10
Everything posted by Terranovation
When you have to sit on 55 mph (88 km/h) to wait for the trans to heat up enough to get into torque lock up...and everyone else is going by you.
Best song that suits your Pathy
Terranovation replied to Terranovation's topic in 90-95 WD21 Pathfinders
http://www.youtube.com/watch?v=sn40grWkK8w This is good one too -
I like it a lot! -
For me it's the Hulk Hogan theme song. It had a tough, rugged beat and sounds good whether I'm on/off road. I don't know why but it just fits.
I like how there's a space under the bonnet for coolant container lol. Police officer "Uh, what's that doing there?"
Why would you have to take the carrier off? Can't you just tap screw the holes with the carrier on there?
It's all good, running at 12.1v at a stand still, 14.2v while running.
You shouldn't have a problem with doing that, you wash that area when you do a regular wash on the outside with the flap closed although it might have been a better idea to be careful and clean inside that area with a quick spray of degreaser and wipe clean with paper towel, just to avoid any possible water entry. Anyway if you did get water in the fuel system you have a warning light for that to let you know to drain the fuel pump? I do on my '91.
I'd use a big flat head screwdriver and rubber mallet, just go around the edge slowly and don't hit too hard, once you get one edge loose, you should be able to get a couple of fingers in the edge to pry it loose but I advise having an old pillow or something soft for it to land on, just in case it does fall.
They are good fire lighters for the fireplace too, smokes a bit but it heats the timber up quicker.
Gauges and filter relocation recommendation
Terranovation replied to txpath4x4's topic in 90-95 WD21 Pathfinders
If you have the altimeter you could always unscrew that and utilise the plastic pod to put gauges in there if they fit. I modified mine, I took out the altimeter and now I have my gps mounted in there. Had to cut a slit in the top of the pod so it, ahem, just slides in there and I can remove it so thieves don't know what was in there to steal. I do eventually want to put a temp guage in there, I've been looking at some cool led gauges. -
THE MRJIM PATHFINDER HAS BEEN STOLEN FROM SNOHOMISH, WA
Terranovation replied to MrJim's topic in General Forums
^ this is what I was thinking too, it just may be that someone from this forum, god forbid, found out where your Pathy would be, scoped it out and took it when the time was right. I hope that no one from this forum would or could be that low to do such a thing as steal another members ride. -
Thanks yeah I will get the battery tested to make sure it's at 14 volts. Il take it down to the auto shop on Saturday they do free battery analysis.
Inform the police ASAP although I'm sure you've done already. -
Also thank you my beautiful wife for helping me and standing with me in the dark
She's alive again! I bought a new battery and I had the bonnet up, worklight on and everything because I needed to have it fixed for the morning and it was dark. Neighbour sees me outside with the work light and he comes over for a look. He says check the cells so I did and the battery is almost totally dry. So he says boil the kettle and then fill up the cells, so I did. He went and got his jumper leads and we hooked up my battery to my wife's car, the Terrano starts so my spirits lifted thinking everything was ok. Neighbour says run the car for 45 mins to get the charge going in the battery and then turn it off, wait 10 mins and then try starting it again. So I put the new battery in the back and my tool box, went for a drive down to the service station. Lights were very dim and she just about died while I was driving. Pulled into the servo with hardly any lights at all. Tried starting again and yep, the battery was totally snaffooed. So I put the new battery in and tightened everything up, starts first go and lights are bright. Turned it off and tried again, vrooom, so it was definitely a dead battery, with fried cells. My lesson learned here is check the cells distilled water level at least every 6 months, especially during summer, because I never checked the battery for 2 years. It's just something I took for granted and I paid the $199 price. Thank you to all for your advice and helping out!
Thanks Nefarious, Il check the battery terminals and see if I can fill it. I definitely think the cold chilly weather killed it though, it was 49 f this morning.
Hi guys, I went to start up this morning, it was very cold and the engine tried cranking over but I got a ticktickticktick noise. I tried starting like 5 times with the same thing. I'm suspecting the battery is dead and I'm hoping it's not the starter or alternator. Lights still work inside, dash lights etc but I've been told yes they will still work but the engine needs more power from the battery to start up. Because I'm at work I can't diagnose the battery but it's been at least two years since I bought the last one. Il start off by getting a new battery and see if it works.
This is truly bad news, the people that did this are SCUM and I hope those responsible PAY FOR THEIR CRIME and do the TIME. On behalf of myself and all Australian Npora members, our thoughts are with you man. I hope your pride and joy is returned all in one piece. -
In Australia on our outback highways the maximum speed limit is 110 km/h
One thing I did notice about the old used oil was when I had the drain pan standing up draining into the oil container. Majority of the oil had already drained into the container and the drain pan had a coating of black oil still clinging to it, even after 2 hours. So I thought to myself that's what the inside of the engine must be like too, even after a whole night draining. There might be no drips coming out, but the stuff is still stuck in there somewhere. Next time I will definitely try filling up with cheap oil then change that and fill it up again which should get rid of most of the black stuff.
Here's some more investigating I did, I used an engine flush on my wife's Nissan Navara, poured the stuff in, idled it for 15 mins like the can said, drained the old oil overnight, the oil was very black. Installed new filter and put fresh oil in, checked the dipstick and it's already got black oil on it. So even after using this 300ml can of engine flush, it didn't get everything sparkling clean inside. Much to my surprise because this engine flush wad meant to be the best one you can get. The name of it is Liqui-Moly. On the can it says 'Removes oil sludge' Hmm that's interesting. Apparently it is a blend of Molybdenum Disulfide, which to me is a fancy way of saying kerosene. On the can it also says 300ml is sufficient for 5 litres of oil. Well in this case it obviously wasn't effective enough. I don't think even three cans would remove everything. I was expecting sparkling clean dipstick. I think kerosene or ATF would have been more effective. So next time I am going to drain the old oil and run a 30% oil, 70% ATF mix and Il report back with the findings.
Terranovation replied to RedRider3141's topic in The Garage
Gave mine a much needed bath, it's been ages since the last time I cleaned it. Drives better when it's clean. -
No, sludge doesn't form in the cylinder, it's carbon deposits. Engine flushes don't remove carbon deposits you have to see a specialist for that type of carbon removal but a lot of people don't think it's a good idea because the carbon buildup keeps the cylinders sealed preventing blow by.
