10
Everything posted by Terranovation
What is PO?
Weird A/T flashing sequence
Terranovation replied to Terranovation's topic in 90-95 WD21 Pathfinders
Update - I took the engine protect metal cover off underneath the front and found a loose transmission hose so I tightened it up. Must have been loosing vacuum pressure, hence the flashing sequence. I degreased everything too so I can check later for any leaks. -
Don't attempt it, you'll end up tearing the foam seal. I tried pulling mine apart and the seal started tearing a little so I quickly put the clips back on before I destroyed anything else lol
I had a look at the back inside panels of my Pathy today and I forsee a problem with fitting. The back panels curve inwards so you'd have to bend the curtain rods slightly so they clip into the rod holders because when you screw the curtain rod holders on the back panels, they're gonna be on an angle as they follow the curvature. The panels directly behind the seats, no problem because they are straight. Also you would have to trim the velour so it goes around the curves of the rear speakers.
95 pathfinder tranny shifting funny need help
Terranovation replied to billpittman's topic in The Garage
The only other thing I cam think of, if it's not engaging D until after 20 seconds and you keep having to select '2' to start driving, then the bands inside possibly need adjusting, the gears aren't meshing properly and I empathise the word Possibly. I don't wish these type of repairs on any Pathy owner. It can cost anything from $1,000 up to $2,500 for a total trans rebuild. -
Thanks guys, I went for a nice long drive today and everything is normal. It's shifting nicely as usual. I think the problem is that I'm not getting all the old fluid out via just the drain plug, I need to flush out whatever is left in the torque converter too. -
My idea for a cover - 4 curtain rod hangers 2 curtain rods Cover material Strong glue This would be a good project. My plan for one is buy four curtain rod holders, they are shaped like a U. Usually when you buy them from hardware store they are white but just spray them to match vehicle interior. Measure everything up so you have the right width and height. Screw rod holders in. Then you need two metal curtain rods. Just cut to length with hacksaw. For the cover material I'd choose something that will last a long time and look nice, something like black or grey velour. Colour code it to match the interior, whatever your choice may be. To fit the cover, get some really strong glue and slap it on one end of the material and wrap it tight around one of the curtain rods. Do the same to the other end and wait 24 hours for it to dry. Clip the rods into the holders and there you have it. Your own cover that saved a heap of cash.
My idea for a cover - 4 curtain rod hangers 2 curtain rods Cover material Strong glue This would be a good project. My plan for one is buy four curtain rod holders, they are shaped like a U. Usually when you buy them from hardware store they are white but just spray them to match vehicle interior. Measure everything up so you have the right width and height. Screw rod holders in. Then you need two metal curtain rods. Just cut to length with hacksaw. For the cover material I'd choose something that will last a long time and look nice, something like black or grey velour. Colour code it to match the interior, whatever your choice may be. To fit the cover, get some really strong glue and slap it on one end of the material and wrap it tight around one of the curtain rods. Do the same to the other end and wait 24 hours for it to dry. Clip the rods into the holders and there you have it. Your own cover that saved a heap of cash. When dry, pl
It would be fairly simple, just get a drilling bit specifically for drilling metal, buy a couple of grease nipples. Drill the holes out a bit larger then screw the fittings in then grease those babies. It would last the lifetime of the vehicle opening and closing. You'd probably have to open and close it a million times before the grease wears out.
My Terrano 1991 turbo diesel with auto has this trans switch on the lower left side of the dash display that has power mode/a/t/hold on it. I understand how this switch works. My question is, sometimes when I start up first thing in the morning, it flashes green on the power side, then flashes about 12 or 13 times on the 'hold' side. It happens every now and then, what does this flashing sequence mean? The transmission has clean fluid in it and the engine is regularly oil changed by myself.
Cleaning the throttle body may help. Carby clean is needed.
Yeah well if it's smelling like swamp water or burnt leaves, expect there's crud built up in there. Remember to wear gloves in case of hidden nasties like bees, spiders or even furry rodents! Vacuuming is the best option imo.
If it's got an overdrive button on the selector lever, make sure it's not pressed in when you drive off. It will be slow as a stuck pig. Only activate overdrive when you get up past 30 mph -
Location and replacement of warning chime
Terranovation replied to path90bill's topic in General Forums
Location - driver side foot well. Refer to here - http://www.nissanpathfinders.net/forum/topic/36071-where-does-this-connecter-go/?hl=chime -
That looks reasonable for being original part used for 259k miles. It's maybe got another 2 to 3 years to go before it's completely stuffed imo having worked in the exhaust industry.
My simple yet effective tip is when removing the oil drain plug and you don't have any gloves handy so you don't get oil on your hands, undo the plug with your ratchet till it's loose, them remove the ratchet and unscrew the plug the rest of the way while holding onto the metal bar with socket still on. As you remove the plug pull the socket down and hopefully the plug will remain in the socket for you to drop into a clean paper towel and your hand and arm should be oil free. Some may not agree with this procedure but it works for me.
Clogged cats cannot be washed out with dish soap and water - I used to fit exhaust systems back in the day and we would oxy cut open dead catalytic converters and inside them is a honey comb material which the exhaust gases have to pass through. Nothing you can do once it's clogged - you replace it.
I noticed you mentioned the battery was put on charge. Usually after a charge, batteries have a tendency to not last for much longer. How old is the battery? The average life of most batteries is 3-4 years and that's it. I'd start by replacing the battery instead of wasting money going and getting professional cleaning etc. It might just be the battery that is responsible for the unusual power loss re low rpms
Cleaned mine out a couple of months ago. Handful of leaves in there, some of which looked black like the resistor had singed them. I also vacuumed everything else that was stuck in there like little pine twigs. Pulled the blower motor out while I was down there and cleaned out a couple more pine twigs and cleaned all the little fins on the mouse wheel using degreaser and an old toothbrush. To finish, I sprayed lots of air freshener up in the holes and now my air con is actually stronger than before and smells a whole lot nicer too! I'm going to do this inspection every six months now as part of normal servicing.
Terranovation replied to RedRider3141's topic in The Garage
Received a new left hand rear tail light now just need some time off work to pull out the smashed one. How it happened - reversed into a shopping cart at the shops. Went to junkyard, guy behind the counter wanted $100 for a 2nd hand scratched up one. I did some hunting online and found www.autopartsmate.com.au they have aftermarket parts. Not original tail light but looks exactly the same thing. -
I've used the metal retainer like two times since 2005. Since I discovered how to properly lubricate the hinges, I think I might be using the metal retainer more often. My tyre carrier is freed right up. ATF seems to not only lubricate but it works as a cleaning agent too it seems
Yes I know but who ever uses that lol. I remember the first time I saw that little do hicky I was like why is that there...oh to hold the frame open, doh!
Also watch the wind doesn't slam it into your back as you are loading stuff. I nearly got squashed by mine the other day but my Bruce Lee lightning reflexes blocked the swinging bar
Mine sits on 750 when I start up, when warm it's at 800. Also remember when in P or N the revs should go up a little bit. It should be noticable.
Hmm very nice and shiny. I see you are skilled with wax on wax off, ahardbod0y sun
