it costs a little money, then you can get a set of component speakers and replace the existing speakers. You would only use the 2 wires providing the audio signal and the other other 2 wires feeding the tweeters. In fact, if you plan to do this, you might want to temporarily wire up those 2 wires to the existing door speaker directly (bypassing the circuit board in there) and see if they work with the other electronics out of the way. -
Hey, I installed the KRFabs SFD along with the recommended Cherokee 3" coils in the rear and I have what I consider the perfect rake. My rear is higher than the front. I haven't loaded the back down with large amounts of weight yet, but have loaded about 150lbs in the back and it wasn't any lower than the front. What did you have installed in the rear initially that didn't match your 4" front lift?
Depends. Your increased CV angle can put increased stress on your rubber boots, causing them to crack/tear early in their life. This leads to contamination of the joint and premature failure. Using manual hubs mitigates this problem and takes care of you. However, if your lift droops your front wheel far enough to physically reach the limits of your CV joint it will be damaged in one simple moment, whether your hubs are engaged or not. If you limit the downtravel of your front suspension so as to never exceed your CV axle's limit then you are fine with your 2" of lift. This will be the case if you lift with springs. They make you ride higher, but don't change the amount of down travel available. However, the downside to this is a harsher ride and 'topping out' which is when the wheel droops and BANGS at the limit of the shock travel. It's startling, but apparently not damaging. If you put an extra 2" of spacer above the strut, then I am not sure if you will exceed the axle's angle limit. If that DOES exceed the limit you could install limiting straps.
Incorrect test. The valve covers are insulted from the engine block by the gasket/RTV and the bolts don't make the continuity because of those rubber grommets. Now, it's very likely something bolts there and completes a ground, but I wouldn't be sure of that unless I tested it. You need to do it again with the threads of the spark plug touching solid, clean metal (no paint) and that metal must be something grounded to the negative battery cable (like the block....except for the paint). Although, it would probably work against a painted block because it's such high current....if it works, you've validated spark, if it doesn't....you can't conclude anything. If you are VERY careful with the distance, you could forego the spark plug threads and keep the electrode very close to a truly grounded piece of metal. You can test the metal you are thinking of using (say a metal bracket) by checking resistance between that spot and the battery negative cable with a multi-meter first just to ensure you've got a good spot to test for spark. (note: I said very careful with the distance because if electrode is touching, current will flow without a spark and if it's a little bit too far away, it won't jump the gap) Another thing....in your video of the cranking, it was cranking very slow. Your battery sounded pretty low. I just want to make sure that your battery voltage is high enough to actually light off the truck. It would be a shame to go through all this just because your battery was only providing 10 volts while cranking and you didn't realize it. -
Ok. So you measured volts across pins 4, 5 and we see lower voltage than expected (must be done with radio turned on). So now you need to measure from pin 4 to a perfect ground to see what your voltage is on that wire. That's the Red wire. See if you can get a 15+ foot length of wire and physically run it from your battery's NEGATIVE terminal to the door where you are working. Connect your meter to the red wire and the wire you have running to the NEGATIVE battery cable. You should see 12+ volts. If not, there is a problem along that wire somewhere. If that tests good (12+ volts), then check the ground wire (pin 5, black wire). Turn the multi meter to Ohms (200) and measure the resistance from pin 5 to your perfect ground wire (the one you ran from your battery NEGATIVE over to where you are working). You should see 0 Ohms or very, very close to 0. If not, then your ground connection is the problem. Just make sure not to touch this temporary cable that you have to any live wires carrying voltage or you will blow a fuse somewhere. Connecting your multimeter leads between this wire and a hot wire is fine. -
Exactly how did you confirm you are getting no spark? -
Ok. To measure volts put the voltmeter on the DC 20 setting, not the 200 mv setting you've been using. Since touching things in there makes them work intermittently, then I will say that you probably have a bad connection in one of the shared wires. If you look at the wiring diagram you will notice that each front speaker has 6 wires running to it. The wire at pin #4 is the one that supplies 12v power when the stereo is turned on. If you probe across #4 and #5 (the ground) you should see 12.6 volts (without engine running) or 14.x volts with engine running. If not, you have a problem with your power or ground wire...and both speakers take 12v and gnd from the same source wire somewhere under the dash. The wires at pins #6 and #2 won't be the problem. Those are the signal wires from the stereo and they are completely independent from each other from side to side...but your speakers kick in and out together which leads me to believe the problem is with the shared power or ground wires I mentioned above. And the other 2 wires just run up to the tweeter and the tweeters are kicking in and out together with the door speakers. So check the connector on the driver's side speaker and make sure all pins are fully seated in the connector, free of corrosion, and tight fitting.
