Remus92
Everything posted by Remus92
  1. Me. Just the cheap-o versions. Run well and cost me around 2.50 a pop.
  2. Ngk. They always seem to work the best in Nissans.
  3. Unless yours is special. Your hubs are stuck. But they are stuck in always engaged because that is how they came from the factory. I agree with cuong start with the electrical system then move forward.
  4. Honestly with how similar the pattern is you may see very little difference between them. The generals are cheaper usually. Have you looked up the wear rating for each of them yet? Depending on that, one may last you longer than the other. You will probably have more road noise vs your destinations. And even though the destinations may not look like much i have always had a good experience in the mud and snow with them. My mom had a set of the bfg's on an s10 but the 4wd didn't work so i can't say how good they actually were... I know they did not like ice. But they were decent in the snow and fairly good in mud. If she doesn't want you cutting.... Better go with a size that you won't have too... I know those 30.5 inch tires will fit with no problems! Id probably go for the same size your running now.
  5. They are very easy to replace. I've bought them off of rock auto before and had good luck.
  6. Id get a sticker that looks like a yeti... Rather than have people think you like expensive coolers
  7. Well a cat does sit right below the master cylinder. The heat may be boiling or otherwise affecting the brake fluid. And the heat on the legs... If its over heating absolutely! It can only release so much heat so fast going up through the engine bay. Out the sides of the vehicle would happen too. What was the code?
  8. Just 1 filter per oil change is fine. I go hand tight going on. Removing i do use wrenches just to aid in removal. My favorite is the type that releases when turning clockwise and cranks down on the filter when turning counter clockwise.
  9. It almost sounds like the exhaust manifold leaking (diesel-esc sound) with injectors ticking as well. As mentioned above definitely check the timing chain tensioner. Even regardless of what the sound ends up being.
  10. Can you record the sound? The 2 vg30's I've owned both ticked from the injectors but had zero issues from them. It wasnt terribly loud but noticeable. Edit: you did record it... I need to pay more attention....
  11. Looks great! How was the transition to going up instead of down?
  12. It honestly wasn't too bad to fix roadside... Even in the nasty heat we had today. And it could have been way worse, but i had slowed down for the corner where the lug nuts left all let loose. It didn't get very squirrelly. It is a joke with me and my family that these damn pathfinders are trying to kill me... Rolling my first and getting pinned under this one. I just tell them I'm crush resistant. They like that better than invincible! Just have to find a wheel and it will be back to normal. Also going to install another new distributor tomorrow. Hopefully that one will last longer!
  13. So heading home from work. I lost some lug nuts... And subsequently a friggin wheel... The last time i rotated was around 2k miles ago... Probably should have retorqued i guess. So it broke one stud and bent several others and knocked the drum loose as i came skidding to a stop. Called my dad and got a ride to the parts store to buy new nuts and studs. We ended up fixing it on a gravel road as there was one directly across where i came grinding to a halt. I said f this to fixing it on the busy road i was on. I ended up using the lsd and throwing it in 4hi to drag the ass across the road and onto the less busy gravel road. Got the brakes back together, new studs installed, and the spare on. Yeah this whole stupid ordeal messed up my aluminium wheel a little.... I will end up having my good tire put on the spare until i find a new wheel.... As i do not trust the tire that is my spare... So, i will probably will call some junk yards to see my options. But if anyone has the 15inch 6 spoke aluminium wheels from the early r50s that they want to get rid of let me know. I will probably make a post in the wtb section later. Psa retorque within 200 miles. I'm going to have to make a build thread for all the stuff that breaks... I keep fixing them though lol
  14. That's my guess too. Retighten things. See if you can push or shake on the vehicle to get the noise to occur to help you narrow it down.
  15. The pictures are gone so I'm adding some since I replaced my thermostat today. I took these as I was putting it back together so I didn't take as many pictures as I probably should have. It took me less than 2 hours and that is with my Grandpa stopping by to see what I was up to. I also waited to refill the coolant as the silicone I used had a recommended cure time. fyi yours may or may not be pre-equipped with the mud splashed engine bay. So, follow the directions above. Remove the splash guard and drain the coolant, a 5 gallon bucket slid perfectly under my stock height rig. I found it easy to start in the engine bay by removing the upper radiator hose, the elbow of the intake and the radiator shroud. It gave me a ton of room and access to all of the bolts. Next remove the guard over the belt on the pulley assembly. Not required but it gave me slightly more room to move in there. (Didn't get a picture of this back on before everything else was in the way.) Loosen the top pulley and slide the belt off and let it droop down out of the way. Remember the top bolt tightens and loosens the belt tension while the bolt on the pulley allows the pulley to slide. Loosen both. Next remove the bolt for the AC line hanger. Then 3 bolts will remove this plate with the pulley on it. Now you are free to get this hose off of the inlet that houses the thermostat. Once that is removed. Undo the 3 bolts holding the inlet in place and pop it off. I had to lightly tap it to get the old silicone to pop free. Now you can remove the thermostat, clean up the 2 sides, and install a new thermostat with a fresh silicone bead. Note the tab on the old thermostat is up and there are knobs on both sides of the housing that are both on the top side as well. Reinstall everything in the reverse order and refill.
  16. Let us know what you think of them. I need to get tires somewhat soon and those are on the list to consider. Are you going to go for taller springs at the same time? Or just shocks and struts keeping stock height?
  17. I say wait on a name like zero suggested... Mine got named Flapjack within a couple months.
  18. Did you jump it off a cliff? Or it was a "hell no you can't hold my beer" moment...
  19. I found some mud on a level B road today. It was fairly soupy for my A/Ts the fronts don't have much tread left.... but I didn't get stuck! And from a few weeks ago when I found some ruts full of water on a dirt road with a friend... This adventure reinforced my need for a new front skid plate... lol And I took the pathfinder kayaking fishing drinking on my last day off work.
  20. To upload photos you can put them on a hosting site such as photobucket and then copy and paste the img link into your post
  21. I did that on a Volvo. Soup cans hold up to the heat better....
  22. Lol good luck. And yes. If you find the thread, message fleurys with the design you want. He keeps the thread updated with the designs.
  23. If i were you i would go for it. If tires are all it needs that's not too bad. Plus you can start with whatever tires you want.
  24. That's not a bad spot. You can get rid of that pretty painlessly. Honestly that's in great shape. I would go for it. But then again i bought my 96 with more miles and in worse shape.
