PATHRIDER
Everything posted by PATHRIDER
  1. my1path knows his stuff..A lot of the guys here does and hes always been the one to answer questions immediately when a newbie like me is in need of some answers. Thanks man
  2. how about something simple to start things off..A Panhard rod drop bracket. I just dont see paying almost a $100 for those..Calmini is the only one that makes them that I know of and at $70 plus an outrageous $28 shipping
  3. You might wanna check the ecu and see if its gotten wet
  4. I was thinking of having one made out of lexan..Im kicking myself for selling the factory thumbscrew I used to have...I totally forgot my wifes pathy has a sunroof without covers and that screw
  5. Ben I was just reading up on my1paths thread last night about the distributor..Lemme look for it
  6. Thanks for the quick reply guys.. Ive been drying it for about a week now and the battery was also disconnected and sitting on the bench also.I had the battery fully charged at my local battery shop coz it was completely drained when I got my pathy back I used almost a can of electronic cleaner then I dried it off real good and every other day I would give it a few shots of air. Im hoping that it works. Im also going to shoot some electronic cleaner on the plug.I just noticed this morning when i looked inside where the pins goes in ,theres some dried up mud on there so just in case its fried I can use any ecu from 90-95 with auto trans,4x4 mpfi and stay away from maxima ecu's? I appreciate you guys help. I was going to give up on the pathy and get a xterra but with all your help I think I can get her back and running again :beer:
  7. Hey guys what should I be looking for in buying an ecu for my 93 pathfinder? does it have to have the same numbers or can I use one off of 90-95 as long as its for auto? My ECU was just drenched when I pulled it out last week and its been drying in the basement since then. I pulled the top lid off and dried it with an blowgun. It doesnt have any burnt smell to it . Can I still use it after its been soaked in water inside and dried off? Im going to try to fire up my pathy maybe tomorrow or monday soon as I get the ignition switch installed and shift lock cable..with the ECU being soaked like that could it have damaged any other sensor or electrical components? Thanks fellas
  8. Found this online. Its a mini version and measures 11X23..Real cf for $87
  9. Thanks. Ill keep that number just in case..Dallas Fort Worth area
  10. I found that one yesterday but I thought theyre in Texas
  11. do you think that can be moved forward towards the front?
  12. I wish theres a hoodscoop available for our pathys..a small one though that can be mounted just above where the cone filter sits.I wouldnt mind cutting up my hood as long as I get a scoop thatll look factory on there and can be mounted with bolts from underneath and not one of those fake scoops that just sticks on I think ive seen a terrano before on here that has that
  13. man what a big difference on how it drives now bud without the auto hubs engaged...hahaha..I dont do any freeway driving and the fastest I go is probably 40. Im going to check the shifter linkage come monday ...ill keep you guys posted ..Thanks fellas :beer:
  14. Would you happen o have the direct link please
  15. ill be installing a manual locking hubs tomorrow and would it be safe to drive it with the hubs unlocked till i get a day off to fiddle with it? Ill check for those things you mentioned bud and will keep you guys posted
  16. im going to try shifting it while driving tomorrow and if it doesnt shift ill take it to a tranny shop and see if they can adjust the linkage or see whats going on with it..thanks guys
  17. I feel so stupid right now..Im in 4H all this time and just found out today at the emissions place. The tcase @!*%er wont shift up anymore and its almost hitting the bottom of the radio bezel..could the tcase be bad that it wont shift back to 2h anymore...im pushing as hard as i could with the transmission in neutral and wont push up anymore. when I bought the truck i didnt even bother to check the tcase...took it for a spin and it ran fine except for the exhaust manifold leak that is now fixed
  18. got if figured out ..Thanks Rob
  19. speaking of which my hardbody has 2H and 4L but no 4H..could it be a bad t-case guys? oh and no lights on the dash either..might be a bad bulb . I tried shifting on 4H and the truck wont move..its like its in neutral
  20. Been trying to locate where the end of my auto shifter cable goes to.. Its the cable on the right hand side (pasenger side) of the shifter.just found out today that it was just tucked under the dash and my shifter shifts even without depressing the brake pedals..It was probably yanked by the thief who stole my truck... Any help is greatly appreciated thanks guys
  21. arrggghhhh..just when i thought im done with junkyard hunting...now i gotta do this mod awesome mod guys
  22. I tried to put sparco on mine and it didnt work..too wide...You wont be able to close your doors ..It would probably work if you take the center console armrest out. The problem I ran into is the left side of the seat is hitting the armrest and if i move it towards the door to clear the armrest it hits the door handle. I was told that a 2004-2008 subaru wrx seat would work and those I believe are sparcos
